Question about KitchenAid KEHU309 Stainless Steel Dual Double Oven
Kitchenaid model kehu309 oven fan vibrates - KitchenAid KEHU309 Stainless Steel Dual Double Oven
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Replace fan
Posted on May 11, 2014
Ykemc308kmo oven fan noise
You are probably correct the cooling fan can wear out. You will have to order it by model number. They are a bit tricky to install depending on the oven, but not hard once you get to the fan area. Somke are behing the cabinet and you will have to puul the oven out and some are in the control panel area.
Nov 26, 2013 | KitchenAid "KEBS208sss Electric Double...
I dont know how to use the oven properly. when i need to bake or roast something i want to put in my own temperature, but there is no option for me to do that. when i turn on the stove all i have is the...
There should be a plus/minus sign OR a up/down arrow to adjust the temp.on the control/touch panel. The default setting is usually 350 and can adjusted up or down accordingly,the display starts at 120 and is supposed to rise as temp. increases.
The bigger issue though is to have it serviced and see why it doesnt rise above 200
Gene
Aug 04, 2011 | KitchenAid KEHU309 Stainless Steel Dual...
Used self cleaner on my Kitchenaid oven and now oven doesnt work.... not the household fuse any suggestions
Is it a fan forced oven? Does the fan and the light come on when you turn it on but no heat?
Feb 06, 2011 | KitchenAid Ovens
My Candy TC21 oven makes a vibrating noise when on, why is that?
There are only 2 moving parts in your oven when it is running - the fan and the fan motor. If a bearing is worn or the fan blade is damaged, this can cause vibration. However, the actual noise could be could be coming from some other part of the oven which is insecurely fixed, e.g a panel, internal shelf, the oven/grill element - pretty much anything!
Basically, the fan/motor causes the vibration and a loose part causes the noise.
Hope this helps.
Regards,
BElectric
Nov 14, 2010 | Ovens
Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
Oven unit not heating up - Kitchenaid KEMX377GWHO
This sounds like a blown thermal fuse, a common problem. What model oven was this?
Dec 02, 2008 | KitchenAid Architect® KEMS378S Electric...
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
KitchenAid KEHU309 Stainless Steel Dual Double Oven Logo
53 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
