If it is the 1045 flagman, you need a replacement arm with the attached flag. disconnect the man from the metal base and open the figure with the screws on his back. Disconnect old arm or whats left of it and reverse the process to re assemble. If you do not have a 1045C contactor, one side of a 154C will work
If it is the 145 gateman the arm has a screw or drive pun into the man's shoulder. If you can get a seperate arm this is the way to go. if not parts dealers will have the complete man. Open the base undo the screw that holds the man to the arm remove damaged man, Reverse process to reassemble
From the Lionel User Guide for this engine.
it forward to release the two rear clips from the frame slots.
2. To remove the lamp, gently push the lamp down and turn counter clockwise to disengage
the lamp from the socket. Refer to Figure 6.
3. Replace the expired lamp with Lionel part no. 600-0363-300, available from your local
Lionel Authorized Service Center or Lionel Service. (For more information, see Lionel
Service on page 12.)
4. To reinstall the shell, first insert the rear tabs on the body into the slots on the frame. Line
up the screw holes on the frame and body shell, and reinsert the screw. Make sure all of the wires are inside the body before you tighten the screw.
This is a 14V bulb
This
