Question about LG Washing Machines
Makes strange noise when centrifugating. What might the cause be?
Thanks.
    Genius:
  • 1,554 Answers
Normally knocking while spinning always means a shock or spring is damaged , open it an watch where it hits . play with the suspension it should be taunt like your car does
watch for power , you'll likely be getting dirty fixing this one.
sometimes the concrete weight around the tub is cracked or loose too.
Posted on May 19, 2014
Beko DWD5410 - noise
The strange noises are of of your hose water. I think your water system is not alright or unit called ciop is damaged.
Mar 27, 2010 | Beko 24 in. D3421F Free-standing...
My Daewoo TV screen just went all Blank n Black suddenly while it was running all fine Then this was accompanied by a strange clicking sound and now whenever i turn it on,it just shows nothing(blank...
The set has developed a short either in the power supply or the horizontal/high voltage circuit. The power supply makes a weird noise when it gets overloaded. This can get complicated so have a repair shop check it out for you. Thanks
Nov 01, 2009 | Daewoo DTQ-13V1FC TV
The carrage goe "bang" then the displayy claims that a paper jamb caused the problem. However, there is no paper anywhere near the carrage. Any ideas? Thanks John
Hi there again here is the web site for you to troubleshoot your problem ok best regards michael
  1. Troubleshooting Printer Noise When printing, The HP Deskjet 600 series printer makes strange noises such as: ... periodically slams or bangs against the left side of the printer while it is ...h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpd07280&... - 75k
Sep 14, 2009 | Computers & Internet
I have servis washing machine and i think the pumps broken coz it makes a strange noise when its suppost to be draining is this expensive to fix and is it easyily done thanks
you may wont to look at pump to make sure their is nothing in it causing it to make noise.some are expensive to replace but it is cheeper to do it yourself.
Mar 25, 2009 | Washing Machines
Clutch making strange noise when changing gears
It sounds like your clutch release bearing is worn/noisey causing fault
Feb 15, 2009 | 2002 Audi TT
When stapeling it makes a strange ping noise
I talked to hatachi about this.as i had a customer that had the same problem.there tech support said that they have had a few of these do this. it is caused by some **** in side the tube connecting the two tanks when it was welded.they said over time it should stop as wares with time.will not harm anything but is extreamly irritating.The offer no solution. which is bull !!!!!!!!!!!
Dec 18, 2008 | Hitachi EC12 Portable Electric 2hp Air...
High pitched noise
HI Step 1: Remove the back access panel. Then reach behind the drum, motor pulley, and idler arm pulley. If these areas are clogged with dirt and lint, undue strain on the motor may be causing the humming noise. Worn or broken belts can also cause a humming noise. Check the belts for wear and damage. If the belts look all right, you may be able to stop the noise by spraying them with fan belt dressing, available at automotive and hardware stores and home centers.
Step 2: Turn the dryer on. The noise you hear may be the whirl of the spinning drum, not the motor. Some noise is normal.
Step 3: Force a little 20-weight nondetergent motor oil (not all-purpose oil) around the ends of the motor shaft. This lubrication may stop the humming noise. If this doesn't solve the problem, remove the motor and take it to a professional service person.
The centrifugal switch on the dryer motor may be located on top of the motor. Humming, no motor power, and no heat can be caused by a faulty centrifugal switch. If the switch is externally mounted, check the terminals of the switch to make sure they are tight and not burned. If you spot trouble, remove the switch and take it to a professional service person for testing. A faulty switch will probably have to be replaced. Some centrifugal switches are located inside the motor housing; you won't be able to remove the switch in this case. Remove the entire motor and take it to a professional for repairs.
Oct 07, 2008 | Hoover HDC6 Electric Dryer
Washing Machines Logo
49 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
