Question about Whirlpool Duet GHW9150P Front Load Washer
Front load washer making noise on final spin - Whirlpool Duet GHW9150P Front Load Washer
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Posted on Nov 26, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Posted on Dec 21, 2008
aborcass
  • 2651 Answers
SOURCE: My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
Posted on Mar 07, 2009
SOURCE: Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Posted on Jul 07, 2012
TOO MUCH NOISE WHEN FINAL SPIN CYCLE
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 10, 2011 | Kenmore HE2 Plus Front Load Washer
Drum shakes and makes clunking sounds on final spin
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Feb 16, 2011 | Frigidaire Washing Machines
Final spin is knocking
Washer Problems
heatman101
Jan 16, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer making weird noise during final spin cycle
Hello suniljt. This is not good. That noise in the final spin is the machine's transmission going bad. This is a very costly repair and usually not recommended as you would be better off putting the money toward a new machine. Joe
THanks for choosing Fixya!
Nov 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
In the final spin the washer is so loud you can't stand by it what is wrong with it
heatman101
Sep 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
Final spins make big noise
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 21, 2010 | Frigidaire GLTF2940ES Front Load Washer
Load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Feb 14, 2008 | Frigidaire FTF2140ES King Size Front-Load...
No final spin
is there stil standing water in the unit at the end??
Jan 26, 2008 | Frigidaire GLTF530DS Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
11 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
