Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
My shifter will shift, but truck wont move
Put in new engine, truck starts, shifter will shift, but truck does not move
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
You could have damaged your front pump when you put engine in!
Remove trans. and check front pump and converter.
Posted on May 16, 2014
Check you're linkage by the trans box have somebody stand behind the vehicle put the truck in reverse to see if the reverse light comes on if not move linkage until reverse light comes on .
Posted on May 12, 2014
Car shifts into gear but does not move. At first we had a hard time just getting the gear shifter to move.
. Vehicles have a shifter interlock device that keeps it from being shifted into gear without your foot stepping on the brake pedal . These systems do fail . It's all electrically controlled . Forcing it will just break it , maybe the shifter cable broke . Look at the transmission were the cable hooks up an have another person move the shifter , does it move at the transmission ?
Now the car won't start how ? When you turn the key to the start position does anything happen ? Like engine spins over but doesn't start , or doesn't do anything ?
Feb 14, 2016 | Cars & Trucks
2002 dodge durango wont shift out of park
Put your foot on the brakes and have someone see if you have brake lights.This has a shift interlock that uses the brake lights to complete the circuit that unlocks the shifter from park. You can bypass this saftey feature by applying brake, engine off key off and moving shifter to neutral then starting the engine Dont forget to fix your brake lights !!
Jan 07, 2014 | 2002 Dodge Durango
My car wont shift out of 2nd gear.the shifting handle is sloppy and the clutch is working fine
if the clutch really is working, (lever at bell moves 3/4")
by fine, my guess, is you can take off from dead stop in2nd, right>?
then its a bad shifter. tip.
or linkage (end tranny extension housing)
or transmission actual core.(shift rails, or forks) or worse.
you do know ,that you can disconnect the linkage and test tranny.
by hand,
key off
leakage off
shift to neutral (read the FSM or alldata.com) for how. under M/T sections.
then key on start engine,clutch depressed, the lift pedel
car moves its stuck in 2nd, of not bad linkage.
can do all gears that way, use 2 people and do not stand infront of car doing test.
or put the front wheels up on stands. but do not get near them.
while engine is running.
btw some shifters have plastic parts that go bad in the shifter tip.
or ,
jack up car in front, can you now shift car in to neutral or any gear?
linkage tests.
remove shifter housing and below see the shifter, H pattern
sifter box mechanism.
see that. you can shift that by hand with any small wrench or
large screwdriver, if the works the parts on the end of the shifter
handle main shaft tip are bad.
Oct 19, 2013 | 1995 Geo Prizm
My jeep wrangler 2008 - I shifted to reverse then to parking, when i release the breaks it kept going in reverse. So i turn off the engine. now it wont start the engine, neither the shifter will move
The shifter cable has broken more than likely ,Find the shift shaft on the transmission,,block the wheels and remove the shift cable from the shift shaft,put the gear shift in park,then shift the shift shaft in park,then it will start,Then of course you will have to replace the shift cable.
Oct 05, 2013 | 2008 Jeep Wrangler
4wd shifter stuck in position and truck wont move
Take the transfer case apart and find out what is broke.
Jun 17, 2017 | 1986 Toyota Pickup 4WD
Buick gear shifter moves freely and wont shift gears
you can shift it at transmission by hand to neutral or park and have someone inside start the car and you manually put in gear under hood and drive it to shop or garage, wherever
Feb 06, 2013 | 2000 Buick Century
The gear shifter wont move when the car is on
I currently have the same problem. If the engine is running the shifter will not move from Park. If you turn the key to the accessories position, put the car in NEUTRAL and then start the engine it will then shift. I am led to believe that this issue has something to do with the brakes.
This has happened to me b4 when I first started driving the car. When I bought the car I had to replace the brakes all the way around and that's when the shifter problem arose.
My advice, check your brakes or have them checked.
Apr 22, 2011 | 1993 Ford Thunderbird
Shifter wont shift the pickup into gear
Let's start with the basics. Key has to be in the ignition and ignition turned to the run postion. Battery has to be charged up. Brake pedal has to be depressed so the shifter will unlock, . If the shifter will not move, it could be several things. A faulty shifter unlock cylinder or wirng problem. A binding shiter cable or shift lever problem at transmission, or a problem with the shifter assembly on the steering column.
Mar 03, 2009 | 1996 Ford F150 Regular Cab
Car wont shift into gear
did you check that you still have brake lights ?
Ford has the shift interlock, so if you loose brake lamps, the shifter will not move out of park.
Quick test, turn the key to the on position ( do not start ), and see if the gear shifter will move to neutral.
Dec 08, 2008 | 2006 Ford Mustang
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
52 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
