I have a Honda eu2000i generator to run a Husky TAW-1524p air compressor. Initial start/run is fine but subsequent compressor restarts as demand for air is required, put the generator into overload. Problem? Solution? Inline capacitor between generator and compressor? If so, specifications?
    Problem Solver:
  • 8 Answers
If your mechanical enough to figure out how to lower the air pressure switch on the compressor it would help with start up loads. For instances if your pressure switch is set for 75 psi. Lower this to 60 psi. or as low as you can and still operate equipment. Otherwise depending what horsepower and voltage {guessing 110 vac) the motor is, I would try an Hard start capacitor for refrigerators or air conditioners. They are rated by horsepower and have a built in relay that kicks it off automatically after starting . You can find these at any appliance or a/c & heating supply house.
Posted on May 12, 2014
SOURCE: Problem with capacitor of air conditioner?
the ratings of the capacitor should be on the capacitor itself in mfu sounds to me like the compressor stuck and cycling on overload is the capacitor distorted or swollen
Posted on Dec 29, 2007
SOURCE: penguin Duo therm AC bogs
Try replacing the wall thermostat with an electronic unit. It sounds like it is short cycling. If there is not at least 5 min delay before trying to restart the compressor this is what happens. Most electronic thermostats have a delay feature built in to solve this problem.
Posted on Jul 09, 2008
  • 5 Answers
SOURCE: Compressor tries to kick in but then stops.
it is a hard start compacitor, the unit is not supposed to have three compacitors.
Posted on Apr 11, 2009
SOURCE: I have a trane XR12
Hello Rich,NO you have a dual capasitor that runs both fan & compressor motors.Shut it down and let it cool off.You need the uf rate numbers & the volt rating of the existing cap (printed on the side)to get EXACT replacement.The wires plug in to the top termanls C, HERM &FAN.Worth fixing good luck.
Posted on Jul 29, 2010
Testimonial: "Thanks for your help and a quick response. The problem was the capacitor. $30.00 to fix the problem! You saved me a lot of time and money!"
hvac1960
  • 2133 Answers
SOURCE: how many amps will a 15000 btu ac unit pull at
15,000 BTU stating current 18 to 20 amphs. And running amphs will be around 6.5 to 7 amphs.
Posted on Dec 13, 2010
I have a deep eu2000i inverter, the problem is to remove the carburetor throttle, it takes some kind of setting as to start the engine low speed, and connect a tool fails ....
if your question is that my Honda generator wont idle up when I connect a load (tool) and it stalls then . first see if unit will run on constant setting (switch on front) if nothing or still barely runs or stalls , then your problem is carb or fuel filter (inside tank) one or both is most likely dirty and needs replaced/cleaned
Oct 15, 2016 | Honda EU2000i Companion Inverter Generator...
What do I check? i have a honda eu2000i that starts and runs but no generator power
The internal monitor is sensing a load does a load make it change tone? Check the 12 v output and see if it is loaded.
Kevin H
Sep 08, 2014 | Honda Eu2000i 2000w Generator
Portable generator stalls when load applied
Connect the air compressor to house plug and check amp draw with tester. More than likely you will find that the initial start amp load is too great for the generator. Do not rely on the information stated on the compressor. Generators and air compressors do not get along. At our repair shop, we find that most contractor /construction type generators that were used for running air compressors had failed or leaking capacitors and were not producing correct amount of power. You could have gen set with weakened capacity and air compressor that is drawing more than stated on plate. Good luck
Mar 08, 2013 | Hammering
Screeching sound-Honda eu2000i
Sounds like a bearing has failed or something has gotten inside the generator or engine area where it spins and is now rubbing against it. There is a bearing at the far end of the generator from the motor and it is most likely to be where the noise is coming from. Best to repair it before it seizes and wears out parts you don't want to have to try to find!
Oct 30, 2012 | Honda Eu2000i 2000w Generator
Husky Wl6510 air compressor, motor shuts off
One other possibility is that the check valve between the compressor and the tank is letting air flow back against the compressor. Is it having trouble restarting when the pressure lowers to the cut-in pressure? If it doesn't want to start up again, sounding like it's starting against pressure, suspect that valve.
Dec 13, 2009 | Air Tools & Compressors
Honda EU2000i with a washing machine
Yes - it will be a fine machine to have and do well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore Washing Machines
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
