Question about Bose SoundDock® (Black) Docking Station for Apple iPod
Where do I get my SoundDock fixed?
Bose sounddock volume is possessed and randomly defaults to maximum volume at which point, if the system (remote or base unit) responds to volume adjustment, it reverts back to maximum as soon as it's left alone.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
It could also be that the volume button has gotten stuck, misaligned and it needs to be seated back into the the right spot. If you feel comfortable in removing the bottom of the Dock connector held on by three screws, you could look and see if the volume button is stuck or maybe a little crooked. I don't believe that this is caused by a bad circuit board. If you have experienced any problems with the docking of iDevice, I would check out www.invebo.com and make sure to type in the www. For some reason it will not navigate to the website if omitted. They are an awesome company for Bose SoundDock DIY repairs or have them repair it for you. Check out the Bluetooth upgrade, if you have an iPod Touch or any device with Bluetooth, you don't have to dock the device anymore. So you have more control of what you're listening to. Anyway, I bet it's just the volume up button that is stuck, or something is stuck in the volume up bottom on the right side of dock connector. If that is not the case then INVEBO is the least expensive repair route, under 50 bucks., Bose will do an upgrade, switch out program, running you a total of around $164.00. You send them your unit, they send you a box for the return, then they send out a new unit.
Posted on Aug 29, 2014
SOURCE: No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Posted on Nov 24, 2009
SOURCE: docking cradle in bose sounddock
Order Prod Number 041615 , Description: "279103-004 MOD ASSY CRADLE BLK SOUNDDOCK" from Bose spares. Costs £35. Undo the four philips screws in base, romove cover and replace whole cradle assembly. There is a circuit board attached to the main unit by a ribbon cable - you do not need to remove this cable you can instead can thread the circuit board through the old cradle. Then pull out the ribbon cable that connects the new assembly to the circuit board. Installation of new one n reverse. Protect from static by using wrist strap etc.
Posted on Dec 03, 2009
SOURCE: Bose Sounddock problem
I had the same issue, it just stopped working today for no reason. Since it's out of Warranty and Bose charges too much to fix it, I took the bottom off, cleaned all the contacts, applied some dialectric silicone compound to the contacts, put it back together... and it works great!
Posted on Mar 10, 2010
  • 51 Answers
SOURCE: Bose Sounddock won't play iPod touch
You probably have a broken docking connector or bad power supply. Contact www.invebo.com to get a replacement board. It takes minutes to fit. They also sell the USB charge upgrade to enable you dock to charge the IPHONE on the Soundock original.
Posted on Aug 16, 2010
  • 17 Answers
SOURCE: Bose SoundDock will no longer
My guess is that the iPod connector in the Sounddock is loose or damaged. You can get a new connector and solder it on yourself (very difficult!) or you could get a replacement PCB at http://www.chargeconverter.com/store/index.php?route=product/category&path=37 which is quite easy to replace (see http://ridax.wordpress.com for description).
Posted on Feb 14, 2011
Boss sounddeck series 1 no volume
Try resetting the SoundDock system. Unplug the system from power for 60 seconds. Remove the battery. Plug the system in without the battery, and see if the audio returns
Sep 01, 2014 | Apple Bose SoundDock Series II Digital...
Have a Bose Soundock1 that is possessed.....volume cannot be controlled.............and goes to max volume whether use remote or plus-minus buttons on unit...where does the problem lie....since I have no...
I repair these fro a local store. The best best is to visit www.invebo.com and enter your dock serial number to access the diagnostic and check videos for your particular dock. The volume control problem can be due to several faults. The most likely is the docking board. Invebo sell kits on a buy and try basis. First have a look at the diagnostic videos. You may be able to get it going yourself.
Oct 24, 2011 | Bose SoundDock Digital Music System for...
Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
Jul 11, 2010 | Bose SoundDock Portable Digital Music...
Bose sounddock seriesII remote will not navigate playlist
EIther the remote is faulty or a broken comms pin on docking connector. www.invebo.com will rpelace the dock connector for you for about 30 Euros.
Apr 16, 2010 | Apple Bose SoundDock Series II Digital...
Bose sounddock remote and ipod menu functions
Unfortunately I've never seen a universal remote that will control the extra functions of this. If it's the original SoundDock, you can only do: volume, power, play/pause, skip/scan. If this is a SoundDock II or SoundDock Portable, you can only control: volume, power, play/pause, skip/scan, and playlist up/ playlist down. Quite honestly, that's all I need to do on my SoundDock. I can't really read what's on my iPod from where I'm sitting in the first place. It may be possible to use a universal learning remote for this, but you'd have to teach commands from an apple remote as well as the bose remote, and the learning remote (+apple remote) may cost you over 1/3 the cost of the SoundDock. It also may not work perfectly. I hope this helps somewhat.
Jun 22, 2009 | Bose SoundDock Digital Music System for...
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
May 31, 2009 | Bose SoundDock digital music system...
Sep 17, 2008 | Bose SoundDock digital music system...
Bose Sounddock Volume Control Problems
Well, there really was nothing to it.
I let it dry out for the rest of the day and it went back to normal, thankfully.
:) Juliyana.
Jul 19, 2008 | Bose SoundDock Digital Music System for...
Bose SoundDock® (Black) Docking Station for Apple iPod Logo
150 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
