Question about WeatherWorks CH-V18 Floor / Box Fan
Where can I purchase a fan switch for weather works CH-V18 ?
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 69 Answers
How much do you know about wiring? I cannot locate a manual for this fan. It is a Chinese made 3 speed fan with a sparate speed control box. From pictures, the speed switch appears to be a rotary style switch which can be purchased from local hardware stores or on-line (Digikey). Pull the old switch out and search for a replacement. The import criteria is: voltage rating, amp rating, number of positions (speeds), knob shaft diameter and type.
Posted on May 30, 2014
Hi I keep getting a ch 67 after the unit starts fine and runs for like five minutes fan on all units work during that five minutes any thoughts would be greatly appreciated
Low freon pressure switch is turning it off. As the coils cool down the pressure drops. As time goes on it will run shorter and shorter cycles. In warm weather freon 22 low pressure should be near 70 lb
410A freon about 150 on the low side
May 02, 2015 | Heating & Cooling
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
Whare can i purchased a lid for my crock pot a 7quart, weather works model ch-9350???
Do a google search for your make and model and replacement lid, and you should get several results.
Nov 25, 2014 | Crock Pots & Slow Cookers
Fan and Light will not work in cold weather (under 45 degrees or so)
Cold weather may be making the lubricant too thick and impeding the motor from turning. On a cold day see how easy it is to spin the fan.
It could also be the switch is worn to the point that the cold weather causes the metal to contract then it does not have enough strength to snap into the closed position. Cold weather can also cause failures in electronic circuits or even a wire connection that is not quite tight enough.
Nov 17, 2013 | Minka Aire Ceiling Fan
Blower relay
This sounds like it's your radiator fan or engine bay fan continuing to run due to the hotter weather we are having. Some fans are programmed to cool the engine bay area if their thermostat triggers them. These conditions usually happen when weather becomes very hot and triggers the system to continue the fan due to excessive heat in the engine compartment. Usually not a bad thing and should stop when weather cools down. What is worse is if the fan doesn't work. Keep an eye on it and see if it continues to do this when weather cools down.
Aug 24, 2013 | Mitsubishi Cars & Trucks
Time is correct but date and day is not. How can I set the correct date?
Press the SET button until the month if flashing. Then press the CH button until the correct month is showing. Press SET again so that the day is flashing. Press CH button until correct day is showing. Press SET so that the year is flashing. Press CH button until correct year is showing. Press SET until nothing is flashing. You should be done.
Jan 18, 2011 | La Crosse Technology Technology Weather...
I need a replacement cover for a Weather Works CH-9550(YD-4500)
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Dec 21, 2008 | WeatherWorks CH-9350 Slow Cooker
Opening fan
first open your cpu cover carefully ,by opening the screws once your cpu cover is opened then carefully remove the wire of the fan connected to the motherboad then open the screws of the fan and clean it then do the same just connect your fan to the motherboad and screw it up and its over make sure that your fan is working and its over
Nov 10, 2007 | WeatherWorks CH-V18 Floor / Box Fan
WeatherWorks CH-V18 Floor / Box Fan Logo
125 people viewed this question
Top WeatherWorks Dryers Experts
Are you a WeatherWorks Dryer Expert? Answer questions, earn points and help others
