Valor nvg 606w screen goes black and then comes back on
  • 2,013 Answers
Verify the power and data cables are both firmly seated on both ends. If that does not solve this, borrow a monitor from a friend. If
that works, your monitor needs replaced.
Posted on May 28, 2014
2005 Silverado 1500 crew cab stuck in 4wd high?
How many buttons on 4X4 switch ? Or doesn't have any . What transfer case does your have ?
Transfer Case - NVG 149-NP3
Transfer Case - NVG 246-NP8
Transfer Case - NVG 261-NP2
Transfer Case - NVG 263-NP1
4X4 light saying lit ? Flashes ?
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel.
The NVG 263 transfer case features a three button shift control switch located on the instrument panel.
Need more info . Could have DTC'S - diagnostic troube codes
DTC B0790
DTC B2725
DTC C0300
DTC C0305
DTC C0306
DTC C0321
DTC C0327
DTC C0359
DTC C0374
DTC C0379
DTC C0550
Aug 26, 2017 | Cars & Trucks
Have 2004 Chevy1500z71&service 4wd message comes onafter it in 4H but it still worksHad fluids changed 2 yrs ago.Goes into 4wdfine&seems like it runs good. Comes on sometime even not in 4wd. Thanks
Which transfer case does your truck have ?
SERVICE 4WD
Refer to
Transfer Case Description and Operation for the Transfer Case - NVG 149-NP3
Transfer Case Description and Operation for the Transfer Case - NVG 246-NP8
Transfer Case Description and Operation for the Transfer Case - NVG 261-NP2
Transfer Case Description and Operation for the Transfer Case - NVG 263-NP1
The SERVICE 4WD indicator is located in the instrument panel cluster (IPC), and shares the common power and ground of the IPC. The transfer case shift control module controls the service indicator by sending the IPC a Class 2 message. This indicator may be controlled with the scan tool using the IPC device controls.
You should take it to the dealer an have it checked for DTC'S -diagnostic trouble codes
Jan 07, 2016 | Cars & Trucks
My screen. On my valor is not working at all can not see anything , but radio works fine. What is wrong please help
  • If you haven't found the answer (or your like me and you found a post because you were looking for the same answer)...
  • Is the PINK wire connected to GROUND? (Legally in most states it should be connected to something that is only at GROUND when the vehicle is in PARK). When this wire is not at GROUND potential the video screen does not come on and stays black in any of the VIDEO modes.
  • When the source is RADIO the screen will function no matter what pink has going on.
  • The PINK wire is a NEGATIVE ENABLE but I don't know if it knows it.
  • When source is DVD with a DVD loaded you should hear the audio even thought the screen is black, of course if its sitting on a DVD menu with no sound you won't really know.
  • This is a PINK wire coming from the head units modular plug. not the bundle of wires that comes through the grommet but the plug that is removable. Not to imply that I have ever seen another pink wire. Well once I drank a lot of tequila ... not a pink wire. never mind.
  • While the wire was labeled on the OEM harness I have seen, the OEM wiring diagrams I have seen only have the description "PARKING" but no color code.
  • Feel free to repost or contact if the pink wire is grounded and the video screen is still acting the fool.
Sep 02, 2015 | Valor Car Audio & Video
2002 yukon front end wont engage
2002 GMC Yukon
2002 GMC Yukon
2004 TRANSMISSION Transfer Case - NVG 149-NP (One Speed Automatic) - SUV
TRANSFER CASE NO FRONT DRIVE
Transfer Case No Front Drive
Cause
Correction
DEFINITION: The transfer case is not delivering engine torque to the front propeller shaft.
Review the Symptoms - Transfer Case and perform the necessary inspections.
Viscous coupling faulty 1. Inspect the transfer case fluid for being black. If the fluid is
black, it is most likely caused by a viscous coupling failure.
2. Test for a faulty viscous coupling. Refer to Transfer Case
Description and Operation.
3. Disassemble the transfer case. Refer to Transfer Case
Disassemble in Transfer Case - NVG 149-NP3 Unit Repair.
4. Inspect the viscous coupling for a bulged cover. Refer to
Cleaning and Inspection in Transfer Case - NVG 149-NP3 Unit
Repair.
5. Replace the viscous coupling if it is faulty. Refer to Transfer
Case Assemble in Transfer Case - NVG 149-NP3 Unit Repair.
Planetary carrier faulty 1. Disassemble the transfer case. Refer to Transfer Case
2. Inspect for faulty planetary carrier components. Refer to
Repair.
3. Replace any faulty planetary carrier components. Refer to
Transfer Case Assemble in Transfer Case - NVG 149-NP3 Unit
Repair.
Oct 19, 2010 | GMC Yukon Cars & Trucks
I connect my alpine cva 1003 to valor dv-169T dvd player. sounds come out but the screen is not getting connected to dvd player. i connect red, white and yellow wires.
if evrything is ok with the dvd (make sure the dvd is working fine), you need to hook up the yellow/ blue wires and yellow / black wires one for parking breack and the other for the breack chek the diagram on top of the alpine radio .
Jun 15, 2010 | Alpine CVA-1003 Car Video Player
Valor IDA 700w won't play movies
TRY CONECCTING THE BLACK/GREEN CABLE TO GROUND
Nov 21, 2008 | Panasonic DV-169 Valor DVD/VCD/CD/MP3...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
