Question about Roper Washing Machines
Roper washer won't fill high enough - Roper Washing Machines
  • 1073 Answers
SOURCE: my roper washer won't fill with water
check the water inlet valve
Posted on May 11, 2008
  • 22 Answers
SOURCE: roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
Posted on Nov 13, 2008
  • 220 Answers
SOURCE: roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Posted on Sep 27, 2009
  • 842 Answers
SOURCE: Roper washer agitator won't spin after kids loaded
It sounds like a someone has broke the lid switch to the washer. Below I have attached a picture, Item number 9 would be the part you seek. P# 3949247 Under the control panel you will find a harness that contains 3 wires coming out of the cabinet housing. The colors should be tan, white and green. If you jump the white and tan you unit should run and think the lid switch is working. Safety way is to unplug the unit to by-pass the switch and plug it back in and select spin only. This is only to test, you need a lid switch for safety. You should replace it ASAP if this test works for you.
Posted on Jul 26, 2011
TheMobilian
  • 8220 Answers
SOURCE: my roper washer fills with
You have a problem in the transmission.
How it works
Trans rebuild
Posted on Sep 14, 2011
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Roper washer
That could be your lid switch. You should hear an audible click when you shut the lid. If the washer act like it is trying but won't spin that could be the drive coupler. I have a page which includes a service manual HERE
Sep 24, 2012 | Roper RAX4232KQ Top Load Washer
We have just purchased a new washer and dryer and we are finding that in the rinse cyce is not filling it up like our older model washer is this normal? On our dryer we are finding that there is no longer...
Hello
if this is a high eff,water saving washer it is normal.The machine will sence the size of the load at put in enough water depending on size and where you have the load set.
Jun 19, 2011 | Roper Washing Machines
Good evening, My Roper washer RAX4232PQ0 will not spin...it seems to drain OK but won't spin...can you offer any help? Thanks!
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
Jun 09, 2011 | Roper RAX4233PQ Top Load Washer
My top load washer will allow water to go into the tub but will continue to run and drain out on the spin and initial fill
You may have a condition known as "siphoning". This is usually caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain (siphon) as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Jul 19, 2010 | Roper RTW4300SQ Top Load Washer
Sometimes washer keeps running water & doesnt fill up. i have to unplug it for a few hours so it can work again...has happened on all cycles...what causes tub not to fill with water
water is siphoning out the drain hose ,drain pipe not high enough "must be 36 inchs"from floor or hose is inserted in pipe to far creating a suction situation ~once over the edge it cant stop...., may need a anti siphon kit on drain hose .
Apr 27, 2010 | Roper RAX4233PQ Top Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Roper washer wont Agitate
you have a bad watwer inlet valve but the agit. has nothing to do with the water unless you are not getting enough into the machine to start the agit cycle
Jul 29, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
13 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
