Question about Amana SXD524VW Side by Side Refrigerator
Amanna Refrigerator tubing leaking
Tubing on our Amanna side by side refrigerator leaking and is cracked.
Could we buy a kit and replace the entire tubing?
  • 351 Answers
Yes am not sure if lowes or your local hardware store may have it if not i can send it cheap if you give me a call... www.whirlpoolpartssurplus.com
Posted on Jun 23, 2009
GE profile side by side refrigerator leaking water from the bottom on the back right side at refrigerator tubing pressure connection. Model# PS123NGMD 88
Try tightening the brass fitting first. If that doesn't fix it, look at the tubing for the source of the leak. If there is enough tubing left after you cut past the leak then you can reuse the brass fitting and the tubing insert on the tubing. If not, then you'll need to get some tubing and a brass splice connector from your home improvement store to fix the problem.
Jan 03, 2015 | GE Refrigerators
Hotpoint refrigerator leaking water from hose underneath
It sounds like this may be coming from the icemaker water valve. If the refrigerator is an older one the tubing gets brittle and cracks. Check this first. But the water valve is usually on the left side in the back.
Apr 09, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a LSC27910ST side by side refrigerator that sprays out water from a tubing line on the back of the refrigerator when you are using the water dispenser and also the condenser fan isn't coming on
This tubing supplies the icemaker and cold water spout in the refrigerator. If you follow it back to its source (probably below the floor) you will find a shutoff valve. This valve usually is a screw-in with wings so that you can turn off with your fingers. Turn it clockwise until it stops. The water from behind the refigerator should have stopped. Now you need to determine if the nut clinching the tube to the fitting on the refrigerator is tight. This should be visible near the floor. If it moves easily, like with your fingers, this is the source of the leak and needs to be tightened with a small adjustable wrench or pliers. Then turn the water valve back on and verify it solved the leak. If the leak comes from the tubing itself, you will have to shorten the tubing to the leak or buy a hose to hose fitting if you have to keep the full length. The tubing will cut with a sharp knife, but make sure the valve is off before you try that.
Oct 07, 2013 | LG LSC27910 (265 cu ft) Side by Side...
Leaking water on floor
Look for:
(1) Condensate drip pan under the refrigerator (catches & evaporates water from defrost cycles) may be out of place or leaking.
(2) Drip Tray under water/ice dispenser may be overflowing (drain may be clogged, if so equipped).
(3) Leaking water supply line (to ice maker/water dispenser): Check:
(a) at inlet-valve fitting(s) and along all tubing going to ice maker & water dispenser,
(b) at water filter connections (check inlet & outlet fittings and any gaskets where filter is inserted,
>>> Tubing can develop a pinhole leak or crack if bent too sharply, pinched when unit is pushed back against a wall, contacting hot or vibrating parts (e.g. compressor or fan),
>>> If connections are the "push-on" style they can leak if the tubing is not cut off squarely - with no burrs, pinched, cracked or distorted ends (use a sharp knife or tubing cutter)
>>> If compression fittings are used with polyethylene tubing a ferrule must be inserted into the tubing end to prevent the tubing from distorting as the nut is tightened; also over-tightening nuts or reusing old compression rings under the nuts may cause leaks.
* Remember to vacuum out the dust bunnies from the fan, condenser coils and all air vents while you're poking around under the fridge!
Nov 19, 2012 | Samsung RM255LASH Side by Side...
GE Profile Arctica refrigerator - water is leaking from the bottom of the solenoid where the plastic hose goes up to the water filter (on the outside of the refrigerator.
Turn off the water supply and check for cracked or broken water tubing/line. Make certain that there is teflon (white) tape on threads connecting water inlet hose from shut off valve at wall to water valve at refrigerator. If there is no apparent damage to tubing or hose, then your problem may be with a water valve solenoid that is not seating/closing tightly. Replace the water valve assembly, if necessary.
Note: If plastic tubing is damaged, etc., you can splice the tubing with a "coupler" and/or more tubing purchased from Home Depot or Lowe's.
Feb 19, 2010 | GE Profile Arctica 25.4 Cubic Feet...
The tubing for my Amana SRD25S5L is brittle and breaking. Where can I find replacement tubing or repair kit?
If you're refering to the ice maker supply tubing, you can get ice maker hookup kits with the proper tubing and ferules at a local hardware or plumbing supply house.
Save your fittings as you pull them off to reuse what you can, you may need to replace the compression ferules on the plastic line under the compression nuts.
Be sure to pressure check for leaks before moving the refer back into position.
Jul 13, 2009 | Amana SXD524VW Side by Side Refrigerator
Amana SZD27MPW refrigerator water reservoir replacement
The watedr reservoir ha a crack. what do I need to do to repair. Do I need to replace it? Please let me know. GE Refregerator Models 20-27
Mar 25, 2009 | Refrigerators
Pin hole in 1/4" copper tubing feeding refrigerator
Never run plastic tubing through a wall! If copper is already there, then leave it, and solder the pinhole leak back up.
If the leak is outside of the wall, then cut off the tubing that includes the pinhole, and buy a brass ferrule coupling for 1/4 inch copper to copper. Make sure that it includes a brass barrel (it may come with 2, one for each side. If not, they are sold separately as well.). Install the coupling with ferrule into one side of the coupling.
Push the barrel into the plastic tubing, and install with ferrule just like you installed the copper tubing.
Sometimes you can get a plastic ferrule for the plastic line side of the coupling.
Feb 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Leaking icemaker
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
Oct 29, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Amana SXD524VW Side by Side Refrigerator Logo
219 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
