Question about Olympus Cameras
How to get rid of grid lines? - Olympus Cameras
    Sergeant:
  • 194 Answers
There should be a setting for grid or other displays on the screen, check your owners manual for the correct settings, or download one from the mfg. website if you don't have a manual.
Posted on May 11, 2014
How do I get rid of grid lines on my Asus computer monitor? I have had it less than one year.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Screen-shots to defective LCD panels are given. You can see and compare to that to your device, and can make sure about the fault to an extent.
Oct 08, 2015 | ASUS Televison & Video
read your manual all makes and models work different
Mar 20, 2015 | Olympus Cameras
Use a ten by ten grid to express the fraction 11/12 s a percent
11/12 = 0.916666. This number is infinite. So, you need to round it off to either 0.9167 or 0.917. of 1.0 whole number.
So as a 1/10th grid, the grid lines would be marked: 0.0. 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0 The grid line would go (Rounded off) 2/100's (0.02) past 0.9. Divide the space between 0.9 into 100ths. 4 equal spaces. Label these spaces 0.02, 0.04, 0.06, 0.08 Your gridline will go from 0.0 to 0.9 to 0.02.
Nov 04, 2014 | Office Equipment & Supplies
How i adjust horizontal size and vertical size
To answer your concern, all you have to do is to change the setting of your aspect ratio on your TV.
Here is my suggested way to procede:
1. Apply 1080i signal, which should produce an oversized HD image on ColorStream1or 2.
2. Select an HD channel that is broadcasting standard 4:3 image, not wide screen.
3. Switch to the Service Mode ( Please refer to the above links). In the Service mode, press channel up/down to find the Adjustment parameters needed for the following steps.
4. Adjust HIT with volume up/down control for the image height to 22.5 inches.
6. Adjust WID for image width of 30 inches, (22.5*4/3)
7. Adjust HPOS to center the image.
8. Adjust PARA and TRAP to minimize geometric distortion.
9. Switch into Convergence mode and Adjust VLIN to get equally spaced horizontal grid lines.
10. Measure the length of the central grid lines and note the number of horizontal and vertical grid lines. This information is used to create an overlay grid.
11. Create the overlay grid on 40x25 x0.003 inch clear Acetate sheet, which you can get at the Art Supply store for under $2. Draw the grid with a fine line erasable pen. Draw vertical and horizontal lines through the center of the sheet so that the lengths are the same as the central grid lines. Now draw the grid so that it has the same number of lines as the convergence grid but are equally spaced, with the outer ones at the ends of the central lines.
12. Cut off about 1/4 inch from the right side of the sheet so that the sheet can lay flat against the screen, which is slightly less than 40 inches.
13. Put a reference mark on the TV frame 2.5 inches down from the upper left side of the screen.
14. Place the overlay on the screen so that the upper edge lines up with the reference mark. The overlay sticks by electrostatic attraction.
15. Use convergence controls to remove grid distortion and converge grid colors. Refer to the Anamorphic link for details.
16. Enjoy 1080i.
Other Comments:
I didn't realize I could create the overlay grid before placing the Acetate sheet on the TV screen, until I finished drawing the grid with the sheet placed on the screen. I added grid lines as called for in the procedure. I'm sure this method took much longer no only to draw the lines but some of them were difficult to see.
Part way through the convergence procedure, I became concerned that the image width was off since I did my screen adjustment with wide screen image. Thus, I decided to repeat that step with a 4:3 screen.
I confirmed the need to press 7 often to save results since after I adjusted one grid color without it, I accidentally hit a key that switched me out of convergence mode and when I switched back, all settings were gone.
Another mistake I made was not realizing that the cursor color determines which grid gets moved.
May 13, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
My camera has lines running through the screen. Did I break something?
Probably not, many digital cameras have the option to display grid lines on the display to make it easier to frame your pictures. Look in your camera manual to see if you can turn grid lines on or off.
Grid lines can help you frame horizontal pictures (like a landscape).
Hope that helps!
Feb 22, 2011 | Nikon Cameras
I accidentally pressed the 2nd button and then the left side arrow button and now I have this black grid on my screen that I cant figure out how to get rid of if I tilt the screen I can see what I'm trying...
Displaying the grid on the screen is a graphing option accessed through the command GridOn. To turn the grid off, press [2nd][ZOOM] (FORMAT). Use down arrow to reach the 3rd line. Highlight GridOff and press [ENTER]. Press Graph to return to the graph screen.
How you activated the GridOn command by a single press of a button is a prowess. I wish you could teach me this legerdemain.
Hope it helps.
Nov 05, 2009 | Texas Instruments TI-83 Plus Calculator
Lines on the page
Hi,i will do this: Remove toner,then remove developer unit.Try to clean magnet roller on developer unit with dry cloth, if see lines on roller.Pull out paper transport unit(green handle ) and clean transfer roler and vacuum it.Then ,when is paper transport and developer unit out, remove drum unit(open door on the left side on the printer and pull out drum). Remove Corona from drum unit.Remove and clean grid,corona inside and corona vire.
Check fuser and drum for scratches.
Nov 23, 2007 | Kyocera Mita FS-1920 Laser Printer
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
Cameras Logo
121 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
