Question about Kenmore Refrigerators
Problem: kenmore model 106.54609300 fridge will not hold temperature
Kenmore model 106.54609300 fridge will not hold temperature
3 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: kenmore fridge not holding the temperature
hi thanks for the question yes it is the thermostat go and buy one they will give you instructions on how to install if not come back here and we will help thanks the appliance doc
Posted on Sep 27, 2008
Sea Breeze
  • 4654 Answers
SOURCE: kenmore model 596.72253201. Bottom freezer works, fridge does not
The most likely reason is part number 12566102 Adaptive Defrost control board. The next likely are the defrost heater and the defrost thermostat,Sea Breeze I will send you photos. below
Posted on Sep 11, 2009
My kenmore coldspot mode 106.53394300 is freezing items in the fridge
If further adjustments cannot be made to the thermostat, the next step would be to replace the thermostat or if so equipped, the temperature thermistor.
Jan 30, 2015 | Kenmore Refrigerators
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
I have a Kenmore 14 Frostless that will not turn on period. I have plugged in it, and the light will turn on, but the freezer will not freeze anything nor will it even get cold. The temperature is on the...
There is a starter relay located on the compressor itself (inside the little black box on
the side of the compressor) in back. You will need the model and serial number of the
fridge to get the exact replacement. The model and serial are inside the fridge
on the left side of the fresh food compartment. This is a common failure.
They make a universal replacement also if this part is no longer available
but it is about the size of a red bull can and
requires a couple of wire ties to hold it in place to the chassis.
I hope this helps.
Mar 06, 2011 | Kenmore Refrigerators
Hi, Please tell me how to change the temperature on my elite kenmore.
Klay421 --
Which model Kenmore Elite refrigerator do you have? If you have one of the older manual models, the thermostat is located inside the fridge side. If you have a newer model with digital controls you need to press and hold the the ON/OFF button for 2 seconds until the digital displays for temperature for the Freezer and Refrigerator lights. The Up/Down arrows allows you to adjust the temperature. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Kenmore Refrigerators
Model#25360722000 is this a freezer or fridge? kenmore
What is it? A single door or a double door unit. If a single door, what temperature does it go down to? lower than 0 deg. c or +/- 3 to 5 deg. c In other words, lower than o it is a freezer. Above 1, it is a fridge..
Jun 03, 2010 | Kenmore Freezers
Kenmore model 596.72253201. Bottom freezer works, fridge does not
Sep 10, 2009 | Kenmore Refrigerators
Kenmore 106.63854302 Coldspot is not holding temperatures
Hi i had the same problem and someone came in it was well worth it it was the relay button and it only cost $50.00 for the part .
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore fridge not holding the temperature
Sep 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
48 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
