Question about GE Advantium 120 Convection/Microwave Oven
Wont heat at any setting? It was working fine until we moved it to another location.
Its a JES10SK The turntable turns but no heat on any setting
  • Dave May 11, 2014
    Hi Arveda Rollins, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Need to know if the microwave won't heat, or the convection portion, or both.
  • Arveda Rollins
    Arveda Rollins May 12, 2014
    The unit will not heat on any setting.
    Sergeant:
  • 194 Answers
There are many GE support forums and factory support sites.
You might check first for a fuse inside (OVEN UNPLUGGED!)
Posted on May 11, 2014
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker microwave turntable will not turn
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 02, 2008
ercupa190
  • 12223 Answers
SOURCE: Food Heats fine, but turntable wont rotate. Makes a loud noise until we press the
see this tips for to repair:
Inspect the plastic drive coupling that the tray sits on, as well as the ring-and-roller assembly, to make sure that they're working properly.
First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Posted on Sep 10, 2012
Sep 09, 2012 | GE JVM1860 Microwave Oven
My over the range magic chief microwave was working fine until one day it just shut off no power! i had an electrician come and found that there was electricity in the sockets but microwave wont work at...
HI.Let me just ask how many years that it has been used. Other auxillary parts might have been give in.Remeber that a single IC or just a single resistor or capacitor or an inductor that has been busted will stop the unit from operating. If socket wherein oven is connected has votage on it then the problem is in the unit itself. Now there are several parts of an oven.few to mention there is a dc motor that turns the turntable,a magnetron that is capable of heating the unit and has fuse on it.Now have you tried to check the terminal button/connection of the unit.Before it was shut down o won't work what was the condition of the unit .Did it suddenly turned off while using it.There are few things to check ..First the terminal button/connection of the unit. Also check the fuse possibly it blown out or you can check motor. You can check the continuity of the circuit using a Multitester. Check the continuity of the circuit by setting it to OHMS. Connect both ends.If the pointer does not moved or either it moves that reaches the maximum then parts of the unit was short-circuited.If the pointer just moved a little then unit is fine its just the connection to the terminal was not engaged properly there is an open circuit of the termnal ends.hope this idea helps.Thank you for choosing FIXYA.
Jul 17, 2011 | Microwave Ovens
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Em-s3577s uk 2 wont turn
Remove the turntable plate and check the motor coupling gears underneath, if motor coupling is fine, then replace the turntable motor.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 19, 2009 | Sanyo Microwave Ovens
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
Turntable sometimes works, mostly doesn't
It sounds like you have a jamming turntable motor.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Jan 28, 2009 | Microwave Ovens
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
May 14, 2008 | Hotpoint RVM1635 Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
103 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
