Question about Hyundai 01 02 03 04 05 06 Elantra Audio Equipment
Hand brake REAR BRAKES WILL NOT RELEASES .HAND BRAKE IS DOWN
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
Send me an e-mail and I will get one of my specialists to try advise you debbie@norbrake.co.za
Posted on Jun 24, 2014
Problems park brake stuck
check the rear end and check if the cable is broken/. frayed and jamming the brakes on . Check for rusted cables. If rear brakes are discs the check the brake action of the hand brake.
Jul 25, 2014 | 2005 GMC Canyon Extended
HAND BRAKE RELEASESD CAR WILLNOT MOVE
Release hand brake. Pull it again. While feeling for the normal tension have an assistant listen at the rear wheels to see if the brakes are moving and releasing when you release the hand brake. Possible causes:
-binding or stuck cable
-broken parking brake handle ratchet mechanism
-seized calipers, or if drum brakes faulty drum brake hardware/springs
May 11, 2014 | 2005 Hyundai Elantra
2001 cadillac sls parked on sloping driveway with emergency brake on. Emergency brake will not release when car turned on and put in gear. Will not release by pulling down on yellow brake release lever...
There is likely a siezed cable or caliper,possibly because the hand brake hasn't been used regularly.Jack up the rear of the car,see which wheel,or both are stuck.The cable(s) will then need to be cut close to the wheel,or possibly hammered back.
Sep 04, 2011 | 2001 Cadillac Sts
HANDBRAKE ON 2006 VW PASSAT WONT RELEASE
try pulling up and at the same time push the button
May 06, 2011 | Volkswagen New Passat Cars & Trucks
Where i can find the hand brake
There is no hand brake. It is foot operated. The pedal will be on the driver side kick panel, and the release handle is under the dash in the same area.
Feb 17, 2011 | 1998 Dodge Caravan
Rear brakes spoungy + rear tail light comes on for no reason
1/ How's the brake pads? High or low?
2/ How's brake pedal? In good shape and condition?
3/ How's brake switch conditions? Good?
4/ Sounds like there is air bubbles in brake system, get a friend if you never done any purging/bleeding brake lines before hand..
Find a small size clear air hose fit tightly over brake nipple on the caliper, tie it tight with twist-ties, stuck other end into a catcher or clean clear container, use a size 8 sock wrench loosen brake nipple slightly, pump the brake pedal until it can not be pressed anymore, keeping it pressed down, using your other hand release the nipple nut so brake fluid can flow out and into container, automatically your pedal will goes down and fluid will stop flowing then close nipple and repeat process until all fluid are flowing clear of bubbles. If brake fluid reservoir is low, keep topping-up with fresh brake fluid until you see a clear brake fluid flows out from the brake nipple. Once that happens, tighten the nipple and you should be in orime state to ride again. Good enough?
Apr 30, 2010 | 2008 Triumph America
I but a new handbrake cable on my 99 transit and shoes and the handbrake pulls up to far
Ensure parking brake is fully released.
Place transmission in Neutral.
Raise and support vehicle.
Tighten cable equalizer adjusting nut until rear wheel brake drag is felt when spinning rear wheel by hand.
Loosen cable equalizer adjusting nut until rear brakes are fully released.
Spin rear wheels and ensure there is no brake drag. Lower vehicle, and check parking brake operation
Mar 05, 2010 | 1999 Ford Taurus
Emergency break cable broke on 2004 silverado
I had the same problem on my 2003. Open the driver door all the way. Get on your knees just outside the door. Follow the plastic tub that holds the parking brake release cable inside the truck. Start from the release lever and follow to the end of the tube. There will be a metal lever that the cable was attached to before it broke. You have to pull that lever with your hand to release the parking brake. Very Important!!!...Hold the parking brake activation pedal with your other hand when you release the brake. Let the pedal out slowly when you pull the metal release lever. The pedal will come back very fast and you could injure yourself if you are not careful. Good luck!
Jul 27, 2009 | 2000 Chevrolet 3500
Mustang parking brake won't release tension on rear brakes
since the new pads are alot thicker than the old ones,the brake needs to be set properly.
something is not right for sure.
the retainer for the park brake cable may be not in the right spot.there is two places it can fit.
May 23, 2009 | 1998 Ford Mustang
Loose emergency brake on 2004 Saturn Vue
  1. Apply and fully release the park brake several times. Verify that the park brake lever releases completely.
  2. Turn ON the ignition. Verify the red BRAKE warning lamp is not illuminated.
  3. If the red BRAKE warning lamp is illuminated, verify the following:
    • The park brake lever is in the fully released position and against the stop.
    • There is no slack in the park brake cable.
  1. Turn OFF the ignition.
  2. Disable the SIR system.
  3. Remove the front floor console.
  4. With the park brake lever in the released position, using ONLY hand tools, loosen the adjusting nut completely to the end of the front cable threaded rod.
  5. Raise and support the vehicle.
  6. Remove the rear tire and wheel assemblies.
  7. Adjust the rear drum brakes.
  8. Ensure there is no brake shoe drag after adjustment by rotating the brake drums. If drag exists, re-center the brake shoes and perform the brake shoe adjustment again.
  9. Install 2 wheel nuts to the wheel studs and firmly hand tighten in order to retain the brake drums.
  10. Lower the vehicle to permit access to the park brake lever.
  11. Raise the park brake lever 1 detent position. Notice: Refer to Fastener Notice in Service Precautions.
Jan 14, 2009 | 2004 Saturn VUE
Hyundai 01 02 03 04 05 06 Elantra Audio Equipment Logo
42 people viewed this question
Top Hyundai Car Audio & Video Experts
Jude24
Are you a Hyundai Car Audio and Video Expert? Answer questions, earn points and help others
