Question about Cell Phones
Yellow sheild icon by wireless connection
Whats does the yellow shield mean
  • 76 Answers
No wireless connection or a connectivity problem with it. May be user name password mismatch? Add your wireless modem id and password again in the wireless settings in the general settings section. If your wireless modem id is in there delete or forget this net work. Search and add again.
Posted on May 12, 2014
How to wire the Superstar DM-452 to a Cobra 2000, 5pin plug. Mic wire colors are Sheild, White, Yellow, Red, Blue.
Yellow is your Audio so it will go to Pin 1
Shield will go to Pin 2
Receive will be black wire Pin 3
Red wire = Ground pin 4 (or it will work with out it)
and Blue will be transmit Pin 5
Oct 16, 2014 | Radio Communications
I just want to know on my cm 918t that i got this right the wht and yello wires have a center and a sheild yes and thx
Black negative/ground,
Red +12V,
White shielded =Audio out, centre white to centre pin of Rca plug shield to outer rca,
Yellow Shielded = video out centre yellow to centre pin of Rca plug shield to outer plug.
I have no idea what your question is but hope that's what you wanted to know
Jun 22, 2014 | Cars & Trucks
Meaning of this symbol
It either means you have limited or no connectivity, in which case you should reset the router/wireless access point you are connected to, by powering it off and then powering it back on after 1 minute. Otherwise it simply means the wireless network you are connected to, or can see on the wireless network list, is unencrypted and any data you send over that network can in fact be viewed by someone else provided that they have the tools for it.
May 11, 2014 | Computers & Internet
Hotspot shield does not connect due to restriction by server
Here's a video Branimir Matijević suggested as a solution to your problem from YouTube:
Freedom House: Hotspot Shield Tutorial
May 02, 2013 | Computers & Internet
Trying to connect to my wireless router belkin n150 with my laptop compaq presario 2500 have a yellow triangle saying limited or no connectivity
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Jan 01, 2013 | Computers & Internet
When i go to update my ipod, it says, network connection timed out, please make sure network connection is correct and active. how do i do that so i can update my ipod?
Go to System Preferences from the Apple icon menu (top left) under the Internet & Wireless section there is a Network icon (glass ball looking thing) click on that. green dot next to ethernet (or wireless whatever one you use) means you are connected. yellow dot means ready but not connected. red dot means not connected.
If you have a red dot next to the connection that you use, check your router or modem. You might have to call you ISP if the problems keep happening.
Feb 20, 2011 | Apple iTunes
Loose heat shield
Most likely it's a heat sheild on the converter, maybe the muffler. 1 on top and 1 on the bottom. The heat sheild is welded to the converter, over time they rust away, around the welds. You can use a large diameter worm gear clamp to keep the heat sheild from rattling. The sheilds are in place so if you drive over grass, the heat from the converter won't ignite the grass.
Mar 14, 2010 | 1997 Honda Accord
I do not see any wireless icon in the network connection...i dont know what to do...please help me....
First go to the control panel > device manager (In XP the manager is in the System folder). Scroll down to network adapters, open it and look at the adapters listed....there should be two, one should be an ethernet card and the other a wireless or WLAN card. Look to see if there are yellow icons by their names. This usualy indicates a problem with either the card or the drivers running them. If they do not have yellow trouble symbols by them, then make sure the wireless switch is turned on either by switch on the outside of the laptop or by an Fn key combination. In the case of your laptop, the switches were optional, but just in case look on the front edge of your laptop, by the audio jacks on the left side should be your wlan switch, make sure it is in the "on" position. If there are yellow icons by the wireless, try right clicking on the adapter and uninstalling it. Then reboot, make sure you are connected to the internet via ethernet cable, you will want to let windows search windows update for a new driver when it reinstalls the device upon rebooting. See if that takes care of the problem. Also, if you have changed the way your system boots like say "selective startup" through the msconfig command, that may need to be temp. changed until this is cleared up, then you can go back to it.
Jan 12, 2010 | Acer Aspire 5580 Notebook
How to change the rear 3 spark plugs on a Buick regal LS 2002
metal sheild comes of with sparkplug wire,just spin and pull should come out then remove sheild and slide on new wire and connect back to plug,its just a slide on heat sheild.good luck.
Oct 04, 2009 | 2002 Buick Regal
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
