Question about Texas Instruments TI-89 Calculator
My ti-89 gives me a data type error when I am asking for rref on the matrix that I entered.
    Sergeant:
  • Texas Instru... Expert
  • 264 Answers
An argument is of the wrong data type
Posted on May 13, 2014
FirePhantom
  • 5 Answers
SOURCE: My TI-89 cant do simple calculations.
You have to set how the calculator handles numbers. To do this follow these steps: 1. Press the 'MODE' button. This brings up the calculator's main settings page. 2. Scroll down until you reach a field titled 'Exact/Approx...'. This is the setting for how the calculator handles numbers, whether it will show the exact answer (which is usually in fraction format) or whether it will show an approximate number (which will be in decimal format). 3. Press the right arrow which will bring up the options for that setting. You must now choose between three ways of handling numbers: -'1:AUTO' will determine which type of answer the calculator will give based on what numbers you want it to calculate (e.g. if you want an answer in decimal format just add a decimal somewhere in your problem). -'2:EXACT' will automatically display all answers in either whole number format or in fraction format. -'3:APPROXIMATE' will automatically display all answers in decimal format. 4. After you have selected one of those options press enter one more time to get out of the 'MODE' dialogue and return to the 'HOME' screen. Now try a problem and see what happens. Personally I like using 'AUTO' because then I don't have to keep returning to 'MODE' when I want either or. Hope this helped, I had the same problem when I first started using the TI-89.
Posted on Oct 07, 2007
SOURCE: "domain error" message on ti-89 titanium
I had the same problem, this worked for me:
Mode -> page 2 -> Exact/Approx change from "Exact" -> "Auto"
Posted on Aug 28, 2008
  • 3 Answers
SOURCE: Calculating out npv and irr
Use the "FINANCE" app:
[APPS] [1] [ENTER]
for npv: select "7:NPV"
now you should get "npv(" on your screen.
use: npv(interest rate, cost {cash flows}, {frequencies of cash flows})
for irr: select "8: irr"
"irr(" will come up.
use: irr(interest rate, cost {cash flows}, {frequencies of cash flows})
Posted on Apr 30, 2009
onomou
  • 24 Answers
SOURCE: steps in solving matrix on my ti 89 calculator.
I assume you are speaking of solving a system of equations with a number of unknowns. If not, please correct me. Here's an example in practice:
If you have a system of 3 equations with 3 unknowns, you would set up your matrix so that the coefficients of each variable for a particular equation are on one row. So, given equations x + y + z = 0, 2x + 3y - 4z = 1, x + -z = -1 you would type the following into your calculator: [[1,1,1,0][2,3,-4,1][1,0,-1,-1]] and press enter to make sure you typed it correctly. notice that in the third row there is a zero, since we have zero time y for the third equation. Then row-reduce the matrix (2nd > 5 > 4 > 4 or in the CATALOG as rref). You should get out the matrix [[1,0,0,-1][0,1,0,1][0,0,1,0]]. This says that x=-1 y = 1 z=0 since my first column contained the coefficients for the x variable, the second for the y variable, and the third for the z variable. The last column contains the solution, the part on the other side of the equals sign.
Hope this helps! For more reading (from someone else; I just made this one up), check out the Wikipedia articles on Gaussian elimination and Systems of linear equations
Posted on Oct 03, 2009
  • 7993 Answers
SOURCE: My TI-89 won't convert temperatures.
There is nothing wrong. For all units except temperatures you use the [|=>] the arrow operator to convert from one to anther. For temperature conversions however, you must use the tmpCnv( command.
Exemple of syntax. tmpCnv( is accessed through the catalaog or enter using the Alpha_shifted keys (Ti89)
tmpCnv( 100_ deg C,_ deg F) [ENTER] should give 212
You should explicitly enter the underscores, the degree symbols and the C, and F. The last two need not be capital letters).
Hope it helps.
Posted on Dec 05, 2009
I am dividing a 3*1 matrix with a 3*3 matrix with numbers in polar format and it gives me the error data type error.
You'll get the same error if you try to divide two matrices with real numbers. The TI-89 doesn't allow you to divide a matrix by another. However, you can multiply a matrix by the reciprocal of the other.
For example, to calculate A/B, calculate instead A*B^-1 . Makes sure you use the (-) key just to the right of the decimal point key to put in the negative sign before the "1".
Sep 10, 2011 | Texas Instruments TI-89 Calculator
Ti 89 titanium when multiply 2x2 matrix by 2x1 matrix get error diemensions
Matrix multiplication is defined only when the width of the first matrix is equal to the height of the second. You can multiply a 2x2 matrix by a 1x2 matrix or multiply a 2x1 matrix by a 2x2 matrix, but you cannot multiply a 2x2 matrix by a 2x1 matrix.
Jun 13, 2011 | Texas Instruments TI-89 Calculator
Im trying to create a program to run the colebrook formula but after i program it and enter the unknown i get error data type and brought back to program editor screen.
The error data type means that the program is expecting a specific type of data ( number, list, matrix, real, complex, string, etc.) while you are feeding it some other type of data. The point in the program where you are taken when the error occurs is where the exception was launched.
A common source of error stems from the use of variables that are global and defined in some other program. You can use the same name inside your program as long as you declare the variable local.
If your program is in fact a function, then all its argument must be passed in the call to the function: You cannot ask a function to read your input.
I will not pretend to know why you get the error, but the few comments I made above may help you debug the program.
By the way, if you are interested a Cobebrook online calculator, here is a link
Apr 26, 2011 | Texas Instruments TI-89 Calculator
I am trying to drive a prediction equation. but the book gives directions to aTI-84 and I have a TI-89. I have these steps "STAT, EDIT, L1, L2,STAT, CALC,LinReg(ax+b), ENTER" I have no clue how to make...
I assume you know how to enter data in your calculator. The keystrokes in the following pertain to TI92/92Plus/ Voyage 200 PLT. The main differences with the TI89/Ti89 Titanium is that the function keys F6,F7,F8 are not accessed directly but by the key sequences [2nd][F1], [2nd][F2], and [2nd][F3] respectively
1. CLEAN THE SLATE (so to speak) and ENTER DATA
In Home folder run F6: NewProb to reset the configuration.
Press Apps, and select 6: data/Matrix editor. Select a new data set
Give it a name: here testing.
Press OK/ENTER, The data entry screen opens, enter your values.
When you finish press F2.PlotSetUp.
2. Statistical plot setup and scatter plot drawing
b142867.jpg.
Press F1:define to configure Plot1. Choose Scatter, then choose a mark for the data point. I select 5:Dot. and press [ENTER
Select the data column X=c1, Y=c2
Press ENTER to save configuration. Press [CTRL] [GRAPH] On my TI92 the CTRL key is the [Diamond] key. On the following graph I changed the mark to a cross to see the data point better. I also played with the window dimension. You can also do that with ZoomStat. The graph remind me of a parabola (I know I chose the exact values)
3. STATISTICAL CALC. AND REGRESSION ANALYSES.
Now we have to find the equation that fits these data best.
You press APPS 6:Data/ Matrix editor but you select current to return to your data set. You are taken to the data entry editor (Figure 3 above). In that screen Press F5:Calc to edit the type of statistics you want
On first line select the type of regression model : Linear Regression, QuadReg quadratic regression (or anything else available) X is from column1, Y is from column 2. Store RegEQ The regression equation in say Y1(x)
Press ENTER to save to get the Regression Equation. Here it is
As you can see I cheated: a perfect parabola. R^2 =1.
And here the best fit represented on same graph as the statistical data
Usually you have to try different regression models, until you find the one that fits best the experimental data.
Jul 26, 2010 | Texas Instruments TI-89 Calculator
Find the equation of the line that best fits on a ti 89 calculator
b142867.jpg.
Press ENTER to save configuration. Press [CTRL] [GRAPH] On my TI92 the CTRL key is the [Diamond] key. On the following graph I changed the mark to a cross to see the data point better. I also played with the window dimension. You can also do that with ZoomStat. Th graph remind me of a parabola (I know I chose the exact values)
On first line select QuadReg quadratic regression, X is from column1, Y is from column 2. Store RegEQ The regression equation in say Y1(x)
Press ENTER to save to get the Regression Equatio. Here it is
And here the best fit represented on same graph as the satistical data
As you can see I have gone a long way out of my way to show you all the steps.
I hope it helps you and others who wonder how to do regressions on a TI89. If someone does not understand these explanations, the blame does not rest with me.
Oct 21, 2009 | Texas Instruments TI-89 Calculator
Steps in solving matrix on my ti 89 calculator.
May 03, 2009 | Texas Instruments TI-84 Plus Calculator
"variable or flash application in use"
First stop the application that is running [2nd][Quit] or [Escape]
From Home screen
[Apps][Data/Matrix Editor/][3:new] name the data set when asked.
A table is displayed Enter the values in list c1 and c2 You can rename the variables in header.
When finished press [F5:calc]
In calculation type right arrow select 5:linReg in front of x enter c1, in front of y enter c2 and [enter] to save. the equation shows when you press [ENTER]
Hope it helps.
Apr 03, 2009 | Texas Instruments TI-89 Calculator
Solving matrix
Go to your matrix button and enter a "3x4" matrix.
Then enter it as follows:
-3 4 5 7
4 3 2 9
-5 5 3 -10
Then exit out and go to "2nd->matrix->math->rref(". Then press enter.
Your screen should look like this:
rref(
Then go to matrix and select your 3x4 matrix, press enter and close it with a parathesis. Your screen should look like this:
rref([A])
Press enter and the screen should say this:
1 0 0 2
0 1 0 -3
0 0 1 5
So,
x=3
y=-3
z=5
Hope this cleared up the confusion!
SJ_Sharks
Mar 03, 2009 | Texas Instruments TI-84 Plus Calculator
IF I HAVE TWO equations 5x+8y=54, AND -9x+y=26 how do i solve
use the simultaneous equation solver software available on ur ti-89 and enter the equation in the form of augmented matrix and you will get ur answer.
Dec 03, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
234 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
