Question about KitchenAid KUDD01DSSS Architect Series Double Drawer Dishwasher, Less than 24 in, 5 Cycle Selections with 3 Cycle Options, Sani Rinse Option, Whisper Quiet Ultima Sound Insulation System, Sure-Hold Light Item Clips, Rinse-Aid Dispenser, Electronic Controls with
Both motors are running red light is on
Both motors are running at same time. tried resetting but motors start back up after 5 seconds. Cannot set any functions on either drawer. Unplugged power flr several minutes. Plugged back in same problems.
2 Suggested Answers
SOURCE: Both drawers are stuck in the on position, both
The water sensor is malfunctioning. It believes that there is still water, so the pumps run and the washer will not continue on its cycle. replace the water sensor, or dry it out so it functions properly
Posted on May 30, 2010
Roomba 560 fully charges. Runs for 2 seconds fully green and just stops. And lights up red.????
Set him on the floor, after powering him off and then back on, and press the "Clean" button three times. This will reset him.
Sep 11, 2014 | iRobot Roomba 560 Robotic Vacuum
Tip
Chevrolet service light 1991-01
Camaro
1998-01
To reset the "OIL CHANGE" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and then goes out, the system is reset.
Corvette
1997-01
To reset the monitor after an oil change, turn the ignition on. Press the "TRIP" button so that the "OIL LIFE" percentage is displayed. Press "RESET" and hold it for two seconds. The word "RESET" should appear on the monitor, then "OIL LIFE 90%".
Impala,
Monte Carlo
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator three times within five seconds. If the CHG OIL SOON lights two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHG OIL SOON light comes back on, the system has not been reset, repeat the procedure. Follow this procedure to reset the GM Oil Life System using the DE 100 Series Radio. Turn the ignition to ACC or ON and the radio off. Press and hold the DISP button on the radio for at least five seconds until SETTINGS is displayed. Press the SEEK up or down arrow to scroll through the main menu. Scroll until OIL LIFE appears on the display. Press the PREV or NEXT button to enter the submenu. RESET will be displayed. Press the DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second. Once the message has been reset, scroll until EXIT appears on the display. Press the DISP button to exit programming. A chime will be heard to exit programming. A chime will be heard to verify the exit.
Impala,
Caprice
1994
To reset the "CHANGE OIL" light, turn the ignition switch to the run position with the engine off. Access the reset button on the end of the instrument panel by the fuse block. Press the switch and hold it for at least 5 seconds.
Lumina,
Monte Carlo,
Impala,
Caprice
1996-00,
1996-99,
1995-96,
1995-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds. The light will flash and go out.
Corvette
1990-96
After an oil change, or when "CHANGE OIL" appears on the Trip Monitor, with the ignition on and engine off, press the "ENG MET" button (located on trip monitor) once. Press the "ENG MET" button again within 5 seconds. Within 5 seconds, press and hold the "RANGE" button (1990-1994) or "GAUGES" button (1995). The light will flash. When it stops flashing and goes out, the system is reset.
Chevrolet Suburban,
GMC Yukon XL,
Chevrolet Silverado,
GMC Trucks Sierra
2000-01,
1999-00
Turn the ignition key to the RUN position. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However, if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the procedure if the system does not reset.
Silverado, Sierra Trucks
1991-93
To reset the "CHANGE ENGINE OIL" message, turn the ignition key to the run position. Press and release the accelerator pedal three times within 5 seconds. If the light flashes for 5 seconds, the system is reset. Repeat procedure as needed.
on Dec 07, 2009 | Chevrolet Camaro Cars & Trucks
Blower motor hums, but does not turn on
Try spinning the blower wheel by hand to see if it starts, if it does a new run capcitor will be needed. If not a new motor will be needed.
Dec 26, 2012 | Goodman Heating & Cooling
Oil change light wont go out on a 1999 grand am
Hello Dyno.
Have you tried using this procedure to turn it off?
OIL LIFE MONITOR SYSTEM
Resetting Procedure
  1. Turn the ignition to the ON position, engine OFF.
Drivers Side I/P Fuse Block 86382201
  1. Press and release the RESET button on the drivers side I/P fuse block.
    • The CHANGE OIL indicator will start flashing.
  1. Press and hold the RESET button until an audible chime is heard and then release.
    • If the CHANGE OIL indicator comes back on, the system did not reset. Try the procedure again.
Nov 10, 2010 | 1999 Pontiac Grand Am GT
Light flashes 6 times locked rotor
Try to turn the center pulley if it moves freely then unplug machine for 30 seconds then plug it back in then open and close lid 5 times within 10 seconds after plugging in. If the motor resets back to 1 flash every second then you will probably be able to operate machine. If it does not reset or it fails again the motor needs replaced.
Feb 26, 2010 | Washing Machines
1986 sei 1200 goldwing It will start from ignition on,fuel pump runs for a few seconds,fuel light goes out,every thing normal-no LED diagnostic lights.When it starts it will run for about 3-5 seconds &...
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Aug 03, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
Dont know how to reset or bypass gm theft system car is not starting .It tries and quits.
this is one way to reset it :
first make sure the battery is fully charged , then do the following:
key in the ignition but do not crank the motor, just leave it at the
ignition mode for ten minutes ,then turn it off POSITION for 5 seconds then REPEAT again 2 more times. at the 3 rd time youre gonna notice the ANTI THEFT light on dash to blink. when doing the last step , remove key , inserted again and turn on motor , good luck , AJ
May 28, 2009 | 2001 Chevrolet Malibu
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
Proxima ds1 not lighting
hi
replace or clean the Air filters. Run the lamp reset command if you have.if not solved then check ballast unit which ignites the lamp.
try this also, press the poweroff button on the remote control for ten seconds, the lamp will reset to zero, if you run the projector more than 1100 hours earlier.
Viren
Jan 16, 2008 | Office Equipment & Supplies
KitchenAid KUDD01DSSS Architect Series Double Drawer Dishwasher, Less than 24 in, 5 Cycle Selections with 3 Cycle Options, Sani Rinse Option, Whisper Quiet Ultima Sound Insulation System, Sure-Hold Light Item Clips, Rinse-Aid Dispenser, Electronic Controls with Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
