Question about Mtd Garden
Yard-man rider mower won't accelerate - Mtd Garden
    Sergeant:
  • 459 Answers
Bad belts
stuck clutch
Posted on Feb 19, 2015
  • 11 Answers
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Posted on Mar 15, 2009
  • 3600 Answers
SOURCE: Yard Man 21" Mower Pull Cord Won't Retract
You will find the retractable spring is broken you can go to any lawn mower shop and buy a replace me, also Wal mart and others you will have to wind it up till rope is tight then hook to the flywheel where the slot is. cost about $10.00 also lube the center hub bearing with wd 40
Posted on Jul 16, 2009
MNfisherman
  • 11896 Answers
SOURCE: Yard man mower 139cc OHV spark plug
You can purchase a boot puller or take a pliers and grab exactly on top of spark plug and pull off. Some do stick on harder than others.
Posted on Aug 17, 2009
rwvanlue
  • 486 Answers
SOURCE: oil change in yard man lawn mower
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
Posted on Dec 06, 2009
  • 10 Answers
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Posted on Apr 12, 2010
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
Yardman2003 rider mower keeps fauling the plugs and shuts down why
either your engine is seriously worn or your fuel system needs to be repaired. If the fouling is black and oily its the engine, if its wet and smells like gasoline then you need to start with the aircleaner and go onto carb,
Jul 15, 2014 | Yard Man Yardman Riding Lawn Mower 38in...
Why won't my yard man briggs and stratton 7.5 hp engine crank
Check for blown fuse if good put a light tester on the starting then turn the key if your tester lights up then you know that the stater is bab if it does not then you do not have power to the shotch. One red wire should have power all the time and the other red wire should have power only when the key is on.
Jun 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Won't start...turns over...took. Air filter off and gas and oil mixture shoots up into their once it starts
sounds like the needle valve in the carb is not seating and the fuel is draining into the oil
May 14, 2012 | Yard Man Garden
Yardman lawnmower stuck in gear. Won't start.
go to https://houzz.com/ type in mower stuck in gear they will give you the answer
Apr 08, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
We have 42'' Yard Man riding lawn mower need to how to change oil
Apr 12, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
After running for a while the engine on my rider stalls and won't restart until cool down
Does it have spark when it won't start? This is a common failure behavior of ignition modules
Oct 25, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Lawn mower idling up and down until it shuts off.
clean or replace your air cleaner that will fix it,I hope this helps you?
Oct 10, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd rider trans belt will not stay on
it sounds like the spring got stretched or came loose. or wrong belt or the dowl pins around the pully came off?
May 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
How to get rear wheel off yard macine rider
LEAVE MOWER IN GEAR(NOT RUNNING OF COURSE),PUT REAR END UP ON BLOCKS,REMOVE THE CAP,USE BREAKER BAR SET SOCKET ON NUT WITH HANDLE FACING FRONT SUDDEN **** SHOULD MAKE IT BREAK FREE.
May 02, 2009 | Mtd Garden
Garden Logo
35 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
