Question about Chevrolet Vehicle Parts & Accessories
Reciever module can you please tell me where i can find information on my factory keyless system for 93 chevy k1500 Silverado, i really need the wire diagram for the factory installed reciever/module. Thank you
    Problem Solver:
  • 8 Answers
THE DEALER WILL HAVE IT ON FILE BY VIN NUMBER
Posted on May 11, 2014
Testimonial: "thanks for the help but surely there is info on my keyless system somewhere without going thru dealer like the manufacture of the reciever, why are the conections ground off on one of the chips..."
Keyless entry wiring diagram 1998 chevy k1500
https://s21.postimg.org/u3aw5m6qv/remote_comtrol.jpg
Click on the link, is that what your talking about? Where it says battery or B+ that voltage come from power accessory c/b, interior fuse block, hot all the time. The one that says ignition, goes hot with key on, gage fuse. The black wire is ground.
Jun 13, 2017 | Cars & Trucks
I need a wiring or instalation diagram for 03 silverado
Download manual from the attached link: https://www.gmupfitter.com/publicat/2004_BB/2003_Beyond_LD_Electric_CK.pdf
http://alarmsellout.com/support/diagrams/vehicle/CHEVROLET%20SILVERADO%201988-2005.pdf
This may help:
http://www.automotivetroubleshootingsecrets.com/2003_Chevrolet_Silverado_1500_4.8L_No_Start_Stall.html
This may help:
2003-2006 Chevrolet Silverado Wiring Diagram:
Listed below is the vehicle specific wiring diagram for your car alarm, remote starter or keyless entry installation into your 2003-2006 Chevrolet Silverado . This information outlines the wires location, color and polarity to help you identify the proper connection spots in the vehicle. Please be sure to test all of your wires with a digital multimeter before making any connections.
PART COLOR LOCATION 12 VOLT CONSTANT RED (+) @ IGNITION SWITCH HARNESS STARTER YELLOW (+) @ IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK (+) @ IGNITION SWITCH HARNESS IGNITION 2 WHITE (+), SEE NOTE #2 @ IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 BROWN (+) @ IGNITION SWITCH HARNESS KEYSENSE N/A PARKING LIGHTS ( - ) GRAY/BLACK (-) @ BCM, BROWN PLUG, PIN B2, SEE NOTE #3 PARKING LIGHTS ( + ) BROWN (+) IN DRIVERS KICK PANEL POWER LOCK SEE NOTE #1, (for BASE MODEL TRUCKS, SEE NOTE #4) POWER UNLOCK SEE NOTE #1, (for BASE MODEL TRUCKS SEE NOTE #4) DOOR TRIGGER GRAY/BLACK (-)(DRIVERS) and BLACK/WHITE (-)(PASSENGER), SEE NOTE #5 @ EACH DOOR MODULE, IN EACH DOOR DOMELIGHT SUPERVISION GRAY/BLACK (-) @ BCM, BLACK PLUG, PIN E, SEE NOTE #3 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK/YELLOW to BLACK (-) @ STEERING COLUMN HARNESS TACH Any wire NOT, PINK, BLACK or BROWN (AC) @ IGNITION COILS or FUEL-INJECTORS WAIT TO START LIGHT DK. BLUE (-) @ INSTRUMENT CLUSTER, PIN A2 BRAKE WHITE (+) @ BRAKE PEDAL SWITCH FACTORY ALARM DISARM LT. GREEN (-) @ DRIVERS DOOR MODULE, IN DOOR, BLACK 26-PIN PLUG PIN 15 ANTI-THEFT GM'S PASSLOCK 2 ANTI-THEFT SYSTEM, SEE NOTE #1 @ IGNITION SWITCH EXTRA INFORMATION NOTE #1: This vehicle uses GM'S PASSLOCK 2 ANTI-THEFT SYSTEM that requires a 791 Bypass Module to Remote Start, if you are using a REMOTE STARTER ONLY, use the 791. IF you are installing a REMOTE STARTER with KEYLESS ENTRY you MUST USE the INTERFACE BYPASS MODULE, Part # DB-ALL or XK09, EITHER Bypass will do the Anti-theft and Keyless entry. If connecting a keyless entry only you can use the GMDL-BP. NOTE #2: The IGNITION #2 wire WHITE must be connected to prevent a CHECK ENGINE LIGHT from turning on and to prevent DAMAGE to the TRANSMISSION on this Vehicle. NOTE #3; The BCM is located under the Drivers Side of the dash, the BCM has 6 plugs on it, with the PURPLE plug on the back. NOTE #4: On BASE model truck the DOOR LOCK INTERFACE MODULE is not necessary, the LOCK wire is a LT BLUE (TYPE B) @ the BCM, LT BLUE PLUG, PIN B5, and the UNLOCK wire is a WHITE (TYPE B) @ the BCM, LT BLUE PLUG, PIN B10. NOTE #5: On BASE Model trucks, the Door Trigger wires are @ the BCM, LT BLUE PLUG, PINS B4 and A5. On 4-Door Trucks the LEFT REAR Door is a LT BLUE/BLACK (-) PIN A3 and the RIGHT REAR Door is a LT GREEN/BLACK (-) PIN A2, located in a PURPLE PLUG at the BCM, use all 4 wires and diode isolate when installing an alarm system.
2011-03-28_044351_brakes_lamps_circuit_2003_2500_siverado-dfydxumns33ohqc3bsmt22yf-2-8.gif
collection-fuel-2003-chevy-silverado-wiring-diagram-estimation-information-standard-work-therefore-straight-swapped-dfydxumns33ohqc3bsmt22yf-2-34.jpg
igniton-black-2003-chevy-silverado-wiring-diagram-neutral-before-position-begin-switch-know-scheme-unsure-pairs-dfydxumns33ohqc3bsmt22yf-2-53.png
sensor-primary-2003-chevy-silverado-wiring-diagram-fuel-pump-plugs-solid-conductors-important-looking-more-channels-dfydxumns33ohqc3bsmt22yf-2-76.png
igniton-black-2003-chevy-silverado-wiring-diagram-neutral-before-position-begin-switch-know-scheme-unsure-pairs-dfydxumns33ohqc3bsmt22yf-2-151.png
Apr 16, 2017 | Cars & Trucks
How many wire harness clips connect to rcdlr module on 2007 impala besides the antenna
2007 Chevy Impala Keyless Entry: Keyless Entry Only ...
www.2carpros.com/questions/2007-chevrolet-impala-chevy-keyless-entry
Dec 30, 2010 - CHEVY KEYLESS ENTRY ... 2006-2007 Chevrolet Impala, Monte Carlo ... Remove the clips holding the RCDLR antenna wire at the RCDLR module and along the "A" pillar. 5. ... Connect the new antenna to the RCDLR antenna module. 11.... The existing antenna is grounded into another wiring harness.
TPMS and key FOB range problems - LS1TECH
ls1tech.com/forums/ls4.../719926-tpms-key-fob-range-problems.html
May 24, 2007 - 2006-2007 Chevrolet Impala, Monte Carlo ... Remove the clips holding the RCDLR antenna wire at the RCDLR module and along the "A" pillar.
Buick Workshop Manuals > Lucerne V6-3.8L (2007 ...
Dec 01, 2015 | 2007 Chevrolet Impala
Ok so i have 95 chevy silverado i change plugs wires,plugs,rotor button, distributor cap, fuel pump,fuel fiter and it still is missing up i have to hold it to the floor and it takes a bit to crank anyone...
Check distributor I have a 93 1500 pull cap and trun engine over watch the shaft if nothing turn truck off and check free play on rotor bug shaft
Jan 28, 2013 | 1995 Chevrolet K1500
93 chevy K150, tail light, turn signal
If you are very sure the wires are good, then you need to replace the multifunction switch in the steering column. Be sure you have checked the wire harness for bare spots or a broken wire first. Hope this helps.
Jul 01, 2012 | Cars & Trucks
I have a 93 chevy silverado when I'm driving
YOU HAVE A GROUND FAULT SHORT FROM A CHAFFED WIRE.......
May 23, 2012 | 1993 Chevrolet K1500
I need a radio wiring digram color code for 2009 chevy silverado
2009 CHEVROLET SILVERADO C1500 4DR TRUCK WITH 4.3L ENGINE AND STANDARD AUDIO SYSTEM
Remote Start
WIRE COLOR POLARITY LOCATION
Battery RED/WHITE (+) IGNITION SWITCH HARNESS
LOW CURRENT, FOR HIGH CURRENT USE RED/BLACK AT VEHICLE FUSE BOX
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Accessory 1 BROWN (+) IGNITION SWITCH HARNESS
MAY BE YELLOW ON SOME MODELS
Accessory 2 PINK/BLACK (+) IGNTION SWITCH HARNESS
FOR REMOTE START INTEGRATION
Starter 1 YELLOW/BLACK (+) AT MODULE UNDER HOOD BEHIND DRIVER HEADLIGHT
NOT FOR REMOTE START, FOR REMOTE START INFORMATION
Starter 2 PINK/BLACK (+) IGNITION SWITCH HARNESS
Anti-Theft Type GM PASSKEY IIIĀ® ANTI-THEFT SYSTEM
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense PINK (+) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/BLACK (AC) AT ECM MODULE UNDER HOOD ON DRIVER FENDER
BLACK PLUG PIN #57
Parking Lights LIGHT BLUE (-) AT VEHICLE LIGHT SWITCH
Brake Lights LIGHT BLUE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
IGNITION MUST BE ON FOR THIS WIRE TO TEST
Reverse Lights DARK BLUE (+) AT BCM MODULE UNDER DRIVER DASH
Horn TAN (-) IN HARNESS AT STEERING COLUMN
ALSO AT BCM MODULE UNDER DRIVER DASH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock WHITE (-) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE UNLOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
PowerLock LIGHT BLUE (+) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE LOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
i would use a DLPK module
DLPK (2009 Chevrolet Silverado)
W2W
CC-Heated Seats Activation
DL-Arm Factory Security
DL-Disarm Factory Security
DL-Door Lock Control
DL-Door Unlock
DL-Driver Priority Unlock
PK-Immobilizer Bypass-Data No Key Req'd
RS-RAP Shut Down (Remote ACC Power)
RS-Tach / RPM Output
SS-Entry Monitoring ALL Door Pins
SS-Entry Monitoring Driver Door Pin
SS-Entry Monitoring Front Door Pins
SS-Entry Monitoring Hood Pin
D2D
CC-Heated Seats
DL-Door Unlock
Hope helps.
Mar 31, 2011 | Chevrolet Silverado 1500 Cars & Trucks
I need a wiring diagram from a CODE ALARM CA-135 two-way security with keyless entry, to a 1989 Chevy Silverado 1500.
First, do you have the code alarm master module required for this to work? Model Ca-425. You can get the wiring for the car from the12volt.com.
Nov 10, 2010 | Chevrolet Silverado 1500 Cars & Trucks
2001 Chevy cavalier Z24 keyless entry not working.
You should have it scaned to see if you have any codes. It has a RCDLR (remote control door lock reciever) this is the module that recieves the signal from the fobs. If it has a problem then the system will not work. If it has to be replaced then a dealer will have to program it for you. Good Luck
May 25, 2009 | 2001 Chevrolet Cavalier
97 color scheme for aux hok up
I could go outside and pop my dash apart real quick and tell you.Its real easy to take it off and pull the cd player and radio right out.Is your wiring harness missing or something?Is that why you need to know what it looks like?
Nov 23, 2008 | 1997 Chevrolet K1500
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
