Question about Olivetti Office Equipment & Supplies
How do i solve olivetti d-copia 253mf error code 6000?
As far as i know this error code has something to do with the fuser unit and there is a way around this but i dont what way to go about it i would be most grateful for any suggestions. kind Regards Pat Hayes
    Champion:
    New Friend:
  • 245 Answers
My dear you press 10871087 after you slect 163 and press print baten
Posted on Jul 12, 2014
SOURCE: Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Posted on Jan 24, 2008
  • 4 Answers
SOURCE: fuser error 50.2
1) First thing is check power source. If you have the printer plugged into a UPS (uninterruptilbe power source) unplug it and plug it directly into the wall. If it is plugged into the wall you might want to try a different outlet to see if it solves the problem.
2) Remove and reinstall the fuser. It may not have seated properly.
#) Make sure you installed the correct fuser. Should be RM1-1082. There should be a sticker on the fuser with this number. See the following article for more info. http://www.partsnow.com/service_today/0705.asp
If you still have the old fuser check also that it is a RM1-1082. If not you may have a euro version machine which would require a different fuser.
If the fusers match up you should check the voltage coming to the fuser if possible. If there is 100- 127 volts where the fuser plugs in you probably got a bad fuser or it was damaged in transit. If there is low voltage or no voltage you may have a board problem. Probably DC controller or Power Supply.
Posted on Mar 30, 2008
SOURCE: Clear Service Code Error Message
you have to:
press the arrows "up" and "down" at the same time for five seconds
press the OK button
a new menu appears
select option 2: ENGINE
with the arrows navigate and select option number: 5 (MODE)
now press the right arrow until you see "810. SC RESET".
press ok
and later press "execute" (you will see it in the screen of the printer)
press "ESC" until you exit all menus
power off the printer for 30 seconds
and.... VOILá........
thats all
Posted on Jun 18, 2009
SOURCE: kyocera fs-3820 no power
You don't have to replace the fuser. You can fix it by taking the fuser apart & repairing the thermostat. This is located under the fuser roller. Take the thermostat apart & bend the metal plate on top just a little, then put everything back together. This works prefectly & will save you money. The heat from the roller makes the metal on the thermostat bend & releases the contact on the inside.
Posted on Sep 03, 2009
  • 11 Answers
SOURCE: error code eq023 & worn fuser unit appears even after changing to new fuser
transfer belt cleaner error
replace the transfer belt unit
Posted on Sep 06, 2009
How do I change the language on an Olivetti d-copia 600? Regards Sarjo
http://www.manualslib.com/manual/455266/Olivetti-D-Copia-600.html?page=54
Feb 09, 2015 | Olivetti Office Equipment & Supplies
Can i get a free copy of an olivetti d-copia 20W digital copier driver for windows 7
yes see link however if you want to look at a better machine drop me a line: l.sweeney@digitaloffice.co.uk
thanks
Luke Olivetti Product Support Copia 16W 20W Olivetti
Oct 01, 2014 | Office Equipment & Supplies
What does this error code mean 6000:0185578
Error code 6000 is usually a Fuser unit error. You need to replace the fuser Unit.
Aug 19, 2014 | Kyocera FS2000DN Laser Printer
Olivetti copia 9017 RESET ERROR E0000
Olivetti copia 9017 haw to RESET ERROR E220
Jan 09, 2014 | Office Equipment & Supplies
Olivetti d-copia 16w error code H4
I need driver olivetti_d_copia_16w for winXp....
Sep 25, 2012 | Olivetti Office Equipment & Supplies
Kyocera FS-2000D error 6000:0087166
This Code relates o the fuser unit, needs to be replace but if this code keep coming constantly from time to time than you need to check this:
There is a two wire power connector from the switching regulator ( by the interlock switch ) that goes to the fuser connector. This is one of the areas we check for the 6000 error code.
You could also check for a small piece of paper lodged in the fuser connector, both on the fuser and the one at the engine board.
also Check the power at the wall outket. Low power will cause 6000 errors.
Nov 10, 2011 | Kyocera FS-2000D Laser Printer
I HAVE A COPIER RICOH AFICIO 2022 SP WITH THE CODE SP 545 BUT I WANT TO KNOW WHERE IS THE THERMISTORS TO CLEAN IT
Thermistor is in the fuser. Open right cover and you see the fuser. On a fuser have some labels "Hot Surface" "Danger... or something
Jan 24, 2011 | Ricoh Aficio 2022 Black and White Copier
263 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Alun Cox
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
