Question about Pentax *ist D Digital Camera
How to change the tube of the built in flash ?
The built in flash suddenly cracked with a big noise and doesn't work at all anymore. I am quite sure the tube is burned out.
    Top Expert:
  • Pentax Master
  • 6,702 Answers
Unless you are trained as an electronic engineer, I don't think you can replace a flash bulb in a camera.
The chance you get the correct "bulb" (it is a tube) is very slim. You could look on ifixit dod com if anyone already did change a flashlight in a camera. I think they also can help when you want to buy spare parts. But first ask what it will cost. Perhaps an external flash is cheaper than a repair. It also gives more light, and can be used on your next camera too.
Posted on May 11, 2014
04 Santa Fe burning smell running ac....
Sounds like the A/C compressor clutch has overheated and become inoperable. Open the hood, start engine, observe the compressor face. It should be turning and also see if that's where the noise and burning smell is coming from.
Good luck!!!
May 16, 2013 | 2004 Hyundai Santa Fe
My audio did not work anymore
If the audio was working earlier and than all of a sudden quit working I suggest making sure that it is plugged into the correct port, than restart the computer and try to play a song than. If it still doesn't work, sounds like your on-board audio card is finished. ALSO make sure your volumes aren't muted.
Sep 06, 2012 | Gateway One Computers & Internet
My flash has stopped working on my D60. It is engaging, and everything is turned on, but no flash. A detachable flash works. Is it possible that it has burned out? And is it fixable?
Hi, It's possible it's the flash tube and that its burnt out. Since an external flash works it doesn't sound like it's the circuitry which is a good thing. The flash tube being burnt out is fixable however it's a fix that needs to be done by a professional. If your camera is still under warranty you can send it into Nikon for repair. If it's not under warranty you can still send it into warranty or you can find someone in your area who specializes in camera repair (as that would likely be faster then sending it to Nikon). If you have anymore problems feel free to message me and I can help you out =)
May 17, 2011 | Nikon D60 Digital Camera
Internal flash not working on olympus e500
The Xenon flash tube in modern strobes rarely 'burns out'. I would guess that a switch that is activated when the flash pops up is not working properly. More info can be found here: http://forums.steves-digicams.com/olympus-dslr/159660-e-500-built-flash-not-working.html
Dec 08, 2009 | Olympus EVOLT E-500 Digital Camera
Sony Triniton xbr
The continuous blink code indicates some failure in communication between the computer in the set and the big signal-processing chip that controls most of the TV's video functions. Since the set fell, it's probably due to a either cracked circuit board or a broken picture tube.
If the board is cracked, it might repairable if the broken circuit traces can be found and patched. If the tube is broken (because the shock of the fall cracks the glass neck of the tube and allows air to leak in), it's time to replace the TV.
There's really nothing you can do on your own to fix this. Your best bet is to see if a professional can come out and give you an estimate. (Or use this as an excuse to get new flat-screen which would take up a lot less room!)
Feb 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Asko dishwasher d3120
Hi this is known as an L1 fault (Not heating) you need to check the element,thermistor,wash motor,wiring or the pcb.Failing this you need to ring asko
Mar 02, 2008 | Asko D1776 Stainless Steel Built-in...
Whirl pool quit partner 3
the dishwasher may not be level, it may be tilting forward or leaning to the left. also check the spray arms to make sure it is not split or cracked. and check the upper rack feed tube to make sure it is in place and not damaged. I hope this helps.
Jan 11, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
My built flash quit working!
Capacitor or tube blown- stick to the external flash a repair will be pretty pricey
May 25, 2007 | Canon Powershot PRO 1 Digital Camera
Flash not working
It is either the small flash tube or trigger coil that need replacing . If you decide to do the job yourself, make sure you discharge the main capacitor before you start working on the camera ( when charged holds +- 300 v)
Apr 23, 2007 | Minolta Dynax 40 35mm SLR Camera
Pentax *ist D Digital Camera Logo
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
