Question about KitchenAid KUDD01DSSS Architect Series Double Drawer Dishwasher, Less than 24 in, 5 Cycle Selections with 3 Cycle Options, Sani Rinse Option, Whisper Quiet Ultima Sound Insulation System, Sure-Hold Light Item Clips, Rinse-Aid Dispenser, Electronic Controls with
Empty cycle stays on on both drwewrs . Will not shut off till I press off button. When I turn back on just get red light and cycle runs on both drwers
Empty cycle stays on on both drawers
2 Suggested Answers
SOURCE: Dishwasher will not run on any setting, lights
Called land lord this morning, says its still under warantee, so I guess that fixes that. Thank You
Posted on Aug 01, 2009
How to reprogram my parker tv remote
HOW TO PROGRAM Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on then take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinks off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
Dec 30, 2014 | Televison & Video
Braun 8995 - YELLOW LIGHT STAYS ON!
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
Jan 06, 2013 | Braun 8995 Electric Shaver
What are the codes to the remot
1. turn on device
2. press setup (underneath on/off) till red light stays on the take finger off the button
3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once
Dec 19, 2010 | GE JASRM24912 Remote Control
How do i program my ge remote to my sanyo tv
1. turn on device
Sep 14, 2010 | GE JASRM24912 Remote Control
What does it mean when the green LED light and the alarm light are both permanently on at the same time. There is a full tank of water, service door has been opened and shut and the dreg drawer is empty...
Hi, Turn off the machine and turn back on again. If both lights are permanently on that means you need to empty the dreg tray. Pull out the tray and wait until the red light start flashing, then put back the tray, the red light will go off.
Another meaning is when you press the coffee button and see the red light came on, that means the grinder motor is not working. Hope it will help.
Sep 06, 2010 | Saeco Odea Giro Espresso Maker -...
Alarm red light stays on after you shut the car off 1998chrysler
I would turn the key on without starting the car then press and hold the black button till the alarm light flashes.Then turn key off take out of car and try the fob again.
Mar 29, 2009 | 1998 Chrysler Cirrus
I need the code to my remote
per manualsonline.com,
"1. turn on device 2. press setup (underneath on/off on remote) till red light stays on the take finger off the button 3. press and quickly release device button (tv, vcr,etc.) the red indicator blinks off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code"
Feb 06, 2009 | GE JASRM24912 Remote Control
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
KitchenAid KUDD01DSSS Architect Series Double Drawer Dishwasher, Less than 24 in, 5 Cycle Selections with 3 Cycle Options, Sani Rinse Option, Whisper Quiet Ultima Sound Insulation System, Sure-Hold Light Item Clips, Rinse-Aid Dispenser, Electronic Controls with Logo
14 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
