Question about Maytag Atlantis MAV6000 Top Load Washer
Poor extraction my maytag atlantis is inconsitent with water extraction
  • edc02 Nov 12, 2008
    he said inconsistent, which I do too! sometimes it extrats and sometimes it doesnt
    Scholar:
  • 146 Answers
Check the drain pump filter and remove the drain hose where it attatches to the plumbing under the sink/tub and look for any blockage in the drain spigot. Also you can remove the drum to pump hose and check that for any blockage. Try to turn the pump impellar by had/finger and it should turn freely. If it doesn't turn freely, the pump is seized and has to be replaced.
Posted on Nov 04, 2007
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My maytag atlantis washing machine is working fine except it is not letting the water in, I have to do it manually, thank you Therese
You will need to replace the water valve. If you go to http://www.partselect.com/MultiModels.aspx?ModelNum=mav6000&searchTerm=img_52402&RefineSearch=0&imgMfg=Maytag and look at part #2. This is the part you will need. You can access it from the rear of the unit. You can also order the part for this site. Good luck
Dec 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mav7000 spins but does not extract well. Clothes remain wet
wet as in standing water left in tub, or wet as in extra drippy???
standing water would be bad or pluged pump, drippy would be bad belt, pulley or tensioner assembly..
also if pump turns hard or has seized, the seal/bearing may have seized, causing a slowdown in spin speed besides burning the belt, leaking, and making a mess..
best of luck,
ttfn
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
May 09, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
114 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
