Question about Vehicle Parts & Accessories
How do I replace a seat belt on renault modus
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
U will need a 19 mm spanner remove covers and remove MAKE SURE U PUT BACK ANY SPACERS AND WASHERS.
Posted on May 16, 2014
How do I fold down the rear seats in a Renault Modus
first o all you pull up the two black pull knobs on the top of the back rests secondly you pull the black handle in the middle at the back of the seat to move them forward thirdly pull up the red lever and this will unlock the seats thenpick them up and fold them forward
Apr 06, 2015 | Renault Modus Cars & Trucks
How do i get rid of check airbag message and spaner on my scean? Renault modus 1.4, 2006 model
airbag line , computer or airbag unit is faulty. repairing the fault will rectify the message. its probable that if the vehicle was not in an accident that it is a line probably under the passenger seat. play with the wires under seats with the ignition on and see if at any point the light disappears, if so repair that set of wiring as plugs corrode
Jul 14, 2014 | 2006 Renault Modus 1.4
Where are the spark plugs located on a 1.4l renault modus
Could this help? It's not from Modus, but similarities may help you...
Apr 02, 2013 | 2006 Renault Modus 1.4
What is the sparkplug used by a renault modus 1.4 petrol
Spark plug type NGK Part # 6799 Gap 0.80"
Feb 21, 2012 | 2005 Renault 181
Headlight bulb replacement on renault modus
Replacing a dipped head light bulb on a Renault Modus.
Having recently purchased a 2008 Modus with the passenger side dipped beam head light bulb not working. Concerned that posts on this matter talked about removing several body parts or a costly visit to the Renault dealer.
It's a simple 10 minute job. It is a little tricky with limited access and restricted view. However - its as simlpe as - remove circular cover from rear of bulb holder - remove the clip on connecter and push to side. You need to pull the wire clip above the bulb slightly to the side from its holding and it flips down and out of the way Be careful not to detach the clip from its holding points below the bulb - it's extra hassle to put back in.
You can now remove the old bulb - replace with the new bulb. Make sure its sitting correctly in housing. Re attach the clip to its holding point above the bulb. Replace the connector.Replace the circular cover to the rear of the bulb holder.
It takes 10 minutes - cost me under five pounds for the replacement bulb. Hope this helps.
Feb 05, 2012 | Renault Modus Cars & Trucks
RE Renault Modus; My drivers side airbag light is staying on after moving the drivers seat, am I correct in assuming the wiring is under the seat or is there a more sinister reason?.
no check the wiring under the seat ,unplug the connector and plug it back in again and moke sure thier is no rubbish floating about like empty coke cans and kids toys
Mar 08, 2011 | Renault 181 Cars & Trucks
The brake lights on my 05 renault modus won't work. All other light working and the brake bulbs are ok. Checked under seat and all looks ok. Any ideas.
Did you check the fuse?
If the fuse is good, you might have a bad brake light switch. It's under the dash, near the top of the brake pedal
Jul 15, 2009 | 2006 Renault Le Car
Renault Modus repair manual wanted
1.5 modus deisel wont start orange light on dash says ignition fault
Jun 12, 2009 | 2006 Renault Le Car
Renault modus dashboard warning light 'check emissions' and rotten egg pong and lumpy drive. Car has done less than12K but did fill up at Asda previous evening before problem started.
Not necessarily catalytic convertor. this happened on mine recently and it just needed a coil replacing. Costs about £87 at a Renault garage if this is the case
Jun 07, 2009 | 2005 Renault 181
Renault Modus 2005 Diesel
how do u reset service-light on facia display on 2005 renault modus after self-service?
Apr 27, 2009 | 2005 Renault 181
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
