Question about Samsung Televison & Video
Ic 44608p40 power draygram
    Top Expert:
  • Samsung Master
  • 75,178 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name or IC number of your device at its search box.
Power supply regulator schematics to many popular brnd TVs are given.
Posted on May 19, 2014
Why burning 44608p40 power supply k2645
Check ground screew , also disconect and re conect conector .
Jan 17, 2015 | Power Computers & Internet
Sa-ht545 error code f61- comes up upon statrting
F61 just equal 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic IC 502.
As both said ICs get very got first remove bottom steel grill and with the power off and capacitors drained (shorted together with a low ohms resistor or leave unit powered down for a few hours) resolder the ICs legs if there are any signs of cracks aka dry solder joints.
Hope that helps.......
Jul 09, 2008 | Panasonic Audio Players & Recorders
Good day i have a Technics amplifier SU-X320. Problem is it powers up up there is no sound. Checked all basic fault finding, suspect it is the volume IC.
"Volume IC" do you mean an IC that is a pre-amp and controls the volume and things like tone? Or do you mean the main power amp IC, which will be on the big heat sink?
If you amp uses the latter and not individual separate devices for the power amp, suspect that over the other IC. But if the amp has separate power amps for both channels, replace the IC.
Oct 09, 2013 | Technics Audio Players & Recorders
I have problem model TCL-14175 I replace ic 8 pins 44608P40 but still unstable power supply
You've replaced the main system control memory IC, I assumes. If so, an adjustment called, memory initialization, should be done after replacement, or, the newly prepacked IC do not work. If you wish to get more details about this, check this link. http://electronicshelponline.blogspot.com/
Oct 08, 2013 | Samsung Televison & Video
How to reset power ic on laptop?
Removing the battery and mains power supply will totally reset the machine.
The power ic has no memory, so I doubt they are telling the truth.
Nov 26, 2017 | MSI Computers & Internet
My SC-HT650 system reads F61. I think I need a new transformer. Where do I find that?
Not the transformer. probably needs a voltage ic or output ic. F61 is a voltage error code. if it was the power tranformer it would not power up at all. It also could be just a bad fan. The fan should start as soon as you turn it on.
Jan 26, 2011 | Panasonic SC-HT650 System
Inspiron 1000 will not power up. power ligth is on but does not go to next stage
check the laptop power ic power light is on then not come to dieslpy mis power ic problem .............ok change the powr ic
Apr 03, 2009 | Dell Inspiron 1000 Notebook
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
ICOM W2a Won't power up, after full charge with two different batteries
There's a comment on eham.net about charging the internal battery first.
Maybe this will help you.
http://www.eham.net/forums/ModsAndRepairs/1961
Jan 10, 2008 | ICOM Informatique BP-85S,...
F61 problem
DIsconnect sound Amplifier ic (RSN).After removal of the ic if the unit works o.k offcourse without sound than replace ic.If still f61 than sound ic is o.k and check voltege regulators in power supply.You can check dc detect line if it gets activated.
F61 is mainly two resons 1st sound ic or power supply problem in power bord which send signal to system control to shut down the power in order not to damege more.
Dec 13, 2007 | Technics SC-EH780 CD Shelf System
Televison & Video Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
