Question about Carrozzeria CYBER NAVI HDD AVIC-VH009MDG
How do i format hard disk drive - Carrozzeria CYBER NAVI HDD AVIC-VH009MDG
    Novelist:
  • 165 Answers
To format an external drive (HDD) in Windows:
1. Plug your drive into the computer and, if necessary, into a wall outlet.
2. Open Windows Explorer, click the "Computer" section in the sidebar and find your drive.
3. Right-click on the drive and choose "Format."
4. Under "File System," choose the file system you want to use. See the above section for more details on which one to pick.
5. Give your drive a name under "Volume Label," and check the "Quick Format" box.
6. Click "Start" to format the drive. You'll get a notification when it's done (it should only take a few seconds).
Posted on Apr 10, 2017
Format hard disk C of netbook
Important: It is recommended to take a backup of all the necessary data you have on your C: drive before you format it. Formatting the drive will erase everything on it.
The steps to format hard drive can vary depending upon which version of Windows you are using. You can refer to the following links for instructions:
For Windows 8 / 8.1:
http://pcsupport.about.com/od/windows-8/fl/format-hard-drive-windows-8.htm
For Windows 7 / Vista:
http://windows.microsoft.com/en-in/windows/create-format-hard-disk-partition#create-format-hard-disk-partition=windows-7
GuruAid.com
Feb 26, 2015 | Computers & Internet
Tip
Formatting an external hard drive with Mac OS X's Disk Utility
Formatting your new external hard drive is not as difficult as you may think. In fact, you don't even have to be a computer techie or uber-Mac geek to perform this procedure successfully.
The tool you would use, to format your drive within your Mac OS X system, is the built-in utility application called Disk Utility.
Disk Utility is Apple Inc.'s defacto utility application, for performing disk related tasks within the Mac OS X volume.
From creating new images, to burning CDs and DVDs to formatting hard drives, Disk Utility performs well enough to keep not only your Mac OS X volume on your hard drive error free, but keep your hard drive healthy and error-free as well.
I could go on in detail, admirably describing more features of this versatile Mac OS X tool, but the purpose of this FixYa tip, is to show you how to easily format your external hard drive. So that is where I will take you now.
There are generally two formats in Disk Utility that you can use to effectively format your hard drive.
Mac OS Extended (Journaled) - if you want a Mac readable hard drive only
MS-DOS (FAT 32) - If you want your external hard drive to be read by both Mac and PC.
--STEPS FOR FORMATTING YOUR HARD DRIVE WITH DISK UTILITY--
• First, make sure your external hard drive is connected securely to your Mac and is turned on.
•Next, from your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities* folder.
(*You can also get to the Disk Utility application via Applications > Utilities folder)
• Now, locate and launch the Disk Utility application.
When Disk Utility opens you will see a left side window, which will show
all connected hard drives and optical drives. It is here that you
should see your external hard drive listed in that window.
• When you locate it, simply select it and then select Partition
from the tabs on the right hand side.
• Change the Volume Scheme from Current to 1 Partition
• Make sure to provide a name for your new external hard drive.
• Select Mac OS Extended (Journaled) from the Format
drop down menu, for a bootable Mac only external hard drive.
• Or select MS-DOS from the Format drop down menu, for a bootable Mac & PC external hard drive.
From there, click the Options button, located toward the bottom of
your window.
This will open a partition scheme selection window as seen in this screen shot:
• Select GUID Partition Table for bootability on a Intel processor based
Mac.
• Or select the Apple Partition Map for bootability on a PowerPC based Mac.
• Click the OK button.
Finally, click the Partition button and allow Disk Utility to format your new external hard drive.
When this process is complete, you now have a newly formatted, ready to use hard drive.
Believe it or not, this process can be completed faster than you think.
Using this method with Disk Utility, I was able to format my new 1TB Iomega USB external in less than 20 minutes.
Final Note:
I used the external hard drive as the focus for showing you how to format and prepare your hard drive for use on your Mac, but this feature can also work with internal hard drives as well.
For more information about some of the disk repairing features of Disk Utility, here is a great support link for this nifty and quite effective Apple utility for the Mac OS X platforms:
Using Disk Utility to repair a disk
Thanks for reviewing my Mac OS X Tip!
Regards,
-Mactechtrainer
on Feb 11, 2010 | Computers & Internet
I was using a 500mb conner hard disk but now 4.5gb seagate hard disk but can't format it
you have to format your hard drive using a third party disc to erase everything on your hard drive
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating systemor if you are trying to format a usb drive
insert your pen drive
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Mar 27, 2012 | Computers & Internet
My WD My Passport external Hard Drive ! TB formatted for Mac is not reading my files
A Windows PC computer will not read files on the WD hard drive that has been formatted on a MAC.
The fix.
Copy your photos onto the MAC computer then remove the WD hard drive and connect it to your Windows PC and format the WD hard drive in FAT32 file system.
After formatting has been completed remove the WD hard disk and connect it to the MAC computer. The MAC can read and write to a Windows FAT32 formated hard disk. You can now copy the photos from the MAC to the WD hard disk. When copying is complete, remove the WD hard drive and connect the WD hard drive to your Windows PC and you can now copy the photo from the WD hard disk to your Windows PC.
Mar 05, 2012 | Western Digital Passport WDXML800UE...
Can i format device without deleting content on hard disk
You cannot format any disk without losing everything. When you format a drive you are essintally bringing it back to the state of it's first use. If you can, transfer the data to another storage device until after the format.
Jan 11, 2012 | Toshiba StorE Stainless Steel 2.5 inch...
FORMAT hard disk with PEN DRIVE
First you need to have the system files to format the harddrive and the process is to simply right click the pen drive and say Format . An option pops up select copy system files and format.then boot the system and it boots via pen drive type in the prompt Format c: /s/Q the disk will get formated.
Regards.
Feb 08, 2010 | Computers & Internet
I have a new, just out-of-the-box Seagate FreeAgent/Desk 1Tb external. After hooking it up, it just flashing and thats all. The automatic software installer did not launch and the Windows Hardware...
The first thing you need to do is go into the Control Panel, then double click on Administrative Tools. After that, open up Computer Management, then go to Storage, then Disk Management. This is where you will see all of your drives listed. Be extremely careful in this section because you don’t want to screw up your main hard drive.
What you are looking for in the Disk Management area is your new hard drive. If you only have one hard drive, it should show up as Disk 0. Therefore, your new drive should most likely be Disk 1. Underneath the name Disk 1 it should say Unknown, the size of the disk, and Not Initialized. Right click in this area and you should get a pop-up window. Click Initialize Disk and it should only take a couple of seconds.
Your hard drive is now ready to be formatted.
Formatting Your Drive Once your new hard drive is initialized, you will still have to format the drive before you can use it. To format, right-click in the column to the right of the Disk 1 label and then click New Simple Volume in the menu that pops up. From here, you can allocate how much of the drive you want for a new volume, what drive letter you want to call it, give it a name, and finally format the hard disk.
Formatting the hard drive may take a while, depending on the size. My 500 gigabyte drive took nearly an hour to format, so don’t be alarmed if your's takes a while. Once the format completes, your new hard drive will now show up in My Computer and you can start putting files on
Dec 24, 2009 | Seagate Computers & Internet
Checking hard disk for errors
no, checking the Hard Disk using windows tools does not format the hard disk. You data would still be there.
Jul 20, 2009 | Computers & Internet
My slave hard disk is not showing in my computer
Is it formatted ? Does it have a drive letter associated to it? If not then either format it (right click on My computer -> click Manage -> click Disk Management. Now right click the drive if it is showing there and either create partitions and/or format it if it not already formatted.
If it's already formatted, and you just need to assign a drive letter, then in Disk Management, right click the drive and click Change Drive Letter and Paths and assign an unused drive letter, say Z.
Close Computer Management and open My Computer. The new drive should show up now.
HTH,
Deboo
Jan 05, 2009 | Seagate 250GB Maxtor DiamondMax Plus 21...
Hard disk problem
First u should format disk from disk management mmc snap or from command prompt.without formatting a disk's properties says 0 bytes used and 0 bytes free space.
Sep 03, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Carrozzeria CYBER NAVI HDD AVIC-VH009MDG Logo
1,129 people viewed this question
Top Carrozzeria Work Safety Experts
Bobby Lewis
Bobby Lewis
Johan Erasmus
Johan Erasmus
Are you a Carrozzeria Work Safety Expert? Answer questions, earn points and help others
