Question about Microwave Ovens
Kenmore quick touck microwave, door latch hard to open & shut
Door hard to open, close door latch not moving up & down correctly. how can I remove & dismandle the door? door?
  • 28 Answers
If your want to start the easy path, get a Q-tip and some light weight grease and lightly grease the door-switch levers inside the door latch holes and see if that solves your problem. If not, then you will have to remove the cover, and likely you will find the door switch assembly and it's metal mounting support are bent on something of an angle - the switch assembly should be at 90 degrees to the front of the microwave oven so that he door latch fingers can slip in and activate the control switches easily all at the same time - straighten the switch frame which may require you to remove the switch bank temporarily. The little bit of grease still doesn't hurt to do it.
Reassemble.
Posted on May 14, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
Posted on Nov 15, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: MICROWAVE DOOR WILL NOT OPEN.
Please post the brand name and model number so we can have the best chance to help you.
But generally you will see a plastic lever that is touching both the door open button and the area of the door switches.
That lever is what breaks most often, and if you will push up on the door hooks (latch heads) , the door will open.
Pushing on the door open button repeatedly while looking inside will help you figure it out, too.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 01, 2007
  • 619 Answers
SOURCE: Sharp Microwave model R-1850A door won't open
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Posted on Jan 14, 2008
Drummernick
  • 440 Answers
SOURCE: door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Posted on Feb 10, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Apr 18, 2008
My Panasonic microwave nn-t945sfx. Door is hard to shut and is not latching correctly. I inspected the spring and latch and it appears to be working correctly. I noticed the two holes where the latch
Common problem. Apply a small dab of lithium grease to the tips of the door hooks. You might also have to adt. the door latch switch assembly inside the oven as it could be bent out of shape from the hard to close door.
Nov 19, 2014 | Panasonic Microwave Ovens
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
SAMSUNG MICROWAVE, MODEL SMH9187ST, WHEN NOT IN USE, WE HEARD A SMALL NOISE (CLICK) AND THE DOOR OPENED. THE DOOR WIL NOT LATCH AND STAY CLOSED. I CHECKED THE TWO FUSES, THEY ARE GOOD. WITH THE...
Hi dschema,
You have a door switch issue. There are three behind the panel. If you can lift and hold the door and it starts one of them is bad for sure. You would be better off replacing all three or have a repair man replace them because a microwave can hold 3000v even unplugged.
Hope it helps.
Thank you for using FixYa.
Aug 20, 2011 | Samsung SMH9187ST Microwave Oven
Our panasonic inverter microwave (3 years old) needs repeated hard slams to shut the door so that the light goes off and the microwave will work. How do we fix this problem as I'm afraid we are going to...
We have a Panasonic Inverter microwave. Door became difficult to close and had to slam it hard while holding themicrowave to keep it from moving. When opening the door did not pop open but did unlatch. I ordered a new door lever from Panasonic. When got part I removed case from microwave and lever was okay. I then removed the perimeter strip on the inside of the door. With a screwdriver I stretched the spring at the bottom that keeps the door latches pulled downward. Spring still worked just not as stiff. Put perimeter piece back on the door and replaced housing (which I didn't need to remove in the first place), and then put a small drop of vegetable oil on the cams where the door latches hit when closing door. Viola, door opens and closed as new. Problem solved. Diagnosis: over time the latch tension spring hardens and gets too stiff. P.S.: I had several similar springs as backup in case I screwed up the original one.
Jan 16, 2011 | Panasonic NN-SN657SMicrowave Oven
Hi I have a new Kenmore microwave model 721.8503 - it is a month old and wont turn on.. I close the door and the light stays on and it wont work..the door is completely shut
It sounds like the light switch isn't being deactivated which is preventing the microwave from operating (a failsafe).
Look to see that the buttons inside the microwave (where the latches are inserted when you close the door) are actually being pressed.
They may be out of place, obstructed, or your latches on the door may be damaged.
If you don't see anything wrong, try pressing the buttons yourself (with a pen bottom) to see if the light goes off.
Dec 18, 2010 | Kenmore Microwave Ovens
Hi, I have a Kenmore 87103 microwave and it has started acting up lately. When I place something in the microwave and set the timer, the timer counts down however the microwave doesn't work (no sound and...
Mine also does the same thing however I only need to lift the door upwards slightly (after it's closed) and it engages the High Voltage Transformer, thus working as normal.
Once you know that, you can get it to work every time. I beleive the clips on the door don't properly stop latch in correctly and the safety feature keep the microwave from acutally turning truly "ON".
Nov 28, 2010 | Kenmore Microwave Ovens
Microwave door shut, but interior light is on - micro won't work
Yes. One of your door switches is not working. It could be an alignment issue or a faulty switch. There are actually 3 switches in the door latch area.
Eric
Sep 06, 2009 | Kenmore Microwave Ovens
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
