Question about Garden
How do you fit tines to MacAllister scarifier ?
How do you fit tines to the drum?
Why does the front roller keep dropping, resulting in lawn scalpage?
Is the adjuster broken or wore out so it won't hold where it is suppose too be. Some times you just need to tighten the bolts that holds them on. You may have to replace the adjuster as well.
Jul 27, 2015 | Garden
How do you fit new Tine claws to this model
new tines on most any tiller looks easy but is a real job , over the years I have developed a more simpler way of just leaving mounting arms on drive shaft (getting them off is the hard part) and cutting the rivets off that hold tines to mounting arms with a grinder , then I just use bolts to reconnect new tines to old mounting arms
Apr 27, 2015 | Garden
Change suffolk punch mower14 from grass cutter to scarifier
Remove grass box support cradle. Unscrew 2 allen bolts (one each side - located in front of cutting cylinder). Remove mowe side casing (drive side). Pull out entire cutting cylinder assembly. Usually they slide out without issue, but sometimes, they will jam and need levering out. There's nothing holding it in except the 2 screws.
Insert the scarifier assembly and secure with the 2 bolts.
Job done
Oct 12, 2014 | Garden
Replacing new tines or a complete new drum
flexrake.com/1f-lawn-rake-head-only-flex-steel.html
Apr 29, 2014 | Flexrake Lawn Rake With 21 Flexpoly Lexan...
Macallister
Two year warranty from MacAllister is not worth the promise they make. Dont buy Macallister products. I am so disappointed with them.
Jan 07, 2014 | Drills
Will a hayter hobby push mower take a universal scarifier/dethatching balde? thanks
Depends on how old it is. If it has a disc blade, it won't fit (there's no blade boss to fit it to!), but if a standard blade is fitted, it can be replaced with a scaifier blade. Having said that, rotary mowers aren't really suited to the task - better to get a cheap cylinder mower and fit a scarifier cylinder. MUCH more effective.
phil_saunders@bigfoot.com
Sep 21, 2009 | Garden
I have a Troy-Bilt PTO Horse (Horse III) 8HP TINES
The tines are very close to the housing and sometimes you do get rocks hitting,as for the dirt it should have side panels to keep the dirt in place.
May 07, 2009 | Garden
How do you change the nylon cog on the scarifier 14'' cartridge
if you hold the scarifier shaft tightly and use a socket on nylon cog and turn socket anti-clockwise it will unscrew
Mar 30, 2009 | Garden
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
