Question about Sony KDF-E50A10 50 in. LCD HDTV
Powers up ok. after about one minute loses audio and video, green light flashes about 40 times. then, powers back up with audio and video for another minute before doing it again. any suggestions?
  • 208 Answers
SOURCE: Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
stonephoenix
  • 563 Answers
SOURCE: My Sony KDF-E60A20 loses audio and video in a cyclical manner
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher. You should call the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 07, 2009
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
  • 17 Answers
SOURCE: My Sony LCD HDTV, 60
Try this...... Remove the front panel to access the bulb. There are 2 screws on either side of the tv right behind the screen. You may be able to remove them with just your hands. It will make sense when you see them. Once they are loose the panel will pop off. There are 2 magnets that help hold it on, so just pull gently. In the middle you'll see a another scew that you need to loosen. Slide the bar off, remove the cover and you'll see the black box that holds your bulb. There is an allen screw on the left side that will need to be loosened. Once that is loose, the whole unit slides out. Is the top of the vent screen really dirty? If it is, flip it over and try dusting it off with a soft brush, maybe a tooth brush. Try to keep most of the dust out of the bulb itself though, just be gentle. Pop it back in with the reverse order.......
Posted on Feb 03, 2010
Audio is OK, Video NO
It sounds by the description that your tv has a defective T-CON (Timing Control) Board -this is evident by the 5 flashes and the fact that the screen was working ok, then going black then repeating.
The board can be bought usually on ebay but, only if you feel comfortable in replacing it yourself, otherwise a sony service tech needs to be called to repair this!
Good Luck
Rich lilja
Dec 15, 2013 | Sony KDL40EX710 40 inch BRAVIA 1080p LCD...
TV stops video and audio for about 5 seconds
This model does have some issues, you can try on it to either remove it and a box if used for power for several minutes and then power back to see if that helps.
Soft reset with set on should (using original remote) be Menu, 1,2,3 and enter.
Dec 20, 2012 | Mitsubishi WD-73737 73 in. HD-Ready TV
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
XBOX360 No Audio, No VIdeo, Solid Green Light
the G.P.U has more than likely detached from the main board.
the x clamp mod is more of a diagnostic procedures than an
actual repair function. The G.P.U will need to be re-flowed to
the main board then lightly but firmly clamp to the board
then stress tested (force it to run hot for 15 min shut off and
repeat 3 times)
that's it
Aug 23, 2009 | Microsoft Xbox 360 Console
Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Dec 14, 2008 | Denon AVR-1908
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KDF-E50A10 50 in. LCD HDTV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
