Question about Refrigerators
Why were Bulbs so hot they melted the lens and melted butter.
I took out the bulbs....temp solution What happened??
    Problem Solver:
  • 15 Answers
Most likely door was left open or door switch is faulty leaving light on when door was closed. also check bulb for proper wattage while your in there
Posted on May 13, 2014
Testimonial: "I manually pushed in the door switches, which worked. fridge blew hot air after I took out the bulbs until husband removed the entire electrical/lens unit. no lights now, but cold inside."
Volvo v70 head light bulbs gets too hot melts plastic connector/why
check that the connection on the headlight is tight if loose can spark causing bulbs to get hot and melts the plastic
May 18, 2014 | Volvo V70 Cars & Trucks
Tip
Reduce risk of overheating and plastic melting if lights stay on
Even though I have found a statement (I think it was in the LG2.gif troubleshooting2.gif FAQS on line) that the lights in the newer LFX25960 french door/bottom freezer refrigerator will shut off after a period of time to prevent overheating and melting the plastic housing, I have heard of this problem enough times to worry about it. So I replaced the two 60 watt bulbs in my refrigerator with 25 watt appliance bulbs just in case. They provide more than enough light and do not get as hot when on. It took a while to find them. They are made by Philips2.gif and were at Home Depot but not always in stock.
on Sep 18, 2009 | LG LFX25960ST Stainless Steel French Door...
Kenmore elite refrigerator
Are the correct bulbs being used in the fridge? You can't just use 'any'. And of course they should be turning off when the door is closed. You can download the manual for your model from several sites that have them, like manualsonline dot com, and others.
May 11, 2014 | Refrigerators
S10 pick up back cab break light not functioning
The break light bulb on the back of the cab goes out a lot. Just remove the lens and replace the bulb. Get the bulb from the dealer ONLY! All other bulbs burn too hot and will melt the lens.
Apr 30, 2014 | 2001 Chevrolet S-10
I have a problem nobody seems to know the answer to. My daytime running lights get so hot they melt the housing around them. I took it to the dealerhip and they had it all day couldnt find anything. After...
there was a problem with aftermarket bulbs being wrong..check connectors and make sure it has the proper bulbs..see your local dealer for the right bulbs
Dec 22, 2009 | 2004 Chevrolet Malibu Maxx
2007 Chrysler TOWN AND COUNTRY.. OVRHEAD MAP
I had the same problem on my 07 and it turned out to be caused by the bulbs getting too hot and melting the surrounding plastic which opened the circuit powering them. I was able to fix the problem by removing the bulbs and cleaning the sockets allowing the bulbs to seat correctly. The lenses snap off to give you access to the bulbs. If you are not familiar with how interiors of cars come apart, I would not suggest doing it as you may crack the lens.
Sep 29, 2009 | 2007 Chrysler Town & Country LX New Cars
On my 2003 venture, both brakelights burn out, they seem to get hot and melt at the base. This happens over the course of two to three weeks. First one goes then the other. What's up with that?
you need to get new board that the bulbs plug in to there not making good conection and make sure you use long life bulbs they dont get as hot
Jul 13, 2009 | 2003 Chevrolet Venture Passanger
Change rear signal bulb on 2002 ford focus wagon
Open the rear tailgate There are 2 screws that hold light housing in place.. Remove the screws then pull the housing outwards till the clip behind it springs. You then need to knock the housing sideways (outwards) to free the 2 prongs that attach housing to the car body.
Unclip the rear housing from the back of the light unit & change the bulb.
Aug 01, 2008 | 2002 Ford SVT Focus
795.77573600
I just saved my fridge / home too, smelled what I thought to be an electrical fire when I opened the Trio doors, immediately looked at the bulbs as a probable cause, and sure enough, the base of the bulb sockets were burned-brown and the plastic housing was to hot to touch without a hot-mit.
Unscrewed the bulbs and set aside out of children's reach and combustable materials.
I'm filing a complaint and service repair today. 8/3/08
Sean-Jon
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
