Question about Garden
How do i replace the pull rope on my stihl fs40c weedeater
  • 27 Answers
SOURCE: broken pull cord
ur going to have to unmount the the motor from the shaft
step 1. Unbolt throttle housing
step 2. now with that out of the way u should see a clamp holding the motor to the shaft, loosen and pull the shaft out, there will be a cable, so make sure u have it lined up so it goes back into place
step 3, look at the back of the motor, u should see screws going into the plastic housing (coming in from back going into plastic)
step 4. once that is off pull the broken part of the cord out
step 5. wind up the starter coil, (it will only wind up one way) its spring loaded so be carful, once it stops back it off 1 full turn
step 6. u will see a hole for the cord in the housing and in the coil, make sure they are lined up
step 7. insert the cord through both holes, tie it as tighttttt as possible, then let the spring do the rest
step 8. put it back together
Posted on May 31, 2009
canbruce75
  • 1776 Answers
SOURCE: starts then dies stihl fs45/weedeater
I sounds like it sucked up some debris in the bottom of the fuel tank and obstructed fuel flow somewhere. Start by blowing out the in-tank fuel filter (You will have to fish it out with something), then load the line with carb cleaner (wear safety glasses) put fuel filter back in line and crank it a few times to pull the carb cleaner into the carb. This may dislodge the obstruction. If this doesn't work, you will have to remove and cleant he carburator. Hope this helps.
Posted on Jul 05, 2009
lemmingleejn
  • 173 Answers
SOURCE: Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Posted on Jul 25, 2009
moretons
  • 155 Answers
SOURCE: no power fs66 stihl weedeater
Hi When you cleaned the muffler out did you also clean the carbon out of the port on the cylinder as this can be blocked as well. Also you will have to retune the carby, There should be 2 screws 1 for low speed marked l on the carby body and 1 marked h for high speed to start with they should be set at 1 & 1/2 turns out from closed the low speed you set at an idle and the high speed you set at full throttle. Hope this helps.
Posted on Aug 04, 2009
  • 279 Answers
SOURCE: pull rope does not return
Unless the rope has broken, you dont need to replace it. The problem is probably the rewind spring. It is located under the starter pulley (the one the rope is in). The best thing to do is pull the unit apart and see if you can see if maybe there is something holding the rope up. The spring is a little dangerous to replace. If you go for it, be careful....Lee
Posted on Sep 04, 2009
How do I cure kickback when starting a Stihl 044 chain saw , as soon as you pull the starter cord it snatches it out of your hand it really hurts.
pull rope just pass compression piston top dead center release rope let it rewind fully .then pull rope quick and firm.
Oct 10, 2017 | Stihl Garden
Working on fs40c Stihl trimmer , when head engages it tightens to a no spin or over heats head . Thank you
It seems like it needs to be removed and cleaned of debris and maybe oiled or greased a bit. It is definitely tight to the point of heating up.
Jul 08, 2017 | Stihl Garden
Sometimes when I try to pull start my Stihl FS 36 weedeater it just free wheels and other times it will start. What could be causing this?
The mechanism is beginning to wear out. When you pull on the rope, the turning action pushes pins out from the center of the rope pulley that engage to turn the engine. These pins wear out and will eventually fail, not engaging at all. These pins may or may not be available for purchase at the small engine parts store near you, but the entire pulley assembly with new pins usually is.
Jul 04, 2017 | Cars & Trucks
How do I replace a drive cable shaft on a Stihl Model FS40c string trimmer.
I have added the illustrated parts manual which shows you the strip down of your machine. If you find this useful please click the 'helpfull' tab. Thank you.
http://www.mediafire.com/download/ksp9roxluyjtgz6
May 14, 2016 | Stihl Garden
Stihl weedeater pull rope won't pull out how do i fix fs75
Check first for pull rope issue by pulling the side cover and inspecting. If not that it may be something more serious like seized piston.
Aug 30, 2014 | Stihl Fs75/fs80r/fs85r Air Filter Housing
Stihl fs 86
I am a Stihl mechanic. We tell all our customers that the proper starting procedure for a Stihl is as follows. Turn on the switch. Set the choke lever to full choke. Prime the primer bulb three times(if it has one) and pull the pull rope NO MORE THAN THREE TIMES with the choke on. If the unit has not tried to start after the third pull, open the choke lever and pull till it starts. Sthil carburetors are notorious for flooding after pulling the rope more than three times on choke.
Thanks;
George
Oct 08, 2013 | Garden
Weedeater Troybuilt TB65SS : the pull rope is good. But the rope won't engage flywheel
Did you replace the rope? how much rope was used? and was the flywheel and rope clutch alligned properly on installation?
Jun 25, 2012 | Garden
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
Pull rope does not return
Sep 03, 2009 | Garden
Garden Logo
375 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
