Question about Craftsman Garden
Problem with Craftsman YTS4500 Hyrostatic Transmission Lawntractor Belt and possibly Tranny Model 917289900
Ok, here is my problem. My tractor mower kept throwing the drive belt while I was mowing so I replaced the belt. It is still doing it so that it now the problem. As I was doing the lawn yesterday it threw the belt one last time and when I reset the belt, NOW IT JUST WONT MOVE. Everything is set up properly and I am afraid it is the transmission. It has been squealing a little bit lately while going in reverse. I have been reading a little bit about the hydro transmission fluid but some say it is a sealed unit. HONESTLY, I took the rear wheels off and can't even access the transmission top area without taking the axle off. Obviously not a normal service for the average homeowner. This is the Craftsman YTS4500 Kohler 26HP Model 917289900 54" Deck. Any help would be much appreciated. Thank all.
  • 2 more comments
  • Kim Percy
    Kim Percy May 12, 2014
    So I took off the wheels and found that 2 bolts have snapped off of the transaxle (transmission) that held it onto the chassis. Also resulting from (I'm Sure) (or vise versa) 2 bolts were ripping a part of the chassis at the ends of where the wheels are also causing the transmission to hang down about an inch or so lower than normal. I don't know if this is what would be causing the belt to be thrown out of whack but I am sure this is not helping. Ugh, what a mess. Now I need to find a lawnmower shop willing to fix this and weld this. Boy I hope this won't cost too much.
  • Kim Percy
    Oh, and found out the problem about it not moving, It was just the drive belt was not placed properly. Last time it was thrown off, it was thrown so out of place it totally skipped out of place I missed a pulley. Anyways. Now I have a whole new set of problems. Thanks for your options thus far guys.
  • Kim Percy
    Add a CommentAnd as for the sqealing, it seams to be coming from inside the transmission. Hmmm.
  • Kim Percy
    But only in reverse the squeal occurs. It's wierd.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
Sounds like the barrings in a ideler pulley are bad.
Posted on May 12, 2014
SOURCE: I have a Craftsman lawn tractor LT1000 6 speed
Similar thing happened to me and it seemed to be nothing more than a completely clogged air filter. When replaced it was fine.
Posted on Apr 21, 2009
  • 6 Answers
SOURCE: Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Posted on Apr 22, 2009
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
  • 246 Answers
SOURCE: craftsman 20.5 hp. auto trans.lawn tractor loss of drive power
Hello:
>>You can View a Breakdown/IPL of
this Engine at this Site Addy,
http://www.outdoordistributors.com/
and Select the H. Then Select Hydro-
Gear. Then Select Don't have Part
Numbers. Then Enter the Model
Numbers 319-0650. Then Select your
Model and Download the File for
Online Viewing.
From your Description it Sounds like the Internal Pump is Worn and is Loosing Pressure as the Unit Heats Up and the Components Expand from the Heat.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
Good Luck
Respectfully
jbridger (John)
Why doesnt my MTD 42" lawn tractor move but it will start?
If the transmission is belt drive, check the belt, worn/oily? If you have a hydrastat tranny, make sure that the bypass plunger is pushed in. Check that the belt goes around the tranny pulley. If still no luck, turn mower off, jack up and support the rear frame, with the real wheels hanging in the air(just an inch or two is plenty) try turning the wheels -1st, with the gear selector in "N". then 2nd, with the gear selector in "D". This should narrow the problem down a bad tranny or a sheared keyway in the axle.
Jun 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 21 hp lawntractor model 917.289240 will no go in reverse.
If this is a hydro unit and it runs ok forward there should be no other reason other than linkage adjustment for it not to run in reverse, for safety reasons they are normally adjusted to run slower in reverse
Aug 09, 2012 | Craftsman Garden
2007 craftsman sy 4500 42" mower will not climb small incline. any suggestions?
sign of a failing hydrostatic tranny. however 3 years is pretty quick for a transmission unless mower was used commercially. make sure your drive belt is snug.
Aug 26, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Trying to replace broken brake rod
Go to www.searspartsdirect.com. Put in your model number there, it will come up with parts list and diagram for your mower.
Apr 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawntractor model # 917273121
There is no tension adjustment it has an idler pulley working off from a spring. Check to make sure that the spring did not come off or break. If neither of these have happened then the belt is stretched and you need to purchase a new one.
Apr 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor has a very touchy clutch
When you change the transmission, also change the drive belt?
One of the most often cause of transmission problems are the inadequate drive belt. The length should be the same as the manufacturer specification. Also the drive belt surface quality is very important. Keep in mind that the "clutch" is a simple mechanism that depends on the slipping belt feature and its right lenght. Frequenty users cange the belt and use an automotive type belt.
Let me know some news about your problem.
Have a grat day!
Fernando
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower will not move.
It is very likely that your belt is not on right. Check your manual to see it it is on right.
Jun 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawntractor does not move forward or backward
you might check the pulleys to see if shear pin has broken.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
201 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
