Question about Adobe PageMaker V7.0.2 for PC
Adobe® PageMaker® for Windows application file has encountered
Adobe PageMaker for Windows application file has encountered a problem and needs to close
Posted on Apr 16, 2013
  • 30 Answers
SOURCE: Downloading Adobe Acrobat Distiller 4.x/5.x
Check your PageMaker installation disks ... Acrobat Distiller software should be included.
Posted on May 29, 2009
SOURCE: pagemaker 6.5
i wan page maker free downlode soft ware
Posted on Nov 28, 2008
NeoMax
  • 13 Answers
SOURCE: want to get back adobe pagemaker 7.0 which got uninstalled
If you had original version, you can check it out with Adobe. But this is illegal. you can find the link to download full version of pagemaker @ www.allyoulike.com and search pagemaker.
Posted on Jan 21, 2009
DCS13
  • 75 Answers
SOURCE: how to convert Adobe pagemaker 7 to indesign cs3?
Pagemaker to InDesign is not an exact process. You are going to have to put some work into the converted file. The important thing to maintain in PageMaker to make a clean transition, is to make sure the PM file is PRISTINE. All the links in the Links Palette are current, al fonts for the file are loaded. Delete any unused colors, just clean the file up. The more clean the file, the cleaner the transition.
No matter how clean the file is, there are going to be things you are going to HAVE to fix. You are going from an app that has not been supported for over a decade into the latest and greatest, InDesign. Be patient and be glad at least you can get the PM file into something usable instead of having to rebuild it entirely.
Hope this helps.
Posted on Jan 22, 2009
  • 30 Answers
SOURCE: I have Adobe Pagemaker 6.5 and just got Windows 7,
I'm afraid you have a problem. Windows 6.5 doesn't run well on Windows XP, and PageMaker 7.0 can't be installed on Windows Vista at all and there is no patch for it, so most likely, your PageMaker 6.5 won't run on Windows 7. Sorry. :(
I'll research a little more and post if I find anything different, but I'm pretty confident that it won't run.
Posted on Feb 06, 2010
Lately, whenever I close a PageMaker file, I get a window saying that PageMaker for Windows application file has stopped working. The details show the problem event name is APPCRASH, and the applicati
PageMaker 7.0 was released in 2001 and according to Adobe the last OS where it would work in is Windows XP. Both PageMaker and Windows XP are officially unsupported. If you are on a newer Operating System, that could be the problem. Either way, InDesign is the replacement of PageMaker. InDesign will be able to open your PageMaker files just fine.
Aug 31, 2014 | Adobe PageMaker 7.0 for PC
How do insert page numbers on page maker automatically?
To have Adobe® PageMaker® automatically number your pages, if the template isn't used, place a page number marker on the Master page of the document.
  • Go to the Master Pages by clicking on the page icons with the L and R on them at the bottom left corner of the screen.
  • Using the Text tool, draw a text block in the general area for the page numbers.
  • On the Mac, press Command+Option+P or in Windows, Ctrl+Alt+P.
  • Depending on the page you are on, the page marker will show up in the text block, LM on the left page, RM on the right page.
Auto page Number
  • This text can be formatted like any other text on your pages.
  • Select the Pointer tool and move the copy block into the correct position.
  • Click on a page icon to go to a page in your file and the actual page number will appear.
  • If the page icons do not have the correct page numbers on them, go to the File menu, select Document Setup and change the Starting page # field to the correct starting page number.
Another solution
Adding Page Numbers in PageMaker 7 Page numbers add shine and organization to any publication. In Adobe PageMaker 7, page numbers are quite simple to include, but function is difficult to find first time. After activated, page numbers show throughout selected project.
Instructions
Step 1
Start project in PageMaker 7.
Step 2
Choose text function from toolbox. It appears as T.
Step 3
Click L/R function. It is placed under ruler.
Step 4
Click master page where page numbers placed and push "Ctrl+Alt+P." Page number must show.
Jun 09, 2011 | Adobe PageMaker 7.0 Classroom in a Book...
Huge files of page maker 6.5 was kept in local drive F, when i tried to open the said files it does not open and show that this format cannot open with this application.
Try re-creating the preferences of your pagemaker software by following the mentioned steps: (Steps are mentioned considering you have Windows XP installed)
1. Close PageMaker id its running
2. Open the Program Files/Adobe/PageMaker 6.5/Rsrc/Usenglsh folder.
3. Rename thefollowing files (for example, to Pm70old.cnf):
-- Pm70.cnf
-- Pm70filt.cnf
-- Pm70ppd.cnf
-- PStyles.cnf files
4. Start PageMaker. It will re-create preferences files.
If the problem continues, the preferences files is not the cause. To restore custom settings, delete the new preferences files and restore the original names of the previous preferences files.
See if this works and reply back.
Jun 01, 2011 | Computers & Internet
I cannot install adobe pagemaker 7.0
Did you see the system requirements? Here's it - try to see if its fit to your system For
Windows
  • Intel® Pentium® processor
  • Microsoft® Windows NT® 4.0 with Service Pack 6, Windows® 2000 Professional with Service Pack 2, Windows XP Professional or Home Edition
  • 32MB of available RAM (48MB or more recommended)
  • 175MB of available hard-disk space for installation (200MB or more recommended)
  • Video card with 800x600 resolution and 8-bit/256 colors (24-bit, high-resolution display recommended)
  • CD-ROM drive
  • For Adobe® PostScript® printers: Adobe PostScript Level 2 or later
for Macintosh
  • PowerPC® processor
  • Mac OS 9.1 or Mac OS X (Classic mode only)
  • 30MB of available RAM (45MB recommended)
  • 150MB of available hard-disk space for installation (200MB recommended)
  • 800x600 monitor resolution with 8-bit/256 colors (24-bit, high-resolution screen display recommended)
  • CD-ROM drive
  • For Adobe PostScript printers: Adobe PostScript Level 2 or later
If you think your computer system got all of the above requirements, Perhaps there's a problem of your computer Operating System. Try reformatting it.
May 18, 2011 | Adobe PageMaker 7.0 for PC
I would like to know if Adobe PageMaker is usable with Windows 7.
PM6.5 is very old in software years. Read here http://kb2.adobe.com/cps/328/328682.html about what Adobe says.
Realistically, you should either install PM6.5 on a Win2K PC or move to InDesign.
You can create a virtual WinXP with Win7 using Virtual PC, but for PM6.5 it's unproven and an extemely lengthy work around.
I think you can upgrade to a newer more compatable version ......cut and paste this to go to the upgrade page for more info http://www.microsoft.com/windows/compatibility/Windows-7/en-us/Details.aspx?type=Software&p=Adobe%20PageMaker&v=Adobe&uid=7&l=en&pf=3&pi=1&os=64-bit
Here is the windows system requirements:
Windows
  • CD-ROM drive
Apr 07, 2011 | Adobe PageMaker Plus 6.5 for PC
Can I install PageMaker 7.0 in Windows 7 Home Premium?
U cannot install page maker 7.0 in windows 7 home premium
System requirements
Windows
  • CD-ROM drive
Dec 01, 2010 | Adobe PageMaker 7.0 for PC
I need to open PMD documents and i am searching for a free software
PMD files are associated with PageMaker application. And as far as the compatibility is concern, only associated application would be able to open that. Till date I haven't heard any other similar app to open a file that was created in pagemaker. You will need to install pagemaker only, that could be a trial version. What you can try... importing the file with the latest versions of adobe cs. I hope this will help you to get the resolve.
Regards,
Rajesh,
www.unichost.com
Nov 04, 2010 | Adobe PageMaker 7.0 Classroom in a Book...
Pagemaker spell checking problem
Pagemaker 7 will not readily allow Spell checking under Windows 7. To do this you will need to run the Pagemaker application as the Administrator. This can either be by clicking on the right hand mouse botton (right handed persons) while the cursor is on the Pagemaker launch icon either on the desktop, Windows Start up menu or Application Program launch menu and then choosing to run the Application as Administrator. Pagemake launched like this will normally allow spell checking, without  the Pagemaker application will return distionary missing or does not support spelling.
Disabling account control in Windows 7 before running the Pagemaker, which I do not recommend also achieves this in Windows 7. All the above applies for Windows Vista too!
May 06, 2009 | Adobe PageMaker 7.0 for PC
Translate a pagemaker file into indesign
This is from Adobe InDesign (CS3) Help module:
Convert PageMaker documents InDesign can convert document and template files from Adobe PageMaker 6.0 and later. When you open a PageMaker file, InDesign converts the original file information to native InDesign information. InDesign files are saved with an .indd filename extension.
For more information, see the PageMaker Conversion Guide (PDF) at www.adobe.com/go/learn_pmconv. Before opening the document in InDesign, you may want to do the following:
  • If the PageMaker file or its linked graphics are located on a network server, floppy disk, or removable drive, it may not open as expected if an interruption in data transfer occurs. To prevent data transfer problems, copy documents and their links to the hard disk, preferably in the same folder where the PageMaker publication is stored, before opening them in InDesign.
  • You may want to use Save As in PageMaker to clear unnecessary hidden data.
  • To ensure that all links are maintained, copy all linked files to the same folder where the PageMaker publication is stored.
  • Make sure that all necessary fonts are available in InDesign.
  • Repair broken graphics links in the PageMaker publication.
  • If you have a problem converting a large PageMaker document, convert portions of the PageMaker file separately to isolate the problem.
If you cannot open a corrupt PageMaker document in PageMaker, try opening it in InDesign. InDesign can recover most documents that PageMaker cannot open.
Oct 29, 2008 | Adobe InDesign CS2 for PC
Adobe PageMaker V7.0.2 for PC Logo
227 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
