Question about Car Audio & Video
Sony cdx v6800
Initially entire system was hanged. anyhow after disconnecting from power supply able to toggle between aux/cd/radio. But, now volume control is not working....!
SOURCE: Sony CD interchanger CDX - T69 (how to reset?)
This would invalidate the warranty and you may break it but I have just had to do one:
1. Remove 4 black screws
2. Unclick the front panel - yes it is clicked on but may appear to be screwed
3. Take off black lid
4. Pop the cradled player from the 4 dampers and unhook from the 2 springs
5. Remove the ribbon connector - do this by slipping/clicking the brown holder very slightly and then the ribbon comes out easily
6. Now using a suitable tool push the stuck CD back into the magazine
7. Click the magazine out - there is a white piece of plastic what when moved does the eject.
8. Do the above in reverse.
The trick to get the grey horizontal/vertical discs back on is to set them passed horizontal one notch on and click them on at the end - turning one notch anti-clockwise to lock them.
Posted on Sep 06, 2008
SOURCE: MMI doesnt stay on
you have to restart the system again  you can do it only in the car delar
it dosen't take time
Posted on Nov 05, 2008
thefazool
  • 3 Answers
SOURCE: No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
Posted on Dec 15, 2008
SOURCE: no sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Posted on Feb 28, 2009
  • 3 Answers
SOURCE: sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Posted on Mar 13, 2009
I have a sony mp3 xplod car radio, buttons wont work on it to operate probaly, any suggentions as to what is wrong?
I had the same problem with my sony CDX-GT540UI and solved it! I just kept clicking the "source/off" button when the display was showing the demo and suddenly it started switching to USB/CD/AUX etc. This means that the contacts inside the micro-switch were stuck in the down position, continuously making contact, and blocking the signals from the other buttons. Have to replace the micro-switch now.
Dec 29, 2011 | Sony XPlod CD Player w/MP3 Playback...
How can I connect ipod on SONY cdx-mp70. Is there a cable to do that, maybe in the back, in AUX?! Thanks
i use to have the same radio, the only way is to use the AUX with a RCA to 3.5min cable. i dont think sony has a ipod interface for that radio because of its age. Wish i still had it!
Feb 17, 2011 | Sony CDX-MP70 CD Player
How to wire a sony cdx-gt640ui in a 1999 dodge intrepid...I get sound with the tuner, but no sound with cd, aux, and usb. I'm assuming its only an incorrect wiring setup...
instead of used the blue wire on the Sony head unit to the car wiring harness use the blue/whit wire
  • Blue - powers on only when am/fm is active
  • Blue/White - powers on when when radio is on am/fm/cd/ ect.
Jun 13, 2010 | Sony CDX-GT610Ui CD Player
MY Sony CDX-R3000 will only play CD's. It will not allow me to adjust volume, skip songs, or play the radio
Try and reset it . disconnect battery under the hood for like 5 min and see what happens ..I had that radio and sometimes its just tempermental . take cd out and try it ? Sre any buttons stuck ? If that doesnt work then hopefully u like your cds at the volume they are at . Good luck
Oct 07, 2009 | Sony CDX-R3000 CD Player
Sub doesnt kick on when put cd in only comes on when turn on radi
I had the same problem, but in my case it was a factory amp.
The blue wire on the deck harness is for a power antenna, and only powers up when the tuner is in use, not in the cd or aux mode. Therefore if you are using the blue wire (on the adapter or car side) to power the remote power on your amp, you would need to connect that blue wire (on the adapter or car side) to a keyed power source. This way the keyed source supplies power when the key is on, and will not cut out when the mode is changed from "Tuner" to "CD" or "AUX".
I just connected to the keyed source on my radio harness, but then, I am not running any kind of system, just the basics.
Jun 03, 2009 | Sony CDX-GT210 CD Player
Turning off sony cdx-gt170 display
Hold the volume button down until the clock setting comes on. Then press the same button until you see "Demo:On" on the screen. Turn the volume either up or down to change the setting and then hold the volume button down until you see "AUX" or "TUNER" on the main screen again.
Mar 15, 2009 | Sony Car Audio & Video
Sony cdx gt200
I HAVE A SIMILAR MODEL AND I HAVE TO HIT THE SOURCE BUTTON TILL AUX APPEARS MAY BE A RADIO MALFUNCTIO
Nov 13, 2008 | Sony XPLOD CDX-GT200 CD Player
Sony cdx -m8800
Remove the radio, disconnect the blue wire, and connect the blue/white wire in its place. This should fix your problem.
Sep 08, 2007 | Sony CDX-M8800 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
