Question about OCE Office Equipment & Supplies
What is the meaning of display message "line failure please turn off immediately" on oce 1824-c plotter on power up, the same message is displayed whether a serial cable is connected or not ?
professor_sc
  • 180 Answers
SOURCE: HP Officejet 5610 Fax Failure
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
Posted on Nov 29, 2008
  • 414 Answers
SOURCE: k80xi scanner failure
follow the link below
http://h10025.www1.hp.com/ewfrf/wc/product?product=61737&lc=en&cc=us&dlc=en&lang=en&cc=us
thanks for the rating.
Mark
Posted on Mar 26, 2009
antiochpc
  • 1314 Answers
SOURCE: System Error 0B000D 0000000D on display, nothing prints
Hello.
From the service manual:
System Error: 0B000D
Problem
Description:
24 V source test failure.
Corrective Action: Replace the Electronics Module
HP Part number: C6072-60146
I just looked up the pricing and it's not cheap. Let me know if I can be of further assistance.
Posted on May 28, 2009
57 varieties
  • 1653 Answers
SOURCE: My brand new HP LasrJet printer is displaying the
Quite literally what it says. You have a fatal printer memory problem. As the printer is new call your dealer, or HP directly, to get this sorted out under replacement / warranty ASAP.
Posted on Sep 10, 2009
  • 95 Answers
SOURCE: HP 1610 "scanner Failure" message
It MIGHT be that the unit is no good. The downside of ALL IN ONE products. BUT, unplug the power cord from the back of the all in one, then unplug the USB cable, then unplug power cord from wall. Wait 10 minutes and plug everything back in in reverse order and see if it works. If not it is bad.
Posted on Jan 18, 2010
I have a problem with my plotter oce 2436 its niot printing
There is no Oce plotter of that model number. Please look again on the front of the machine or on the Operating Panel and ensure you are not reading the serial number.
May 17, 2017 | OCE Office Equipment & Supplies
Tried upgrading Canon iPF710 firmware from 1.35 to 1.40 on 2 separate plotters and received a !Error E196-4040 Call for service message. Plotter will not come to a Online status.
Power off and unplug the printer for several minutes. On power on the printer had the same "ERROR E196-4040 Call For Service" after Initialization. Next start the printer in Service Mode, turn on the printer while holding down the [Paper Source/Feeder Selection] button and [Information] button until Initializing appeared in the display. An "S" will appear in the upper right of the version display. Power down and do a normal Power On and the printer should do a normal initialization and came On Line.
May 28, 2011 | Canon imagePROGRAF IPF710 Printer
What does error Oxc05d0281 mean
This error message means" ink system failure " and to resolve this issue please follow these troubleshooting steps:
Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed
1?Press and hold the “*” key
2?Press the “#” key and release both keys,Display should say “Enter Special Key Combo”
3?Press and release in sequence the “1”, “2” and “3” buttons
4?Press and release the right arrow button until the display says “System Configuration Menu”.
5?Press and release the “OK” button.
6?Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure
7?Press and release the “OK” button.
8?Display should say “Hardware failure status: Clear. Press OK to clear”.
9?Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
10?Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11?Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
12?Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
13?Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
The error message should not pop up so try to print a self test Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
all the best
Jun 04, 2010 | HP Photosmart 3210 Printer
Message on printer screen "ink system failure" Message on computer screen "print head failure"
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Aug 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error 0xc18a0401
This can be a failure of the firmware which means the printer is in hardware failure status but it can sometimes be fixed. Follow these steps EXACTLY as written.
Press and hold the “*” key. Press the “#” key and release both keys.
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration Menu”.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
May 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
My printer displays ink system failure error message 0xc18a0101 model hp c6288
May 14, 2009 | Canon imageRUNNER 7200 Copier
Document failed to print
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Jan 06, 2009 | HP DesignJet 90 - printer - color -...
Ink system failure
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
display says: "enter special key combo"
C. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
display says: "uiaux"
display says: "support COxxFN0723BR"
Perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Make sure that you perform steps from 2-9.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Please perform all the above steps from 10 to 13 .
Jan 06, 2009 | HP Photosmart C6280 Printer
Printhead
When the plotter goes through its initialization, it stops, the printheads move to the right side and the window displays "switch power off, check printhead path (2)" I've turned the power of an wiped things down, I've unplugged and then restarted but continue to get this message. What do I need to look for or do to get it back on track?
Oct 17, 2007 | HP DesignJet 1050c InkJet Printer
12 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
