Question about Bosch 24 in. SHU53 Built-in Dishwasher
Bosch shu 6800 won't drain in any wash cycle except drain
SOURCE: Bosch SHU 5300
Mine did that. I tried changing the timer but it didn't help. I noticed that the water level kept rising until the drain pump would be triggered by the overfill protection switch on the left side under the insulation. It turned out that the fill valve didn't close all the way and so the pan would never empty. A new fill valve (easy to install and cheap) fixed it!
Posted on Jun 19, 2008
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
SOURCE: my bosch dishwasher whistles when on washing cycle
it is your wash pump
Posted on Apr 16, 2009
  • 98 Answers
SOURCE: Our Bosch SHU 4300 dishwasher does not drain fully
There is a recall on the control board of many of these models, butyour problem is likely not related. A sticking impeller indicates that the pump may be failing, but you are welcome to try my guide to help. It is here. Thanks!
Posted on Jul 19, 2009
  • 98 Answers
SOURCE: bosch shu 4000 dishwasher no water comes in when
I have written a guide to help. It is here. Thanks!
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Bosch Integra SHU 9955US/12 - when we start wash cycle, the detergent dispenses and the tub fills with water, but the wash cycle never starts (never spins spray bars). Seems like timer is counting down,...
Sounds like your motor is burned out. The drain motor and wash motor are seperate on your machine. You can check for power going to the motor, but to do this you might have to pull the dishwasher out. While the cycle is running check for 120 VAC going into the motor. If you are getting power and nothing is happening, you will need to replace the motor, otherwise you will need to replace the motor control board located at the base of the machine.
Jan 31, 2011 | Bosch SHU9955UC Built-in Dishwasher
Beeping sound when cycle is finished just started after 8 years. how do I turn it off?
Welcome to FixYa.
I think can answer your question..."beeping sound when cycle is finished just started after 8 years. how do I turn it off?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
? If the display blinks with a "0", you will hear
no signal (indicates OFF).
? If the display blinks with a "1", you will hear a
LOW volume signal.
? If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
? If the machine beeps, then the Cycle
Completion Signal has been enabled.
? When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Nov 06, 2010 | Bosch SHU9915UC Dishwasher
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
• If the display blinks with a "0", you will hear
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
function:
• If the machine beeps, then the Cycle
• When you push the button again and it does
program mode.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
I have a built-in Bosch dishwasher SHU 4302 UC. It no longer drains the water out at the end of all the cycles. I have tried everything mentioned in the booklet (make sure water is hot, use the jet-dry...
The problem is a solenoid on the bottom of the unit. It is a small black cylinder next to the pump. It operates the valve that changes to the drain cycle. You can probably order one from Bosch
Aug 18, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 3032 dishwasher gets stuck halfway through the wash cycle and just continues to wash until you manually advance it. I turned in on before bed one night and it was still running the next morning....
It obviously sounds like a timer issue here, and as it's embedded in a big chip on the control board, I would think a new control board is needed.
The exception to this is if it is not heating at all, in which case it won't advance if the water is not hot enough. Try it again and see if it gets warm.
If not - replace the heating element.
Most machines just stop to heat up the water, but to cut down cycle time they may recirculate the wash-water first to speed things up.
May 04, 2010 | Bosch 24 in. SHU30 Built-in Dishwasher
Impeller is going bad. What will cost to fix on a Bosch shu 9990
Hello there
Normally you will want to get the impeller kit for this it will include the seal for the impeller
Drain & Wash Impeller Kit - Comes with drain & wash impeller, pump seal, chopper, gaskets, screw and instruction sheet.
Part Number: AP3115180
Our Price: $29.00
this is a quote from parts select.com
and is usually a fairly normal price
ok hope this is very helpful for you
Best regards Mike
Jan 06, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
testing will end shortly after water has started circulating
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Error message F on shu 6800
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 5300
May 11, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
50 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
