How do I get rid of awful smell in my hotpoint Aquarius WDL540?
I have cleaned the drum and the rubbers in the machine and tried a washing machine cleaning powder all with no luck. Any help gratefully received! Lauren, Cumbria
SearsTechToo
  • 261 Answers
SOURCE: strong mold smell inside washer
Powder is tuff on a front loader, liquid is the way to go. One solution is to use a ratio of 2 Tbls of soap to 1 Tbls of softener as this machine uses 70% less water and this makes the solution of soap much stronger causing a build in the back bottom of the tub. Every one I have rebuilt has had to be scrapped out because of excess soap, liquid or powder. This stuff turns black and is awful. I usually use washer magic only and knowing that one use will not remove even 3 years of build up but is a process of reversing the junk. So I will by one from Walmart for about 4 bucks and pour the contents into the machine will empty of clothes and water and let it sit over night to start breaking the stuff down, then in the morning I will run hot water in the closet sink to the machine so when I start the cycle the water is hot. So after soaking you want hot water with a heavy agitation plus a second rinse and that will remove half of the junk. I usually do this every month on my top loader because of hard water and my clothes do smell much better for it
Posted on Sep 20, 2008
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
beltronic205
  • 1474 Answers
SOURCE: i bought a hotpoint aquarius wdl540 with no
try downloading on hotpont website
Posted on Oct 31, 2009
  • 57 Answers
SOURCE: how do i remove and replace rubber seal on door of
Remove the lid and loosen the band internally holding gasket to tub, from the top. The front come off easily once the retaining band is removed. Just reversed the process to put on the new rubber.
Posted on Dec 09, 2009
SOURCE: control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Posted on Feb 16, 2010
Instruction manual for hotpoint aquarius WDL540 7kg Washer/dryer
My washing machine's indicator flashing after 5 minutes,what should i do?
May 13, 2012 | Washing Machines
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Horible smell comingfromthe drum, took the filter out to clean it, now it is leaking, what can I do? ps smell still there, have tried 1 95o wash with no joy
For the pump try taking filter back out and putting back again for smell clean out the rubber door seal with soapy water after the door seal is clean clean the despencer draw fully by taking it out. When you washed the seal and draw get washing machine clean for local super market and do a 95oc wash it should smell nice now if not could be drains hope this helps.
Jul 29, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Hi, the machine/drum area keeps smelling of stagnant water, no matter how many times i clean it. Is there anything i can do to stop this?
Things to do make sure despencer draw is clean and the rubber door seal is clean do a maintenance cycle every year this is the hottest wash cycle with cleaning detergent. also leaving the door open after cycle will help hope this helps
Jul 10, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Does the hotpoint auarius have a filter that needs cleaning over the past two weeks or so the machine has started to smell the drum and soap drawer are both spotless
It does, but our loving friends at Hotpoint put the filter UNDER the drum and it can only be got to by drgging the machine out and attaching from the rear. The filter is the size of a large coffee mug, covered in rubber, directly below the cetrre of the drum and held in place by a large jubilee clip. Remove the clip, pull off the rubber boot and inside is a white conical "pot" with a ping pong ball in it. HOWEVER. Before you do this, if you are getting smells, first take 3 DISHWASHER tablets, throw them in an empty washer and put it on the hottest whites cotton program you can. Modern biological powders use bacteria to "eat" stains and when they get trapped in the machine, they can smell. Dishwasher tablets are made to wash and to KILL bacteria. It may help. Its a good thing to do anyway every now and again and it may save you a fruitless job dragging the machine out for no reason.
Jun 04, 2010 | Hotpoint Aquarius WF220 Front Load Washer
I have an extremely unpleasant smell coming from the drum-i have run several empty washes at 95 degrees with both washing liquid and machine refresher but no luck!
Sounds like dirt in drum, Can be quite hard to get rid of however there are some cleaners for the job. try espares.com, and make sure your sink drain is clean too...Good luck
Sep 29, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius wf440 : my washing 'smells' after a wash so think filter needs changed/cleaned; where is it located, have lost my manual?
if i were you i would buy some detergent that cleans washers in the normal wash cycle without no clothes in it then you will find that the smell as gone,do this regular once a month to keep all the pipes fresh.rgrds,paul
Jul 07, 2009 | Hotpoint Aquarius WD63 Front Load...
WF740 Hotpoint washing machine with bad smell from drum. Tried 95 degree wash but still smells. Door seal slightly blackened but I think smell is from drum too. Any help?
Wash it out with a strong solution of washing soda placed into the drum before you fill the machine
Ps
Run the machine empty through a full hot cycle then run the soda one
The first will soften the deposits and the second should help kill the bacteria that is causing the smell.
Reducing the load so that there is more agitation helps as well
Jul 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
