Question about GE (PSS26MSRSS) Side by Side Refrigerator
It started with not defrosting after defrosting unit runs but doesn't cool.
About three weeks ago My refrigerator stopped cooling while the freezer worked well. Thanks to this DB I found my evaporator coils were iced up so I thawed them and clean my condenser coils. Everything seemed to work well. Now, three weeks later my neither refrigerator nor freezer will cool. I have checked the evaporator - there is no ice on the evaporator coils. I have check both freezer thermisters At 32 degrees they measure 16,300 ohms respectfully. I don't know what to check next.
4 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Stops cooling ice melts and leaks water on the floor
That model refrigerator uses the mother control board for deciding when defrost is to take place. It has no defrost timer or Adaptive Defrost Control like other refrigerators. This sounds like *********** board part number WR55X10942 is malfunctioning. The board decides most functions of your refrigerator. Until the board is replace I do not believe the problem will resolve itself. Thanks, Sea Breeze
Posted on Sep 26, 2009
aasc
  • 1606 Answers
SOURCE: Refrigerator does not cool.
Ok , I'll help you .
Pull the refrig out from the wall , and unplug . Remove the 8 " X 10 " panel on the back of the refrig . Inside this panel , is the main control board .
Remove the blue plug with 3 larger wires going to it . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . Get a short piece of insulated wire , and remove about 1/4 inch of insulation , from both ends . Insert 1 end of the wire , into the slot of wire2 , and the other end , into wire3 .
Plug the refrig back in .
After about 2 min , look inside the freezer , behind the bottom crisper , and look for a red glow . This glow , is the defrost heater .
If no glow , this is an indication of a shorted defrost heater , or bad defrost thermostat , both of which are located behind the rear freezer panel . Unplug the refrig , and reinstall the blue connector , and the 8 x 10 panel .
The pt # for the heater is WR51X10101 , and the part number for the defrost bimetal is WR50X10068 . Both should be replaced . The heater is at the bottom of the coils , held on by 2 screws , and the thermostat , is clipped on the top right of the coils , with a blue and pink wire going to it .
If you do see a red glow , reasemble as above , and remove the rear inside freezer panel . At the top of the coils , on the left , you will see 2 white wires attached to a 1 " piece , which is clipped to the coils . This piece is the # 4 thermistor ( evaporator thermistor ) . Pt # WR55X10025 . Also replace the # 5 thermistor , ( freezer thermistor ) which is at the bottom of the panel , slid into a holder , also with 2 white wires going to it . Both thermistors , sent readings of temp , by coldness resistance , to the main control board , which then decides if it needs to defrost , or cycle off due to coldness reached .
Posted on Oct 11, 2009
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
I have an Amana Model ARB2214CB Refrigerator with the bottom freezer. The unit runs fine but the last three months for about a week it stops cooling and the freezer stops freezing. You can hear the fan...
That sounds like a defective=> 67001036 Defrost Timer
slowing down and sticking in it's defrost position on the timer cam. The defrost timer can be found inside the fresh food section behind the controls. See=> ARB2214CB Controls location #12 in the photo HERE Questions? Thanks John Tripp Appliance 911
ARB2214CB User Manual
Feb 20, 2014 | Amana ABB1927DE Bottom Freezer...
I bought a French 3-door Refrigerator about three years ago and the freezer recently stopped cooling and then the refrigerator stopped cooling. The refrigerator runs but doen't cool. Any help here?
Yes. You have a faulty automatic defrost cycle. If you manually defrost the freezer, then restart the fridge and it is back to normal. It is a sign that the defrost is faulty and you will need a technician to fix it for you
Apr 04, 2011 | LG Refrigerators
About every two or three weeks the temperature rises to about 15 F in the freezer. Temperature also rises in the main part.
Defrost timer/control board is sticking...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer has started to frost over. It started about 2 weeks ago and is getting worse. What is the cause for the automatic defroster to stop working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 15, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
18 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
