Question about Ricoh Aficio 450 Copier
Ricoh aficio 4850 emf
I have error sc301 in my copier ricoh aficio 4850 emf, I know that's error related to the fusing, But I do not know exactly where the problem is in the fuser.can anybody help PLEASE thank U
  • Ricoh Expert
  • 393 Answers
Has to do with the charging of your drum, its in the "cleaning assy of the drum unit
Posted on May 12, 2014
    Scholar:
  • 130 Answers
Most fuser problems have to do with the fuser lamp and or the thermistor, or the thermal fuse. If you can put you hand near, and I did say near, because the fuser is very hot and can burn you, you should feel heat. Use an inferred thermometer to pick up heat. Should be around 225 degrees F +- a few degrees. If no heat detected the lamp is bad or is not receiving voltage. The thermistor detects heat from the fuser roller, it lays on it, and sends a signal to the logic to turn up the voltage to the lamp or turn it down. The thermal fuse could be open hence not voltage to the lamp. Last but not least no power from power supply or no signal from logic board to turn up the juice. Hope that helps.
Posted on May 11, 2014
  • 10 Answers
SOURCE: ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Posted on Nov 05, 2008
  • 9 Answers
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Posted on Dec 16, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
SOURCE: I have error code sc329 on my Aficio/ricoh copier.
In some models this code means that the laser has aged and must be replaced.
But he would be interesting to know that model is for being safe of this.
Posted on Sep 17, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
ERROR CODE E-5 HELP RICOH 4522
If you press the "." key you will get the last 2 digits to complete the error message. For example: "E542".
Whatever the result, 'E5xx' is always related to a fuser error; That means, you have a blown fuse, lamp, or thermistor, and the problem, and the service code can only be reset by a technician in service mode after the fault is fixed.
Nov 25, 2011 | Ricoh Aficio 450 Copier
Ricoh aficio 1018d sc 544
Hello!
This code is related to a Fusing low temperature error.
You probably need to change Hot roller (or fusing rooler) and thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do njot have technical knowledge)
If you still want to reset the code tey this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Aug 03, 2011 | Ricoh Aficio 1018D Copier
Comment enlever message sc 570 sur ricoh 1232c
This error code is related to a Insufficient oil.
The fusing oil tank is in the rear of the machine.
You have to call Ricoh to supply the oil.
See you
Mar 29, 2011 | Ricoh Aficio 1232C Color Copier
We have a Ricoh aficio 2051sp with error code SC555 what does this mean?
you will need to remove these and test with a multimeter. we are in michigan do you need a ricoh copier service 248-677-8112
Oct 07, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
May 26, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
Nov 05, 2008 | Ricoh Aficio 1035 Copier
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
