Question about Radio Communications
My rapoo h6060 bluetooth headset won't start. I've already recharge maybe because it is low battery but still it won't start. Please help.
RAPOO h6060 led is always red
Hi Bando
Just want to ask, have you accidentally dropped this head set? if not then lets make it this way.
Now the time that this headset still working or responding normally..
- the time that you use this headset what was the color of the led? is it red,green or blue?
- normally led red light indicates standby mode,
- how would you know that your headset is in fullcharge? is there an indicator?
Jan 27, 2014 | Rapoo BLUETOOTH STEREO HEADSET H6060 WHITE
Rapoo H6060 red light doesn't go off
DUDE THIS SAME THING IS HAPPENING WITH ME BUT I BOUGHT IT YESTERDAY AND TODAY NIGHT IT SHOWS RED LIGHT CONTINUOUSLY! PLISS HELLP MEE
May 23, 2013 | Universal Rapoo H6060 Bluetooth 2.1EDR...
Bluetooth conecton faild
You need a new one, the batteries only last a couple of years.
Apr 17, 2012 | Jabra BT3030 Bluetooth Headset
My plantronics 220 won't turn off. The blue light won't turn off and I can't get it on or off.
Try letting the battery go completely dead on the headset and then recharge it. This should fix the problem.
Here is the link for the Plantronics 220 User's Guide.
Good luck from Headsets Direct!
May 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics Explorer 220 no longer connects to Blackberry Curve
You can have the two devices connected, but still get your sound through the phone. During a call (maybe call your voicemail or an automated number, just to make a call) try holding down the answer/end button on the earpiece until it beeps, and see if the sound switches from the phone to the earpiece. You can also try pressing the speakerphone button on your phone during a call to switch the call to the earpiece.
Did either of those ideas work?
Jan 26, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Jabra BT350 Bluetooth Headset
This is what I did:
1. open the headset by following these steps:
http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
4. Reassemble and hope your headset is back to business.
May 10, 2008 | Jabra BT350 Bluetooth Headset Headset
I Also Got Bluetooth headset from a friend.
Changing the headset is not going to change the battery drain on the phone.
Aug 12, 2007 | Motorola Mobility H350 Wireless Headset
Radio Communications Logo
100 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
