Question about Philips 190WV
I am looking for a table top base stand for a Phillips 190wv pc monitor. Can anyone help.
My original stand broke, and I am looking for any help that I can get.Thanks.
  • 116 Answers
SOURCE: Im just looking to buy
check online auctions, or local papers, it would b you best bet. Other option would be to buy a entertainment rack that has a big screen mount on it.
Posted on Dec 11, 2008
guru_dev
  • 315 Answers
SOURCE: cannot find table top stand to buy for philips lcd television
you can try on of these: http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1311&_nkw=tv+stand&_sacat=See-All-Categories
Posted on Jun 15, 2009
  • 418 Answers
SOURCE: Philips 42 PF7220A Table top stand is needed
310430816731 or 3113912877791 ; from encompassparts.com ; guest login. 34.00 -50.00
Posted on May 03, 2010
SOURCE: Philips 32PF5531D 32 in LCD tv table top stand
I have a Philips 32PF5520D/10 TV and need the Table top stand that fits it - anyone have any ideas where I can get one ?
Posted on Nov 28, 2010
SOURCE: I have a phillips tv model number: 37pf9731d/10 Do
Hi there. I have the same problem with you but have found out from Philips and their supplier that they have discontinued making the parts for the tv.
Did you manage to solve this?
Posted on Oct 27, 2011
Desktop Stand ,any ideas ?
  • You can get a universal wall mount if the stand is no longer available or you cant find one
May 10, 2014 | Philips 190WV
I have a Phillips 190wv pc monitor and I am looking for a desktop stand for same as the original broke. Any ideas ?
got wood I would just build my own...cheaper and you can customize it to your like..
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
I broke the table top base for my new Haier HL32XSL LED LCD tv and can not find a part number or place to order a new one.
If it is not practical to glue the base back together with metal-filled epoxy (e. g., J-B Weld), then consider whether you can adapt the hardware to a custom wood base. If you are not comfortable with your woodworking skills, any cabinet shop could probably make a base for you. Be sure to include space for the base weight in the bottom of the wood plate, and specify that it must be capable of supporting the set. (The entire weight of the set including the original stand is 50.7 pounds; subtract the weight of the stand to find the minimum support capacity.) If the vertical arm broke, it may be better to replace it with steel or aluminum channel or tubing.
If the original stand mount scheme is not amenable to a hardwood base, you can build a stand to use the wall mount holes in the back. Be sure to offset the base weight forward enough so the weight of the mounting bracket doesn't tend to tip the set backwards.
May 24, 2011 | Haier HLH326BB 32 in. LCD HDTV
Need a table top stand for a LG 15" (model
Tries websites like Amazon.com,Ebay.com to buy a new or used base stand for ur tv.
Dec 08, 2010 | LG 15LC1RB 15 in. LCD Television
Lost the table top stand for my KDL-40s4100
I might have one of this table top stand.
Write to jah2mil@hotmail.com for more info.
Jul 08, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Does anyone have the table top stand for sale ? tia
You can order a replacement stand assembly for this model (P42H401) from a major Hitachi parts distributor at the link below:
Hitachi P42H401 Replacement Part Stand Assembly / Table Top Stand
Apr 15, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Can't remove stand from Element flx 1910 TV.
On the bottom of the Element FLX-1910 there are 4 tabs located on the bottom side of the base. With the help of another person, please slide all 4 tabs in an inward direction. This will release the tension between the base and the stand. Slide the base over the tabs and remove the base from the stand.
Apr 12, 2009 | Element Electronics FLX-1910 19 in. LCD...
Phillips 190wv 19inch monitor keeps on flickering leavind the display not in its full glory?
look at you video output speed.
<Control panel>::<display>settings tab::advanced button::monitor tab
once there it should shown you a slow refresh rate, set higher & the 'flicker' should dissipate, you may find that you'll want to update your video adapter as well.
Jul 18, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
