Question about Sony VAIO VGN-BX561B PC Notebook
HOW IS THE DIP SWITCH SETTING? - Sony VAIO VGN-BX561B PC Notebook
    Sergeant:
    Champion:
  • 218 Answers
Should be 1-3 on and 4 off I believe
Posted on May 11, 2014
With me problem on konica minolta 7235 show error code f35-8
1. Turn OFF the SW2 (sub power).
2. While pressing the copy quantity setting button 2
and 5, turn ON the SW2 (sub power).
3. [Software DIP SW setting screen]
Select a DIP switch number.
Use the or key or numeric
keys.
To use numeric keys, press the DIP
switch number key at the left before
entering a DIP switch number.
select Dip 3 1 to 0 from 3 1 1
Mar 22, 2016 | Konica Minolta Office Equipment & Supplies
How to reset fuser error konica 7030
In your case the soft switch will be 3-1-1 changing last bit to 0. if the code comes back do not reset as this code deals with the fuser it can catch on fire and that will ruin a perfectly good day.
Setting Software DIP SW1. Setting method
This setting specifies the software DIP switch on the software SW setting screen. (*1)Caution 1: The bit of the DIP switch is written in
the non-volatile memory every time it is
changed.
Caution 2: The numbers shown in the message
area are defined as follows:
Software SW 8-bit switch values in indicated in hexadecimals from 00 to FF.
Example: 04-7 : 1 A8
Bit data
1 : ON
0 : OFF
Bit number (0 to 7)
Switch number
2. Setting proceduresStep1
Operation procedure
Enter the 25 Mode.[25 mode menu screen] Hold Down the 25 and power on.
Press the [1. Software SW] key.[Software SW setting screen]Select DIP switch number.Use the left [  ] , [ ] key.
Select bit number of the DIP switch.Use the center [  ] , [ ] key.
Select ON (=1) or OFF (=0) of the DIP switch.
Use [ON] or [OFF] key.
[ON] : Set bit.
[OFF] : Clear bit.
Press the [Return] key to return to the 25 mode
menu screen.For each switch function, refer to "List of Software DIP switches".
25
May 24, 2014 | Konica Minolta Bizhub C300 All-In-One...
Dip switch setting
Can you please provide more specifics about the dip switch setting errors? Is it not functioning or functioning improperly?
Sep 14, 2012 | Pelco Spectra IV DD423
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
Dip switch setting for my fan
It does not matter what the dip setting is as long as they are the same on the remote and the receiver. If you do not know the setting you will have to remove the fan mounting cover and pull the receiver out. Open the receiver and see what the dip setting is. Then set the remote to the same setting.
Aug 12, 2009 | Hunter 27185 Remote Control
I don't know the dip switch setting for my fan
Most controls only have 4 dip switches. That makes 16 possible settings. If you try each setting it will take you less than 5 min.
Cannot set remote code for fan/light(dip switch)
The remote dip switch setting must match the fan receiver dip switches. Set them both to 2 on
Jul 04, 2009 | Hampton Bay 52 In. White Redington...
No dip switch in Hunter 27157 remote control.
Those aren't transistors in the transmitter they are jumpers. Match the jumper settings with your dip switch settings in the receiver. You can move the jumpers in the transmitter using a small needle nose pliers. An open jumper in the transmitter equals an OFF setting on the dip switch in the receiver.
Jun 24, 2009 | Hunter 27185 Remote Control
Kenwood Power Supply Dip Switch Setting
why don't you get a controller for that supply? I got one...
John
Jul 08, 2008 | Kenwood (PDS36-20) Power Supply
Vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
Nov 22, 2007 | Canopus ADVC-110 A/D Converter...
Sony VAIO VGN-BX561B PC Notebook Logo
53 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
