Where can i be shoawn to connect with car battery for home use nh3t w56
Imean ido not know the speakers wire battery positive
etirbynnor
  • 655 Answers
SOURCE: How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
Posted on Jun 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: I need to probe my VM9512 with one battery car
The battery needs to be sufficiently charged to at least 8V to power on the radio.
Check the battery is fully charged.
A better option is to wire it directly to a battery charger + and -.
But you have the setup correct.
Yellow and red to + and Black to - in order to bench test it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 02, 2009
SOURCE: need hdd nh3t-w55 menual
Has any one got a copy of the NH3T-W55 english manual. I appreciate your kind assistance.
Regards LeDerek@yahoo.com
Posted on Jan 25, 2010
  • 14 Answers
SOURCE: A friend recently gave me
One thing to remember about most radios, the RCA pre amp circuit will still work even if the mosfet power amp inside the radio does not. The best way to know if the amp inside the radio works is to use one matching color pair coming off the radio to wire up a random speaker right to the radio. You can use just about any old random 4 ohm speaker that is laying around to check it. The best solution if the amp inside the radio is blown is to replace the radio or amp the pre amp outputs with a small 4 channel amp. Oh, by the way. What vehicle are you connecting this into? And does the vehicle say Bose, Infinity, or ect sound or Premium sound? These usually denote a factory amplifyer already onboard and requires special connections to get the signal to these amps to then be delivered to the speakers.
Posted on Sep 12, 2011
  • 206 Answers
SOURCE: Need to know where the positive wires that connect to the battery of a '95 Toyota previa connect.
Hi
The black wire will be connected to the body or engine of the van and the red or positive wire is connected to your starter motor.
You can also use a 12 volt battery light to check the negative or positive wires.
You take the 12 volt battery light and place the negative black wire clip to an earth on the vehicle, then when you touch the tip of the 12 volt battery light onto a positive wire the light will light up.
Then you will know which wires are negative or positive sometimes the key has to be on for some wires to work.
Cheers
Posted on Nov 28, 2012
My hdd nh3t-w56 car radio is not working it says it cannot read the program please consult a dealer
Could be a faulty disc that refused to load a necessary program so the unit can work after a full reboot. The original disc is still fine to run the map and guide to the destination but was not able to upload the program that got deleted after disconnecting thebattery. All I needed was a new disc which I got from ebay
Apr 05, 2016 | Cars & Trucks
How do i download cd disc for nh3t-w56
never knew you could download the disk perhaps order one
Feb 19, 2015 | Toyota Cars & Trucks
How to find rear speaker wire on nddn w56 dvd player?
well, if you look at the rear speaker and write down the colors
that be it.
or login to alldata.com click auto/radio/sound.
Apr 30, 2014 | 2007 Toyota Yaris
RR= Red (+) Signals when played.
RR= W-B (-)
RL= Y (+) Signals when played.
RL= W-B (-)
Confirm the connections, because Toyota Yaris comes with and without integrated panels.
More clarification on the original question sub connection have no markings as + or - red or black nothing need to know which is what on these 12 dvc visonik subs if you put upside down which side is +...
To be absolutely sure of which terminal is positive and which is negative, we will use a 1.5 v battery to have the speaker react as though it is playing music.
* special note * do not use any more than 1.5 v as it may damage the speaker coil
As we know, batteries are marked positive, negative, or both ... we will use this to our advantage when hooking up the battery to our speaker.
To start the process, temporarily attach a short piece of wire to each terminal of the speaker (be sure to either use wire that is marked, or wire of differing colours to help determine which terminal is which).
In our example, we used standard speaker wire which is "polarized" (one wire is made of copper and the other is made from tin .. interestingly, this serves no electrical purpose)
Once you have connected the wire to your speaker, proceed to briefly touch the free ends of the wire to the battery terminals (as shown below). In some cases, extended contact with the battery has caused cancer of the voice coil (ie. blown speaker)
If the speaker moves OUT when the battery is first connected, the battery is connected in proper alignment. Be sure to take note of which wire is connected to the positive terminal of the battery as this is your speaker's positive terminal.
Aug 08, 2012 | Visonik Car Audio & Video
Need 2 know if head units rear and door mount speakers is wires with black line on em r negative or positive
normally negative. You can check by cutting the wires leaving them connected to the speaker and touching the wires to a nine volt battery. if you connect the negative terminal of the battery to the black/stripe wire and the positive to the other wire the speaker will either push out or pull in. if it pushes out then the battery will tell you the positive wire. if it pulls in the polarity is reversed and you need to reverse the wires. do not send the battery voltage back up to the headunit you will blow a channel in the radio.
Jun 30, 2012 | Kenwood KDC-MP228 CD Player
My toyota vitzs 2007 modal came with NDDN w56 multi av station i fixed a rear view camera by connect the vedio yellow cable and power to the reverse gear light but when put reverse gear no no display .any...
you don't need any settings actually it works with a three wire camera because the camera operates on 7volts and is powdered by the system, no need to connect it with the reverse switch, its already wired to the system, just connect the camera and will work.
May 12, 2011 | Car Audio & Video
The radio in my jeep isn't connected right. Some of the wires have come apart. i bought new **** connectors but how do i know which wires go together?
1994 Jeep Grand Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Green/Red
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
Thank you for using Fixya and good luck
Mar 22, 2010 | 1994 Jeep Grand Cherokee
Need hdd nh3t-w55 menual
Jul 27, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
