Question about Philips HR1363 Mixer
Citrus press on Philips Cucina HR7745 food processor not working
The citrus press is the sole component that is not working. All other components work. What is more, the food processor motor runs when I use a chopstick to depress the button inside the vertical shaft (officially called the Coupling Toolholder in the service manual for this appliance). It's as if the pin inside the cone of the citrus press has worn down to the point that it no longer depresses the button far enough. Can anyone confirm if my suspicion is correct? I assume that if this is the case, there is no other solution but to get a replacement cone...
Why wont my food processor work?
[PDF]Food Processor - Cuisinart
CuisinartDough blade, metal chopping blade, 3 slicing discs, shredding disc, detachable stem... food processing technology plus the largest work bowl on the consumer ...
[PDF]Download Manual - Cuisinart
Cuisinartwork bowl, cover and pusher ... The work bowl won't come off until the ..... DOUGH.BLADE. 12. The Pro Classic1" Food Processor can mix and knead dough in a.
[PDF]INSTRUCTION BOOKLET - Cuisinart Cuisinart12-Cup Cuisinart Elite Collection® 2.0 Food Processor FP-12N Series. For your ...RECOMMENDED MAXIMUM WORK BOWL CAPACITIES ... dough blade, adjustable slicing disc, reversible ...... immediately after use so food won't dry on them ...
[PDF]Premier Series 7-Cup Food Processor DLC-2007N - Cui
Jan 01, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
Does the clear guard remove for cleaning and if so how?
I don't understand what do you mean by this question. Explain and specify what do you want to remove for cleanin.
Just as a general explanation, you can't submerge in water the part whare you have the motor of your mixer.. Just wash exterior wiith a moist cloth. Watch these videos about the theme
How to Clean Food Processor
How To Clean Your KitchenAid Mixer
How To Clean Food Processor
The Food Processor How It Works Cleaning Easy
Jul 31, 2015 | Food Mixers
How can i found a part of a food processor from philips mixer type HR 2970/C ?
The machine is a relic from the past, parts are no longer available.
Aug 05, 2014 | Food Mixers
Kitchenaid food processor, motor rotates but when blade is inserted it won't rotate
It will be something in the mechanism that activates that switch in the base. It is more common for the fault to be in the lid but it is not so uncommon for it to be the bowl. You are using the pusher aren't you? That's the mechanism activator. This information is relevant to the wide mouth model.
Jul 30, 2014 | KitchenAid Food Mixers
How can I operate the Aux for DPX-55MD?
Jun 13, 2014 | Food Mixers
Food processor assembly
I'm going to take a guess that you can't get it to work....tell me if I'm wrong. The biggest mistake people make when assembling their food processors is putting the bowl on backward. It will not run if the bowl is on backward. The handle on the bowl should face the front of the base. Once you click that into place, put the blade on, then lid and lastly the pusher. For safety reasons, all of that has to be in place for it to work.
Jul 18, 2012 | Cuisinart DFP-3 Handy Prep 3-Cup Food...
Breville wizz stick professional doesnt operate.
If you can feel anything when you press the button, unplug it and try to turn the mixer. Once you get it freed up, put a drom of cooking oil where the shaft comes out through the case.
Jan 14, 2009 | Food Mixers
Citrus juicer
maybe you need the nut (adaptor and washer ) for attach your juicer ...
you can get in
Jul 24, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Philips HR1363 Mixer Logo
108 people viewed this question
Top Philips Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Philips Food Mixer Expert? Answer questions, earn points and help others
