Question about Mitsubishi Televison & Video
Vertical white lines on half the screen of my Mitsubishi 73835
    Master:
  • 456 Answers
Problem in horizontal circuit, time for a flatscreen
Posted on May 16, 2014
premtech
  • 934 Answers
SOURCE: Vertical line down the center of screen
A WD62827 is a V30+ chassis and is a DLP format projection screen Tv, not a flat screen, am I missing something?? For the symptoms you're describing with a WD62827 remove and reseat the DVI cable between the chassis and optical engine. If removing and reseating the DVI cable does not resolve the issue you may need to replace the Optical Engine part # 938P019020
BTW the current software version for this unit is 7.04.1F if you have anything less you might think about updating the software also..
Hope this helps!
Bill
Posted on Nov 29, 2007
Williston
  • 7 Answers
SOURCE: vertical lines on sansung hln5065w tv
Bring up the on screen menu if you see the lines in front of the menu replace the DMD board.
Posted on Feb 24, 2008
  • 2920 Answers
SOURCE: Vertical white lines across screen
whatever brand your tv is go there .com maunals it should show u what u need to know
Posted on Nov 03, 2008
Angel Petter
  • 114 Answers
hi there.. try this link they talk more about this problem and there is a picture lets see if your problem is similar to the one on web
your image is like this one?
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1283&p=4322&hilit=Vertical+lines#p4322
Posted on Mar 24, 2010
  • 86 Answers
SOURCE: White vertical lines across the screen. Why and
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
Posted on May 06, 2010
I am showing a green and blue grid across the screen of my Mitsubishi WD-73835. How do i fix it
You can get a repair kit for the convergence components if you are handy with a soldering iron. You can get parts from: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 01, 2016 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
May 06, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
CRT TV with a white line half way up the screen
The white line is result of a Vertical failure. Believe it or not, the whole picture is contained in that one white line, but it is not spread out from top to bottom on the screen.
Usually, a vertical failure is IC or capacitor related. Should be an easy, fairly inexpensive fix for a competent repair shop.
Hope this helps you...
Jan 05, 2009 | Televison & Video
Mitsubishi Model CR3515R White Gray lines cause picture inversion.
Your having trouble with the vertical sync/deflection circuitry. Probably a driver since it clears up after it gets warm. Could be as simple as a cold solder joint but it's not something you can do yourself unless your a tv repairman.
Sep 24, 2008 | Mitsubishi CS-40503 TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
