Question about Flojet Triplex Water Pump - 03526-144A
Our house pump system shut down... checked fuses, lever on the pressure box will go up and make sound, then will go off and won't give you a 'sound again for a few minutes... almost like recharging.
Every time we turned on the water for a while the pipes would 'groan'... not sure if that means anything\
  • Joel Friedenberg May 12, 2014
    Hi Shay Tunis, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?What does your water system consist of: what pump do you have? Do you have a pressure tank?
2003. Where is fuel pump reset switch?
Sorry ,dodge doesn't have one ! No fuel pressure ? Can you hear the fuel pump run ? , check the ASD relay in under hood fuse / relay box . ASD - auto shut down relay supply's power to fuel pump relay an to ignition system an O2 heaters .
Oct 31, 2015 | Dodge Grand Caravan Cars & Trucks
Our auto irrigation system wouldn't turn off. We found the Davey XJ70 pressure pump was leaking so replaced the leaking pipe. Now the watering g system won't start. What do we do?
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
Mar 31, 2013 | Plumbing
My hhr will not turn off, where is the battery so i can disconnect it
Unplugging the battery won't shut it down I don't think.
Get into your fuse box under the dash or in the engine compartment and pull the fuse for the fuel pump.
Jul 02, 2011 | 2009 Chevrolet HHR
Will start if i put gas down the port/carb seems to have fuel press at test port,,changed the rotor/dist. cap,don,t allway have fuel press may be the knock sensor ?shutting it down. it was hard startind...
sounds like fuel pump relay. next time it want start pull the ecm bat fuse for a few seconds see if it will crank then. knock sensor will not cause this. ecm bat fuse it works the fuel pump relay,fuel pump,injectors,ignition system an the pcm. also the oil pressure switch will shut down the fuel pump if oil pressure drops below recommended pressure . check the connectors on these things that not loose or corrioded.i think you will find the fuel pump relay is what this relay is the problem. this relay maybe in dash or under hood in the relay box.
Dec 11, 2010 | 1997 Chevrolet S-10 Pickup
1991 320i wont idle unless you put fuel direct into manifold
SOUND LIKE FUEL PUMP NOT RUNNING.CHECK FUEL PUMP FUSE AND RELAY IN FUSE BOX UNDER THE HOOD LEFT SIDE OF THE UPPER STRUT HOUSING OR NEAR THE BATTERY..IF FUSE AND RELAY IS GOOD.FUEL PUMP FAULTY.YOUR FUEL PRESSURE IS SUPPOSE TO BE 64 - 74 PSI.IF FUEL PRESSURE IS STILL LOW REPLACE FUEL FILTER FIRST.IF FUEL PRESSURE STILL LOW FUEL PUMP IS FAULTY.
Jun 27, 2010 | 1997 BMW 318
I started my 1999 Bonneville this morning and it shut down
Make shure both battery cables are tight especialy the pos side since there are 2 cables with a washer between the cables. they come loose all the time.
Feb 25, 2010 | 1999 Pontiac Bonneville
95 cherokee sport 4.0L 6cyl. driving down the road after awhile the jeep will ****, skip, hesitate, and then shut off for a few min. i hear clicking noises in the fuse box on passenger fender with the key...
Sounds more like a fuel pump problem ,but iam often wrong,on the older models i have found the rubber connecting hose inside the tank that connects the pump to the outlet on the fuel gauge unit perishes and the fuel pressure drops giving the symptoms you describe
Oct 17, 2009 | 1995 Jeep Cherokee
2001 f350 diesel craks but wont start
SOUND LIKE THE ELECTRIC LOW PRESSURE FUEL PUMP CHECK FUSE TO SEE IF PUMP GETTING POWER. IF NOT REPLACE FUSE AND CHECK THE WIRE TO PUMP.IF PUMP IS GETTING POWER..REPLACE FUEL FILTER FIRST.IF IT DONT HELP.COULD BE THE ELECTRIC LOW PRESSURE PUMP. FAULTY. IT PUMPS DIESEL FUEL IT INTO INJECTION PUMP TO BE PRESSURIZED TIMED AND INJECT.SEE IF LOW PRESSURE PUMP DONT WORK THE WHOLE ENGINE WONT RUN.THE INJECTION PUMP NEED FUEL FROM LOW PRESSURE ELECTRIC PUMP TO RUN ENGINE.
Aug 11, 2009 | 2001 Ford F350 Super Duty SuperCab
Getting fuel, won' start
hello,ok your fuel pump is working,hoping fuel pressure is also good,how about your ignition system,try to start your engine,then remove your spare plug,determine the condition, have fuel in plug?if yes try to check your ignition side,first check your excees voltage protection,located in fuse box(with aluminuim housing with fuse on top) ,,ty
Apr 29, 2009 | 1993 Mercedes-Benz 190
Flojet Triplex Water Pump - 03526-144A Logo
Top Flojet Plumbing Experts
Andrew Taylor
Andrew Taylor
richie46
Bill Boyd
Are you a Flojet Plumbing Expert? Answer questions, earn points and help others
