Question about Samsung Ml-2160 Mono Laser Printer
What is wrong when my samsung ml2160 says it has a toner problem
FREE counter reset samsung ml2160
https://www.youtube.com/watch?v=HohOTLt2Tvk
Nov 05, 2017 | Samsung Office Equipment & Supplies
Installed toner cartridge samsung clx6200fx and it keeps saying install toner what is wrong
Did you get a Samsung toner cartridge or an off brand? Toner cartridges have small chips that tell the printer how much toner is left.. Not all of those chips will work correctly.
Mar 28, 2016 | Samsung CLX-6200FX Printer
My newly installed Samsung CLP-310 has a red light showing next to the <...> icon. Please could you help me to resolve the problem. Thx
Hi paulette,
if the light is red and TONER COLORS LED all LEDs off
• The machine is experiencing an error, such as jammed paper, open cover, empty paper, installed waste toner container, or full waste toner container.
• The machine is experiencing a service required error, such as LSU error, fuser error, or Contact your sales or service representative.
if the light is red and TONER COLORS LED each LED lights red.
• Each toner cartridge is totally exhausted. You can not print.
• Each toner cartridge is wrong.
Aug 01, 2011 | Samsung CLP 300 Laser Printer
My samsung 2150 duplex jam and always say invalid toner. but my toner still new
The printer is telling you it is the wrong toner not an old toner this is either because it is the wrong toner or a fault with the printer has caused it to think its the wrong toner, try taking out the toner and putting it back in again, then try replace the toner with a new one. if this doesn't work the printer is probably got a broken component.
Mar 10, 2011 | Samsung ML-2150 Laser Printer
My Samsung CLP 300 shows a red light. I've cleaned the toner tub and checked for paper jams, but still no results. How do you use the laser printer to check what's wrong? Any...
The red light stays on even in cases there's a paper size mismatch, and press the GO/START button usually helps. Also, it may be an indication that one of the toners is empty. See the level of the toner, the printer control program does this. If nothing seems to be wrong but you still have the red light on, unplug the power cord and plug it back in after a minute. Hopefully that may help.
Jan 18, 2011 | Samsung CLP 300 Laser Printer
I have had a SS Scx 4300 for 6 months with a starter catridge, it gave a message "replace toner" and I got it refilled. after that, it worked normally for some days, but now I can't use scaning and copying...
Starter carts aren't the same as the ones you buy to replace them and there is a module in Samsung machines to check the toners. The scanner error is something else, not related to the toners. With Samsung you get one year warranty, and should have it checked.
Aug 28, 2009 | Samsung SCX-4300 Monochrome Laser...
Wrong clp 510 toner
samsung clp 500 toner cartridge can not use samsung clp 510
bcase clp 500 is without chip and clp 510 chip base cartridge so never u can user.
Dec 27, 2008 | Samsung CLP-510 Laser Printer
Getting error message on samsung clp 510 printer
yes refilling will solve the problem.but you have to change the green colour small chip on the side of the toner to make it work,as the new chip will be detected as new toner in the printer.
Jul 28, 2008 | Samsung CLP-510 Laser Printer
Samsung Ml-2160 Mono Laser Printer Logo
54 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
