Question about Electrolux Dryers
How change a thermofuse
Model energysmart. I cannot find where it is.
  • 1 more comment
  • Electrolux
    Electrolux May 15, 2014
    Good Afternoon Perrin,
    I see that you are trying to change the thermofuse on your Electrolux dryer. I will be more than happy to assist you. In order to better assist you, I will kindly ask for the model number of your dryer. You will be able to find it located either on the back of the door or around the edges where the door meets your dryer. Looking forward to hearing from you.
    -Best Regards-
    WP
  • perrin
    perrin May 16, 2014
    Thank you very much for your answer. My dryer model is EDC 77557W.
  • perrin
    perrin May 16, 2014
    I was looking for the thermofuse at the back. I will try to remove the front panel and if I don't find, I'll tell you. Than you again, Antoine
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Thermofuse looks like a small white square 1 " +or- long with a wire connection on either end
Posted on Jun 01, 2014
Di 621 ca
C 0540 Fusing roller (upper roller) thermistor or thermofuse failure.Verify the continuity of the thermofuse ,if neccessary change.The thermistor not defeted easy,90% thermofuse defected.
Mar 24, 2014 | Konica Minolta Office Equipment & Supplies
Dryer wont start
I have a Maytag dryer 5600tq0 and my wife had it for 5 years. it stopped turning on. i did a trick by opening the back and locating the small white thermofuse (Part# 3392519), unhook the 2 wires attached and somehow stick a small wire to connect those 2 purple wires together. Then plug the dryer on and if it turns on, then that ThermoFuse is blown. I ordered the ThermoFuse Part# 3392519 from Appliance Parts Stop on Amazon $3.37. I also ordered the small silver n black (with 2 blue wires n 2 thick red wires attached)Thermostat part# 3387134 $5.00 from ACS on Amazon because it works together with the thermofuse and all websites say it is common practice TO CHANGE this also. then plugged everything back and it worked.
Feb 17, 2013 | Dryers
Where is thermofuse and thermistor located
The thermofuse and the thermistor is located in the fusing unit.Open the front cover,remove 1 screw and pull out the fusing unit(the left exit cover must open).Remove 2 screws and the unit front cover.Remove 2 screws and the upper cover,remove the harness from the harness guide,unplug the connectors of the two thermistors.Remove one screw,shoulder screw and the harness guide,remove one screw and the thermoswitch cord,remove 2 screws and the temperature detector assy.Using a soft cloth dampened with alcohol or oil,wipe clean the 2 thermistors.Verify a continuity of the thermoswitch and clean using a soft cloth dampened with alcohol,wipe clean the thermoswitch.99% the problem is a thermofuse.
Dec 17, 2012 | Minolta EP4000/5000 CS/PRO Copier
Our whirlpool Ee 3j50rd045v keeps releasing water from the discharge line.We have it set on energysmart and seems to discharge in the afternoon after it hasn't been used for a few hours. We have taken it...
This sounds like the Themal Relief valve is not working properly. Some of these valves have a lever that you can lift to PURGE the valve of debris. If there is too much debris in the valve it lodges in the valve seat and caused blow-by / leakage. In the evnt that your thermal relief valve does NOT have a purge lever and you can not get the valve to seat after going as far as remving it to clean it then it should be replaced. The relief valve is Item 8 of this link:
http://www.searspartsdirect.com/partsdirect/part-model/American-waterheaters-Parts/Water-heater-Parts/Model-EE3J50RD045V/3274/1081000/50028188/00001
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Whirlpool Water Heaters
How do i check the thermo fuse with a voltmeter. i get 120 with top wire removed and zero with the bottom one removed
Hi
Please disconnect power before checking the thermofuse. Now use a Multimeter with R X 1 scale and touch the leads to the thermofuse terminals to test for continuity. If you get an infinite reading, it means the fuse has blown and needs replacing. However if you get reading above 100 ohms then the thermofuse is fine.
Please post back for any further assistance.
Daniel
Jul 22, 2010 | Dryers
My dryer wont start
this is common issue,,,thermofuse ,,home electricity check cercut breaker,,thermofuse is located normally behind the rear cover,,it is the only white fuse in the unit it is not resettable but is cheep to buy and easy to install,,,,,www.myabcspace.com/washerwizzards
May 15, 2010 | Roper RGS7745PQ Dryer
I have a konica 7022, it says call for service code F-35-3. what's wrong with it. please help me.
Fixing upper roller low temperature error.Verify the continuity the heater lamps and remove and clean the thermofuse.If the thermofuse not working change it.
Sep 25, 2009 | Konica Minolta Office Equipment & Supplies
Error code SC 542 on my Gestetner Dsm622sp
Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
Sep 24, 2009 | Gestetner Office Equipment & Supplies
ERROR CODE
there is a problem with the fuser, replace thermistor or thermofuse
Aug 29, 2008 | Canon CLC 1150 Color Copier
Ricoh afficio color 6010
· Hot roller fusing
lamp brown
· Hot roller
thermofuse opened
· Defective main
control board
· Defective I/O
control board
· Defective AC drive
board
more than likely the thermofuse.
Jun 17, 2008 | Ricoh 6513 Copier
Dryers Logo
35 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
