Question about Exercise & Fitness
My healthrider crosswalk sl h50 will turn on but won't start
My HEALTHRIDER H95T treadmill is stuck in the fully elevated (level 12) angle on the platform and will not move
The incline motor is jammed due to a faulty incline sensor or incline motor assy. This is somewhat hazardous if you do not know what you are doing to remove the incline motor. Sometimes you can repair it most of the time you replace the incline motor assy. Must be calibrated upon completion.
Feb 22, 2015 | HEALTHRIDER H95T Treadmill
99 saturn sl won't start after turning off engine for few minutes
had u turn on similar problems with Honda crx replaced fuel pump relay turn on ignition but don't start car listen
Apr 18, 2013 | 1999 Saturn SL
Sony dsc-h50 camera won't show pictures in recovering data mode
Take out the SD card of your camera and put it into a card reader.
Then you can plug it into computer to recover yoru pictures.
For photo recovery software, here I recommend you this one, which I used and worked.
Tenorshare Photo Recovery for Windows
Tenorshare Photo Recovery for Mac
Jun 18, 2012 | Sony Cyber-shot DSC-H50 Digital Camera
Proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
1992 saturn sl engine won't turn over
Best case scenario: Your battery is dead or almost dead.Worst case: The engine has seized and you have to replace it. Do the dash and interior lights stay on or turn out when you try to start the car?
Apr 19, 2012 | 1992 Saturn SL
2002 saturn sl won't start, turn over but won't start
Done cars have a kill switch if they are low on oil. Check your oil. If the oil is good, it may be the ignition switch.
Jan 01, 2018 | 2002 Saturn Sl
Healthrider S500i HRTL12990 belt won't run
HI,
If you can then before replacing the Motor control board do one thing. Replace the IGBT on the control board. Igbt is the component which drive the motor. It will not cost a lot. The only thing is you should be very careful while working on the motor control board because there you can see two capacitors which is capable of store charge for a long period of time even the treadmill is unplugged. Before doing work on the control board you have to discharge the capacitor. If not it will lead to serious electric shock. You will get many pages on web to know how to discharge an electrolytic capacitor. I have add the picture of the motor control board with the igbt marked. You can find the part number written in its frond side. Replace the IGBT first.
Ajin
Jan 19, 2012 | HEALTHRIDER Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
